Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Thu Aug 02, 2018 3:47 pm Post subject: 74 Standard - Formula Vee inspired GL Build |
Hey guys,
So I figured it was probably about time I stop lurking and actually start a build thread for this project. This bug was my first car and now that I'm out of college and actually have some money I figure I should give her the make over she has always deserved.
The Plan
Mission Statement:
So, I love the German look, but with this build I dont want to exactly take it too far style wise. The plan is make a fantastically performing bug with a more subdued styling. Here are the set in stone requirements.
- She must look like it could have come that way to non beetle people
- She must be a capable daily driver for mostly freeway miles
- She must get over 20 MPG (american), but preferably ~30MPG
Objectives:
Suspension
As with any performance build, the absolute first mod one should ever do is making it handle. The plan here is actually fairly simple. Stage 1 is to off with soft ride KYB gas shocks front and rear as well as dual 3/4" sway bars. Stage 2 will be to lower the car roughly 2 1/2" with front drop spindles and convert to early 944NA rear trailing arms and spring plates (and figure out how to lower those). Once I get the weight/power of the engine and transmission more figured out, stage 3 is where will start playing with stiffer springs/bars and different size sway bars and probably adjustable shocks and a kafer bar system.
Brakes
The car currently sits with a front disc conversion and rear drums all of which are in fairly nice condition. The primary upgrade on the brake system will be a big one though. The brakes will be upgraded to early 944NA brakes on all 4 corners (donor parts already obtained) which will require rear trailing arm/spring plate swap as well as having the front spindles and hubs being machined by VDubEngineering for proper fitment on a standard beetle.
Wheels & Tires
The plan for wheels is to move to 15x6 or 16x6 early offset Porsche wheels for the best wheel width without running into clearance issues or needing to narrow my beam. As for which wheels specifically, I like the idea of black cookiecutters, but we will see where I end up. Tires are still something I have no clue on though.
Interior
The interior is something that will largely be worked on intermittently throughout the entire project. My current thoughts are that I would like to somewhat replicate the 1970 Formula Vee Edition package with the gauge layout of the 1600SP. This will include sourcing an appropriate walnut sifter (obtained) and steering wheel as well as fabricating actual wood dash panels and button inlays and black door panels and carpet. The seats I am torn on though. The two major options I am considering are obtaining and reupholstering some sports beetle seats or possibly just going with EMPI race trim seats.
Exterior
This is possibly the easiest, but may take the longest. The plan is to black out the trim, possibly go with smoked light covers, and patch/repaint to get rid of all the chips. I likely wont do much until I have the small rust patch in the rear driver side patched and and can afford/justify a full paint job. This will likely all happen when I finally take the body off the pan fairly far into the build.
Drivetrain
This is one place I still have quite a bit of thinking to do on. My 3 basic options are a Subbie swap for an EJ207 and Subaru transmission (will have done professionally), type 4 conversion with a Porsche tranny (slightly cheaper than the subbie but not much and still aircooled), or a more mild type 1 engine with a better trans (either higher 4th or porsche). What this basically comes down to is just how far I want to build this car. It will continue to be my daily driver for at least a long while, which does make the less efficient engines a bit less appealing. Ultimately, I believe the choice is going to come down to if I want to build my bug to the 9s or do a more moderate build and put the money that would have been used on a more exotic drive train to get another car. Luckily I have a while to think about this one though. _________________ '74 - front disks/lots more work to do
Posted: Thu Aug 02, 2018 3:47 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
The Build
Outline:
Green = Done
Blue = Parts Obtained
Red = Not Done
Phase 1
Suspension
- ball joint and tie rod end replacement
- KYB soft ride gas shocks
- Front and rear 3/4" swaybar
Interior
- Locate gas smell
- Better front seats
- Begin mock up of dash panels (3d print test fits?)
- Install lighter port
Misc
- Full inspection of electrical system
- Repair turn signal switch
- Upgrade headlights/install stealth light bar
Phase 2
944 Conversion
- Obtain donor parts
- Have front spindles and hubs machined and order replacement rotors and pads
- Decide on MC
- Finalize wheels and tires
- Install Conversion
Exterior
- Black out Trim and smoke light covers
- Wolfsburg emblems for wheels
- Front damn
- Fastback Window Cover (?)
Interior
- Walnut Steering Wheel
- Walnut Formula Vee Shifter
- Make Dash Panels
Phase 3
Body Off Restoration
- Fix all Rust
- Patch Paint/Repaint
- Replace Cracked Dash pad
- Install New Carpet
Posts: _________________ '74 - front disks/lots more work to do
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Thu Aug 02, 2018 4:47 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Excellent plan! Seems like it could end up as a distant relative of Glenn's '74:
For your suspension phase 1, it is very important to install both HD swaybars at the same time. Don't do just one and then drive it a while before installing the other because the handling is really wacky- too much oversteer or understeer depending on which single HD bar you install. They have to work in a matched pair to keep the handling neutral.
For your engine, consider that if you build a complete, turn-key mid-range performance engine such as a 2-liter Type 1 with slightly larger valves, you could build the entire engine over the winter, then swap engines in a single weekend. Then you'd be driving your "daily driver" again with absolute minumum downtime. Keep your current running engine completely intact. Swapping over to a type 4 or even to a Subie would inevitably involve much more downtime and adapting/fabricating/cutting.
For seats, consider finding a decent set of Porsche seats; either '80's 911 or even 944's. Since you are considering reupholstering, see if TMI or Sewfine would make a custom set of seat covers using a VW vinyl pattern that was offered in '74. Then the interior would really look like it came out of the factory. Or, try to find some generation 1 Rabbit GTI or Cabrio sport seats. Those have a very similar mounting method as the Beetle seats (rear legs need slight adjusting in width) and you have the side bolsters. It should be straight-forward for either TMI or Sewfine to use Beetle-pattern vinyl for a replacement set of Rabbit covers. Then it'd really look factory stock since those seats were made by VW. |
Posted: Thu Aug 02, 2018 5:08 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Rome wrote: |
haha. Ill have to go look up his build now.
Rome wrote: |
For your suspension phase 1, it is very important to install both HD swaybars at the same time. Don't do just one and then drive it a while before installing the other because the handling is really wacky- too much oversteer or understeer depending on which single HD bar you install. They have to work in a matched pair to keep the handling neutral. |
Luckily that was something I already knew. I actually pulled apart the entire front end yesterday and picked up both sway bars and a full set of shocks last night along with all my balljoints and tie rod ends. My hope is to get the new joints pressed in tomorrow and get everything back together for an alignment on Monday.
Rome wrote: |
For your engine, consider that if you build a complete, turn-key mid-range performance engine such as a 2-liter Type 1 with slightly larger valves, you could build the entire engine over the winter, then swap engines in a single weekend. Then you'd be driving your "daily driver" again with absolute minumum downtime. Keep your current running engine completely intact. Swapping over to a type 4 or even to a Subie would inevitably involve much more downtime and adapting/fabricating/cutting. |
I dont mind the downtime of the car as much as I mind the cost tbh. I do have another car that I can drive while mine is taken all apart, its just that I would kind of like to get rid of that rather uninspiring (auto 08 scion XB) and possibly get a second more interesting car. I just dont know exactly how that feeling stacks up against my desire for a bug that has way too much power.
Rome wrote: |
You know, I hadnt realy thought about getting seat covers instead of reupholstering. I do quite like a lot of the old 911 seats, but they are just too expensive to justify IMO. The rabbit seats I have been considering though, its just not to easy to find them tbh, and (before you mentioned it) I was worried about how well they would go. The massive benefits of either EMPI seats or sport bug seats is definitely the plug and play though, and either way it looks like I would come out about $600. My massive question is just if i can actually find a place to sit in the seats before I buy them. _________________ '74 - front disks/lots more work to do |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1227 Location: Eerie PA
Posted: Fri Aug 03, 2018 5:28 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
I like your color coded build plan / guide. I am going to steal your idea for my projects. It would help keep me focused on what I need to do and motivated when I get to change colors when done. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
cdgreentn Samba Member
Joined: May 01, 2005 Posts: 8 Location: Knoxville, Tn
Posted: Fri Aug 03, 2018 7:57 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
My guess is you are in the Quality or Project management field. I love it. |
Posted: Fri Aug 03, 2018 9:17 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
pondoras box wrote: |
I like your color coded build plan / guide. I am going to steal your idea for my projects. It would help keep me focused on what I need to do and motivated when I get to change colors when done. |
cdgreentn wrote: |
Haha. I picked up the style from doing computer builds quite a while back (last one was 3930k generation) actually. Im just a little sad at how limited the recognized bb code is here tbh. Took me a fair while to figure out how to format it all with only like 1/5th the commands I am use to. _________________ '74 - front disks/lots more work to do |
Posted: Fri Aug 03, 2018 9:34 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
So, not a full update here, but kind of a small one. I currently have the entire front end of my bug pulled apart with everything off except the steering box and the beam. Though I would like to pull the beam off, clean it, and paint it, I just dont think I have the time for that currently as I would like to be driving my car again by the end of this weekend. There were a couple of weird things I encountered when pulling everything apart, so here is a list of my anomalies/what kicked my ass
My front sway bar was only connected by fittings on one side with the other side completely rotted out, and the sway bar its self was cracked (looked like someone beat on it with a hammer, but its hard to tell). My front passenger side shock hemorrhaged all of its oil when I finally got the weight of the car off it. The same shock was missing its lower retaining nut and only held on by being seized to the bracket its self. The driver inner tierod looks like it still has a good end (being replaced anyways) but the not was not tightened down at all. When pulling the spindles off one of the ball joints was so shot that the pin the nut was on was spinning inside of the joint making it an absolute pain to get off. I had to go buy wobble socket extensions for my impact and literally just let it run and smoke a bit until the nut let go and I could get the ball joint out of the socket.
I also have a gas smell that I seriously cant locate. I have an early 68 tank and have just gone about replacing the vent lines (larger one and running one off of the cracked cap in the picture), fill hose, gas cap, and the sender seal to no avail. I do not have the carbon canister installed, but I didnt think that should play too big of a role. The hose connecting the tank to the had line is never wet at all and doesnt smell of gas from what I can tell. Maybe the issue is where the bottom hose comes out of the tank as the grease around it isnt dry, but it doesnt realy smell of gas either. Over all this one is kind of kicking my ass.
Here are some teaser pictures for my front end overhaul post
[/img] _________________ '74 - front disks/lots more work to do |
Posted: Sat Aug 04, 2018 9:22 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Another mini update because I’m kinda frothing mad. My tie rod ends were a pretty massive PITA to get off the tie rods, but ultimately I got 3 off just fine but was stuck on one of them. I decided to just go and get new tie rods at the only shop open and when I got back to install them I found out the threads on one was just completely jacked up to the point of being completely unusable. I’ll return them on Monday but that meant I was kinda stuck on what I could do this weekend. Being completely stuck because of this i ended up litteraly filling the old tie rod with PB blaster and leaving it setting upright in the blazing sun. After 2 hours of soaking, using a vise and a pipe wrench I finally broke the last one free and got back on my way rebuilding the front end. Have one spindle back on and the trailing arms and tie rod installed on the other side. Should actualy get to finishing this part tomorrow luckily, so hopefully I’ve got a full update post some time monday _________________ '74 - front disks/lots more work to do |
jinx758 Samba Member
Posted: Sun Aug 05, 2018 6:02 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
These cars can definitely be frustrating ... some have a rather steep learning curve.
If it's not "improvements" from the PO it's I'll fitting aftermarket parts. Ugh !
It's all worth it in the end ... chin up.
Good luck ... jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Posted: Mon Aug 13, 2018 11:01 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
So, I ran into a few more problems, as is to be expected, but the entire front end is finally rebuilt, shocks installed, and front and rear sway bars installed. I am just waiting for the shop to call me back to let me know when they can fit me in for a custom spec alignment. Big post on the rebuild inbound. In the mean time though, I unfortunately discovered another problem. It seems as though I have a break line leak inside of the main tube not only causing a leak but also the beginnings of some rust....
Not sure how im going to fix this one at all unfortunately _________________ '74 - front disks/lots more work to do |
Rome Samba Member
Posted: Mon Aug 13, 2018 1:03 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Crap- 2 steps forward, 1 step back with your repairs. Have you reached over to touch that wet spot, then smelled your finger? Most likely it's gasoline which does run through/inside the center tunnel. Brake fluid runs in the main pipe to the left of the tunnel along the inner edge of the driver's floorpan and would not leak through at the center of the tunnel. Once you confirm which fluid is leaking, we can advise on repairs.
As to your earlier question as to tire pressures, I recommend the radial tire setting per the sticker on your glovebox door. |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Mon Aug 13, 2018 1:16 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Thoroughly read threads on transmission swaps before making a decision. The 901 is best left in a 914 and a 915 transaxle is going to cost as much as a fully built engine and difficult to source. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Mon Aug 13, 2018 1:42 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Rome wrote: |
haha. as it always is. TBH, I cant quite identify the fluid its self. There is not much smell at all, and its realy clean, so it shouldn't be motor oil or gas. Brake fluid was my assumption since the last time it happened my fluid level plummeted (I had overfilled by accident that time), but maybe I'm wrong. Is there any good way to realy check what it is for sure? It does feel a little oily, but not very much and I dont have a hydrolic clutch so I was kinda at a loss other than brake fluid. I am parked somewhere else currently though, so I'll go check in a few and see if it smells different after driving it somewhere.
theKbStockpiler wrote: |
Thoroughly read threads on transmission swaps before making a decision. The 901 is best left in a 914 and a 915 transaxle is going to cost as much as a fully built engine and difficult to source. |
Hahaha. I fully plan to, dont worry. I think (doing the fitment and install myself, but not the building) I was looking about 2-3k for a 901 or 914 and 5-6k for a subbie swap (with LSD). Ultimately, I dont realy mind how much I spend on this build as I am 100% building my daily forever car (or at least until I am driving kids daily). More money just means more time between steps as far as I am concerned. Ultimately though, I'm well over a year out from any real engine or transmission work, so I have some time. I think the big one coming up that IDK what to do about is seats tbh. _________________ '74 - front disks/lots more work to do |
Posted: Tue Aug 14, 2018 10:02 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Ok, so I checked all of my brake lines last night and you guys were right, that doesn't seem to be the problem. Unless my transmission is burping fluid out of the shift linkage, my best it is you guys are right about it being gas. My guess for why it doesnt smell is because it has been sitting on the ground for a while and has lost most of its ethanol. I am going to pull my seat up tonight and check the tunnel through the access panel above the shift rod coupler. I seriously hope the issue is gas running back down the had pipe from the soft tube not being sealed, but if the hard tube is bad, is that even possible to fix with the body still on? _________________ '74 - front disks/lots more work to do |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Tue Aug 14, 2018 10:13 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
If the fluid doesn't smell like gas it is probably brake fluid and is probably leaking from the master cylinder.
Check for leaking inside and around the rubber boot in front of the pedals. The forward bulkhead the master cylinder bolts to is hollow and has an opening directly into the center tunnel so fluid leaking from the master has an easy path down the tunnel of the car. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Tue Aug 14, 2018 11:47 am Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Q-Dog wrote: |
Check for leaking inside and around the rubber boot in front of the pedals. The forward bulkhead the master cylinder bolts to is hollow and has an opening directly into the center tunnel so fluid leaking from the master has an easy path down the tunnel of the car. |
Huh. I hadnt thought about that path. None of the rest of the tunnel seems to be corroding, but there is some surface rust on that drain hole. Does that seem reasonable if brake fluid is traveling all of the way down the tunnel? _________________ '74 - front disks/lots more work to do |
Posted: Tue Aug 14, 2018 12:45 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
so it looks like you are right. I pulled the cover from above the shift coupler and could see it wet fairly far up the tube. I went up to the shifter, pulled it, and low and behold, there is actual liquid sitting in the channels on the bottom of the tube.
That would make sense that I only see the leak when sitting in the driveway as that is the only time it can actualy drain because it isnt sitting flat. I guess my question is now, how do I locate the actual issue? I cant actualy take a wheel off and look at the MC its self until after work, but what should I be looking for? I am assuming its the seal with the plunger, is that an auto full replacement of the MC or can I rebuild it somehow? _________________ '74 - front disks/lots more work to do |
Posted: Tue Aug 14, 2018 3:27 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
Quote: |
Hahaha. I fully plan to, dont worry. I think (doing the fitment and install myself, but not the building) I |
If you're not concerned with the cost but want to do some of the work yourself, the Berg 5 speed is the way to go. The info I had on the BugSpeed products was that they took SOME of the adapting work out of the Subaru install but not nearly all of it. The Porsche 901 transaxle's first gear is only meant to get the car rolling and Porsche parts are about 3-4 times more expensive than a VW so beware of that. The 901 shift pattern makes you go over a gate to get it into 2nd gear which is meant for a fast 2-3 shift but most people don't like this for the street. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Posted: Tue Aug 14, 2018 3:42 pm Post subject: Re: 74 Standard - Formula Vee inspired GL Build |
If you're not concerned with the cost but want to do some of the work yourself, the Berg 5 speed is the way to go. |
I had certainly thought about that, but I was having trouble finding what kind fo torque it was actualy capable of handling, I couldnt find any new anywhere to specify my own gears, and it was also looking like 2.5-3.5k.
The info I had on the BugSpeed products was that they took SOME of the adapting work out of the Subaru install but not nearly all of it. |
For the subaru, I was actually looking at a prebuilt subaru gears conversion from subbie stuff (only an hour and a half from where I live, so no shipping even), and as far as I understand fitting the converted trans into the car is actually not very hard.
The Porsche 901 transaxle's first gear is only meant to get the car rolling and Porsche parts are about 3-4 times more expensive than a VW so beware of that. The 901 shift pattern makes you go over a gate to get it into 2nd gear which is meant for a fast 2-3 shift but most people don't like this for the street. |
Honestly, there is just something so cool about the dog leg shifter that realy tugs at my hipster heart strings.... I get that first is weak, but thats fine since if I go that route I wont put an engine that would be worth launching into the car. Honestly, I wish I could drive one first to realy make sure I would be fine with it, but I have no idea how to even go about trying to test drive either a 901, 914, or converted VW. _________________ '74 - front disks/lots more work to do |
