Jenk0 Samba Member
Posted: Fri Aug 03, 2018 4:33 pm Post subject: Single port EFI conversion in Type 3 engine |
Hi all,
I have a single port 1916 type engine that I’d like to convert to electronic fuel injection. Has anyone out there done this before? I’m finding it hard to find the correct parts and ‘how to’ on the internet. Lots of stuff out there for dual port just not single port. Thanks for your help. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34018 Location: Conejo Valley, CA
Posted: Fri Aug 03, 2018 6:06 pm Post subject: Re: Single port EFI conversion in Type 3 engine |
Stock VW/Bosch FI was one injector per cylinder, tough to do with single port heads! You might find some throttle body injection made for the same manifold as those awful progressive replacement carbs (though those were mostly/all for center sections for dual port intake manifolds), and make a system work. not sure why you would want to, though... |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Fri Aug 03, 2018 9:30 pm Post subject: Re: Single port EFI conversion in Type 3 engine |
I agree, why work so hard to get a larger displacement engine, to choke the life out of it by running a single port head? EFI as a single port flat engine is going to be even more of a challenge, as there is about zero backing on it. If say just swap to DP heads, and save the hassle. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Aug 03, 2018 10:55 pm Post subject: Re: Single port EFI conversion in Type 3 engine |
Sqrbckguy38 wrote: |
I agree, why work so hard to get a larger displacement engine, to choke the life out of it by running a single port head? EFI as a single port flat engine is going to be even more of a challenge, as there is about zero backing on it. If say just swap to DP heads, and save the hassle. |
Actually... a stroker single port might change your tune a little about that. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 599 Location: CA, USA
Posted: Mon Aug 06, 2018 2:11 pm Post subject: Re: Single port EFI conversion in Type 3 engine |
Jenk0 wrote: |
Hi all,
Are you able to do a little bit of fabrication and welding or know someone who can? If you're willing to use aftermarket EFI like Megasquirt or something I should think it's quite doable. May be interesting trying to tune it since you'd need to feed two cylinders with one injector.
My idea would be to weld an injector bung into a stock single port manifold and use either a single barrel carb as the throttle body on each side or maybe a motorcycle TB?
Let us know how it goes, maybe do a project thread. This one sounds interesting if you decide to do it. _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
(Conversion thread https://www.thesamba.com/vw/forum/viewtopic.php?t=732508&highlight= or https://shoptalkforums.com/viewtopic.php?f=1&t=151375&sid=f0542d44a322d290c29d6609fac7f215 )
74 914, 2.0L w/ D-Jet
-Derek |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
