spectre1995 Samba Member
Joined: May 06, 2018 Posts: 57 Location: El Segundo, CA
Posted: Sat Aug 04, 2018 9:21 am Post subject: Poor Fuel Mileage on 1973 Super - 1600 DP |
Lately I've been noticing the fuel economy on my 1973 Super has gradually been worsening. The engine is a 1600cc dual port, using a H30/31 carburetor and a DVDA distributor. Lately, I've been getting about 11-15 MPG
Last week, I pulled the tank to check for leaks and noticed that there was some fuel residue underneath the tank, but I figured this could be due to when my filler neck hose broke, and the residue was just left over. I replaced the gasket for the sender as well as the hoses for the breather, but I am still noticing a very slight fuel smell in the trunk, which could be due to one of the hoses coming off of the expansion chamber being open ended (not sure where it leads but I'll cap it off at some point today).
The Bentley book mentions a few possible problems & solutions. The ones I've already done (besides rebuilding the carb);
-Tested the float for leaks
-Installed new needle valve and function tested it
-Tested automatic choke
-New spark plugs / wires / distributor cap & rotor
What I still need to do;
-Check jets (have two new idle jets, need to check accelerator)
-Check fuel pressure at float needle valve
-Check / adjust points
So my question is, if the fuel pressure at the needle valve is excessive, will it have a serious effect on my fuel economy? Also, what other problems / solutions should I consider to improve my fuel economy?
I'm also considering swapping the DVDA for a 009 distributor, or even an SVDA. Which would be the best paired with the H30/31 carb, and why?
Thank you all in advance |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Aug 04, 2018 9:31 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
spectre1995 wrote: |
What I still need to do; Do this.
Don't do this!
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Aug 04, 2018 11:57 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
When I first bought my ‘74 Super Beetle, it got about 13 mpg. I had the stock Bosch 034 SVDA, coupled with an H 30/31. The engine ran very rich.
My solution was to replace it with a Solex 34 pict 3. The reason? That’s what the car came with when new.
The difference was amazing. Five years and no issues.
Some people do well with an 09 distributor and an H30/31. But the SVDA distributor doesn’t go well with your carburetor. Not enough vacuum.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Sat Aug 04, 2018 12:38 pm Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
I have 009 with Petronix and H30/31 carb.
Good throttle response and 23-25MPG _________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15” 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
Posted: Sat Aug 04, 2018 11:26 pm Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
I spent the day cleaning and rebuilding the carburetor once again, this time installing a larger main jet (125 vs. the 120 that was in it), then checked the fuel pressure. It seems to be holding steady at +/- 3 PSI at varying RPM's (Up to about 3400 it goes just beyond 3 PSI).
I tried setting the idle RPM but it was fluctuating between 600 and 900, and would not hold steady. I also discovered the timing was improperly set.
I brought the distributor to the local VW place, and we determined that the DVDA distributor may not have been the best option for the H30/31 carburetor. So, I picked up a brand new Kuhltek SVDA and installed it, and not only does the idle RPM seem more stable, the engine itself seems "happier" with the new distributor setup.
At some point I plan to "upgrade" to a 34 PICT-3 so vacuum should be less of an issue in the future.
In any case, I'd assume having the timing improperly set (5 degrees ATDC) would be my #1 cause for poor fuel economy, as everything else checked out okay, save for some corrosion on the spark plug wire connectors which I had not seen before. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Sat Aug 04, 2018 11:50 pm Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
With the h30/31, make sure you are using the vacuum port facing the rear of the car, that is angled upwards/diagonally From the flange of the carb. The port facing the drivers side of the car (above the cutoff solenoid) is meant for use with vacuum-only distributors, and will over advance the timing if used.
fluxcap wrote: |
Hello,
Recently got a good deal on an engine so I bought it as a spare or for a future project. It's a 1600sp and has a 205T distributor with an H30/31 solex.
I broke the engine down a little bit to replace some of the tins and swap it over to a doghouse setup. I was putting it all back together and was puzzled by all the vacuum ports on the carb. When I originally got the engine, the vacuum line was connected to port D. I know the previous owner of this engine pretty good and know the engine has been dependable and gone of plenty of long journeys with no issues set up this way.
I've read a good bit of posts about the H30/31 carb and have seen a few pics of others with this same carb that are using different vacuum ports than the one used on my carb. I tried finding a reference picture of what all the different ports are for, but came up empty handed. The port the vacuum is currently connected to (D) is giving around 32-33 degrees of advance from idle to about 3500 rpm, which appears to be in spec with the info listed on OldVolksHome. Is there a better port I should be using? Anybody know what all the other ports are for?
I really just need to know which one is the correct vacuum port, but like I mentioned above, found a bunch of posts on this carb, but no clear breakdown of what all the ports are for. Maybe if we could identify them all, it would help others down the road.
Port D is what you want. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Frank Bassman Samba Member
Posted: Sun Aug 05, 2018 5:16 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
Just to be clear, use D for advance and B for retard.
-Frank |
jinx758 Samba Member
Posted: Sun Aug 05, 2018 5:49 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
Please verify you have no vacuum leaks ... anywhere. Check ALL OVER : anywhere on the carb that has a shaft or gasket, intake runner boots, and manifold intake. It's a little concerning to me your statement of a fluctuating idle.
You won't be able to correctly tune your carb with any vacuum leak.
My experience after rebuilding my stock carb was no less than 4 places that I had idle changes when sprayed with carb cleaner. I replaced the intake boots, carb & also put a Kuhltek 034. Car has been very well behaved ever since. I also found a cheap RPM/dwell meter & found out my El Cheapo dizzy prefers a "loose" point gap. The dwell was @ 65 so my points were too close together. Once this was corrected ... What a difference in drivability !
I used to be able to tune by ear but because of my degraded hearing from surfing and installing way too many stupidly loud audio systems over 3 decades I have to rely on tuning tools.
Just trying to help ... good luck ... jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
vamram Samba Member
Posted: Sun Aug 05, 2018 6:25 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
Have you checked your oil level and smell? Is there gas in it? I had a fuel pump go bad allowing gas to leak into the crankcase and was getting like 10-14 mpg. I "figured it out" once the engine hydrolocked from so much gas in the block. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
AlmostHeavenWV_VW Samba Member
Posted: Sun Aug 05, 2018 6:29 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
jinx758 wrote: |
[....] I also found a cheap RPM/dwell meter & found out my El Cheapo dizzy prefers a "loose" point gap. The dwell was @ 65 so my points were too close together. Once this was corrected ... What a difference in drivability !
Just trying to help ... good luck ... jinx |
Just want to make sure we're all on the same page here:
Point gap and dwell measurements are inversely related:
--High point gap = low dwell angle
--Low point gap = high dwell angle
I wouldn't say your distributor prefers a 'loose' point gap. 65* is just way too high dwell- meaning that your points were closed much of the time and only opening briefly (and barely) (i.e. the point gap was low). This causes poor running characteristics by messing with proper spark delivery.
Glenn wrote: |
Gap is .016" and dwell is 49° ±3° |
So that translates to a dwell of 46-53* is advised per most manuals. Some will include values as low as 45*, some increase the max to 55*. A dwell of anything between 45-55* is okay (although 55* should be considered an alert for the need for timely point gap adjusting, as soon as feasibly possible)
Some people prefer to adjust their points to a 'loose' .016" and dwell closer to 45* so that as the rubbing block wears, the point gap/dwell will actually fall closer to "perfect" of .016" and 47* dwell and run through the full acceptable range (allowing for longer gap adjustment intervals- BUT proper lubrication of the breaker plate pivots, shaft oiling, and cam lobe greasing must still be followed no matter what you choose to set the point gap as!!
Just wanted to put up that info surrounding point gap and dwell.
Hijack over lol
Carry on, gentlemen! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Sun Aug 05, 2018 8:38 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
Good morning everyone,
To start out, yes the vacuum advance is using port "D" on the carburetor, and it appears to be advancing properly.
As far as vacuum leaks, the only noticeable one (spraying carb cleaner and watching for RPM changes) is on the throttle shaft of the carburetor. Everything else in the engine compartment is okay.
I recently changed my fuel pump because the diaphragm on the old one was leaking fuel into the oil. I changed the pump, and the oil. My oil level seems to be dropping at a very slow rate over the past couple months, and I have noticed a minor leak coming from around the filler / alternator stand, which I will address sometime soon. It probably just needs to be torqued down a bit further.
My goal for today is to verify the points gap and the timing, and possibly have the time to do a compression test on all four cylinders.
As far as distributor lubrication goes, will a health amount of engine oil suffice? I have some leftover 20W-50 sitting in the trunk that could possibly be used. |
Randy in Maine Samba Member
Posted: Sun Aug 05, 2018 9:01 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
Here's a diagram with instructions on how to properly lubricate the distributor
1600DP AK case
Solex 34PICT3 Carb
Posted: Sun Aug 05, 2018 9:03 am Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
Almost : thanks for sharing that bit of knowledge. That's what makes this forum so great !
I checked the gap on my new Craptek 034 before installation & it was spot on perfect out of the box. My OCD, PSM, & CRS force me to double & triple check most projects ( lol ). After 2 weeks of 009-like hesitation & head scratchin I researched & found some posts about dwell. I regapped my point dwell while slightly twisting the feeler gauge as it didn't have a .017. Hence the "loose" reference. All was good / better, and I have no pinging - I run premium gas only.
My drivability & miles per gallon did improve.
Just my experience ... your mileage may vary ( 'nother pun ).
Best regards ... jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
VALVES (cold)
POINTS
TIMING
SCRAPE ALL GROUNDS
1971 Standard Bug
1776cc dual port
034 distributor
Posted: Sun Aug 19, 2018 12:05 pm Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
Hm, still having some issues here.
So I found out the center intake manifold section was off of a single port engine, so when I went to install this brand new 34 PICT 3 carb on the engine, it didn't fit. I swapped in a DP center intake and then the 34-3, and it seems to run a lot better than it did before.
So here's the issue. Last night I took the car out for a run and it ran really good with the new carb, definitely better than before, the issue is that once again I ran out of fuel at the 130 mile mark on the odometer. I find it nearly impossible to me getting 13 MPG on a car like this.
I suspect my gas may have been stolen (recent string of auto thefts and gas siphoning nearby) but in the event that it wasn't stolen, I'm still scratching my head over this since I have not found any leaking, etc. I still need to do a compression test, which I will likely be doing sometime this week |
Posted: Sun Aug 19, 2018 1:32 pm Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
What is your timing set to?
Definitely check the jetting in the carb, but it should be pretty close. 55 idle, 125-130 main should be ballpark.
Plug gaps? you did check the before installing, right
Don't bother with premium. The car doesn't have high enough compression to need it. Also, try buying gas somewhere different, just in case.
What air filter? restrictive aftermarket stuff can hurt economy.
Any pics of the engine? _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Posted: Sun Aug 19, 2018 1:37 pm Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
It's set to 7.5 Degrees BTDC
Jetting is 55 idle, 130 main
I checked the plugs prior to install.vif I recall it was 0.028 gap
Air filter is a round aftermarket one from the local VW parts shop |
Posted: Sun Aug 19, 2018 1:49 pm Post subject: Re: Poor Fuel Mileage on 1973 Super - 1600 DP |
Without sparking an oil debate like, is the fact I'm using 20W-50 going to have an effect on MPG? |
