Peter_Plade Samba Member
Joined: January 09, 2005 Posts: 551 Location: Denmark
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Sat Aug 04, 2018 3:07 pm Post subject: Re: Airflow systems oil cooler |
You'll likely find more information on the 356 Registry. I've seen a post or two where oil temps were reduced 20 degrees (fahrenheit). I've never seen anyone make a comment about head temps. Before I bought mine, I was told it was a "nice to have", not "need to have" item.
You might want to email the manufacturer. He has a 912, and regularly manufactures oil coolers for small aircraft. He was very responsive when I had questions.
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Thu Aug 23, 2018 8:31 am Post subject: Re: Airflow systems oil cooler |
This is what I use in my Denzel powered lowlight Ghia. She runs cool all the time! I install 'em in my Pre-A 1500cc engine builds also......
This model is made exclusively for the 25hp - 36hp - Porsche Pre-A 2pc. case design as it allows you to use the factory type oil cooler seals.
No more trying to figure out which oil cooler seals to use with those "other" aftermarket oil coolers!
Contact: Bill Genervo @ (949) 680-0085 / Tell 'em Mr. Okrasa sent you
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
Posted: Thu Aug 23, 2018 9:51 am Post subject: Re: Airflow systems oil cooler |
"This model is made exclusively for the 25hp - 36hp - Porsche Pre-A 2pc. case design"
And it's less expensive than the 356 cooler too (525 vs 595).
https://www.airflow-systems.com/category/motorsports-oil-coolers/
Cheers,
Richard Feynman |
Posted: Wed Dec 26, 2018 3:23 pm Post subject: Re: Airflow systems oil cooler |
I emailed Airflow Systems and asked them what the differences are between the 356 and 36hp oil coolers. Here's what they said:
"The -03 has gasket bores ... match 36 hp case and 6 mm studs. The -01 has larger gasket bores and is drilled and tapped for 8 mm studs. Core is the same."
Cheers,
Richard Feynman |
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Mon Jan 20, 2020 6:51 am Post subject: Re: Airflow systems oil cooler |
I contacted Brian 2 weeks ago via his website, as I was interested in buying this oil cooler, but the cooler is out of stock. I was wondering when it will be produced again, so I could order it.
does anyone know if he is going to do a new production run? Or does anyone has a new cooler which he/she is not going to use for a project? _________________ 1192CC WW okrasa
48,2 DIN PS (58SAE HP)@4430rpm - 83Nm@3610rpm |
Posted: Tue Jan 21, 2020 2:56 pm Post subject: Re: Airflow systems oil cooler |
Many other Porsche vendors carry aluminum oil coolers.
https://www.stoddard.com/61610704100-nla.html.html
Cheers,
Richard Feynman |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Tue Jan 21, 2020 11:13 pm Post subject: Re: Airflow systems oil cooler |
Hello
The aluminum coolers are a step up in cooling compared to the stock cooler. What I DON`T like about these is, that they do make cyl 3/4 run warmer than usual under load due to the simple fact that this cooler can dissapate more heat than the stock steel cooler can. It does make for an easy and clean set up with improved cooling, and the elevated temps on cyl 3/4 is primarily when you use the power, but still.
Personally I prefer to install a small external cooler instead, so that you get as much heat out of the engine compartement as possible. |
Albertoprop17 Samba Member
Joined: March 15, 2016 Posts: 196 Location: Valencia (Spain)
Posted: Wed Feb 12, 2020 3:31 am Post subject: Re: Airflow systems oil cooler |
Don't you guys consider to convert them to doghouse oil cooler? As far as I know it can be done with little effort _________________ '54 vintage speed beetle slow project
Visit my workshop site and leave a like:
https://www.facebook.com/talleresalacreu/ |
Posted: Wed Feb 12, 2020 12:14 pm Post subject: Re: Airflow systems oil cooler |
"Don't you guys consider to convert them to doghouse oil cooler?"
Here you go: https://www.thesamba.com/vw/forum/viewtopic.php?t=358957
Cheers,
Richard Feynman |
JeeWee Samba Member
Posted: Fri Feb 14, 2020 11:44 pm Post subject: Re: Airflow systems oil cooler |
Mr. Okrasa wrote: |
I use AirFlow oil coolers on my engines. |
Thank you Jou, that is also what I would like to do, however currently the coolers are out of stock. Do you know or are you able to check with Brian if these coolers will be in stock somewhere this year?
Thank you for your help! _________________ 1192CC WW okrasa
JeeWee Samba Member
Posted: Wed Jun 17, 2020 12:27 am Post subject: Re: Airflow systems oil cooler |
Does anyone have an Airflow systems oil cooler for sale?
I try to contact Brian but so far I did not get any response.
Or is there anyone who knows Brian and would be so kind to contact him with the question if these oil coolers will be in stock again?
I really would love to use one for my engine. _________________ 1192CC WW okrasa
PeteSC Samba Member
Posted: Wed Jun 17, 2020 6:11 am Post subject: Re: Airflow systems oil cooler |
I bought mine two years ago and they were great about replying to emails.
I'm not sure of who Brian is, I dealt with William Genevro. His contact info:
Bill Genevro
Managing Director
Airflow Systems
949-218-9701
[email protected]
Good luck! |
JeeWee Samba Member
Posted: Wed Jun 17, 2020 12:40 pm Post subject: Re: Airflow systems oil cooler |
Thanks a lot for your help guys, really appreciated! The 356 coolers will fit 36hp isn't it? the studs for 356 is 8mm instead of 6mm for 36hp? Which 'modification' needs to be done to fit it?
Hopefully I will be in the USA (if they allow me to) as I have a training to follow for 3 weeks, starting end of July. I will be staying in Nevada. Therefore I am looking now for some parts to get my engine going again.
BTW, any cool VW stuff/collections in the Las Vegas area which are worth visiting? _________________ 1192CC WW okrasa
5500 Samba Member
Joined: October 16, 2020 Posts: 112 Location: Cape Cod
Posted: Tue Jan 26, 2021 9:21 pm Post subject: Re: Airflow systems oil cooler |
Maybe a bit late but Airflow Systems has both 356 and 36 hp coolers available in limited numbers. |
