Thing7 Samba Member
Posted: Sat Aug 04, 2018 1:28 pm Post subject: Anybody recognize this oil pan? |
I went to change my oil and the drain plug was pretty loose. When i went to tighten it, it wouldn't tighten. The pan is pretty thin and there are only a couple threads that hold the bolt and they must be stripped.
Does anyone recognize this aftermarket pan? Looks like "de's buggins"
I'm not sure what to but I was thinking if this is a pan I that is still made, I could just get the center part and bolt that back on.
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Sat Aug 04, 2018 1:52 pm Post subject: Re: Anybody recognize this oil pan? |
That’s an antique! Claude’s Buggies is now called CB Performance. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Sat Aug 04, 2018 2:07 pm Post subject: Re: Anybody recognize this oil pan? |
Still available.
_________________ Glenn
Member #1009
#BlueSquare |
Thing7 Samba Member
Glenn Mr. 010
Posted: Sat Aug 04, 2018 2:51 pm Post subject: Re: Anybody recognize this oil pan? |
It uses a oversized plate you you have to use theirs. it also requires a oversized gasket.
The plate is aluminum so you could drill and tap it to put a drain plug in.
You should always drop the plate to clean the screen when you change the oil. _________________ Glenn
Member #1009
#BlueSquare |
KAmes Samba Member
Joined: February 16, 2014 Posts: 877 Location: Illinois
Posted: Sun Aug 05, 2018 6:22 pm Post subject: Re: Anybody recognize this oil pan? |
I wonder if the one you have didn't originally have a drain plug in it either, being that it's in the middle of the logo. |
Thing7 Samba Member
Posted: Mon Aug 06, 2018 7:59 am Post subject: Re: Anybody recognize this oil pan? |
Yeah definitely looks like a custom drain plug hole. The plate is so thin that I'm worried about trying to tap threads in a new plate. The plug only has a couple threads to grab on to |
Posted: Mon Aug 06, 2018 1:14 pm Post subject: Re: Anybody recognize this oil pan? |
CB sells "billet" drain plates with a magnetic plug for those sumps.
http://www.cbperformance.com/product-p/jayceemagx.htm
Forget about using a screen/strainer with those oversize sump covers. |
Posted: Tue Aug 07, 2018 11:53 am Post subject: Re: Anybody recognize this oil pan? |
I wouldn't want to pound an extended sump into a rock or log. |
Thing7 Samba Member
Posted: Thu Aug 09, 2018 8:30 am Post subject: Re: Anybody recognize this oil pan? |
Thanks, I actually ordered one of those and will be installing it soon. You guys recommend loctite on the studs that go into the sump pan and hold the sump plate on? If so, red or blue loctite? |
Posted: Thu Aug 09, 2018 8:45 am Post subject: Re: Anybody recognize this oil pan? |
I like Loctite 680. (620 would be my second choice.)
It's green, but it comes in a red bottle.
Get the mating parts hospital clean first, and replace that broken stud.
Good luck, Mondshine |
Thing7 Samba Member
Posted: Thu Aug 09, 2018 8:55 am Post subject: Re: Anybody recognize this oil pan? |
mondshine wrote: |
Thanks. Yeah I cleaned the surface where the plate goes, got all the old seal off and I ordered a new stud and nut kit. Luckily that stud wasn't broken, it was only missing the nut.
Thanks again! |
Thing7 Samba Member
Posted: Fri Aug 10, 2018 5:14 am Post subject: Re: Anybody recognize this oil pan? |
So far so good. Impressed with the quality of this plate. We'll see how it holds up to leaks. Drain plug will make for quick oil changes!
