Egan Custom Guitars Samba Member
Posted: Sat Aug 04, 2018 2:47 pm Post subject: Hesitation, bucking and stalling |
So I finally got my 77 Bay Window on the road this summer. Ended up bringing to a mechanic to do the work. After a month of success(ish) in the van, I'm back wrestling problems again. Cruising along, it just dies and shuts off. I can pull over and fire it up and keep going right away. Also 4th gear seems to lose power, I can feel the van slowing down and sputtering so I fly back to 3rd and am usually able to limp back to 4th gear and resume before it shuts off again.
Any ideas on where to start?
Recent work done in last few months.....New fuel pump and filter, replaced 2 fuel injectors, timing, new points and condensor, compression issues and push rods problem dealt with.
I pulled the filter out and short of busting it open to look at the guts, it looks clean. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Aug 04, 2018 2:51 pm Post subject: Re: Hesitation, bucking and stalling |
Replace the filter again, just do it it’s cheap. This sounds like fuel starvation to me. It will at least eliminate the cheapest easiest possibility and will most likely fix it. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Sat Aug 04, 2018 2:55 pm Post subject: Re: Hesitation, bucking and stalling |
Ya, I've got a few coming in the mail. |
Randy in Maine Samba Member
Posted: Sat Aug 04, 2018 3:29 pm Post subject: Re: Hesitation, bucking and stalling |
Have you tested the Temp Sensor II? |
Posted: Sat Aug 04, 2018 5:03 pm Post subject: Re: Hesitation, bucking and stalling |
I did read about somebody else arriving at the Temp Sensor II....I ordered in another one just incase. |
Posted: Sat Aug 04, 2018 7:03 pm Post subject: Re: Hesitation, bucking and stalling |
Clean up the connection (notably the electrical connection) and make sure it is snug on the head but don't reef on it.
That costs nothing to do and you can do it in about 10 minutes. |
Clara Samba Member
Posted: Sun Aug 05, 2018 4:26 am Post subject: Re: Hesitation, bucking and stalling |
Randy in Maine wrote: |
When the temp sensor in my 77 fi 2 l engined bus went bad, it would stall, seemingly randomly. I could start it again. It happened more often.
There is a procedure in The book on testing it with a volt ohm meter |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sun Aug 05, 2018 6:50 am Post subject: Re: Hesitation, bucking and stalling |
Clara wrote: |
Here is The Book...
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Sun Aug 05, 2018 6:43 pm Post subject: Re: Hesitation, bucking and stalling |
I'm measuring about 1900 on the sensor,on a cold van. Which I was told to be somewhere closer to 3000. Being about 2/3 of what it should be, should this be cause for concern, or can this number vary? |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Sun Aug 05, 2018 10:56 pm Post subject: Re: Hesitation, bucking and stalling |
Egan Custom Guitars wrote: |
On a summer day that sounds about right. A freezing cold morning can still get you into the upper 2k ohm range with your current reading.
Do the problems persist more when the engine is fully warmed up? If so, test the TS2 resistance for under 400 ohms warmed up.
The TS2 can be completely bypassed (eliminated) on a warm engine by grounding the white wire to a clean metal screw nearby. You'll need a short bit of thin wire, and a good connection to the white wire and clean ground. The car won't start well cold, and it won't drive smoothly until warmed up, so this is only a temporary test or an emergency "get home" fix, not an actual repair.
Does the problem EVER happen in the lower gears?
www.airschooled.com |
Posted: Sun Aug 05, 2018 11:05 pm Post subject: Re: Hesitation, bucking and stalling |
[quote="asiab3"]
Robbie
I would say that it mostly happens when the bus is fully warmed and cruising for a bit. It has happened in all gears, sometimes cruising along in 4th or hitting 2nd gear after a stoplight. |
curtp07 Samba Member
Posted: Mon Aug 06, 2018 1:15 am Post subject: Re: Hesitation, bucking and stalling |
I’m gonna take a shot here on the fuel/electrical side.
1. Check and clean all the FI grounds perfectly?
2. Possible fuel starvation (filter mentioned), up stream of filter..creating fuel tank vacuum of some sort?
Following.
Curt _________________ Subaru |
Posted: Mon Aug 06, 2018 4:16 am Post subject: Re: Hesitation, bucking and stalling |
~1900 ohms is about right on a cold engine, but as it gets warmed up is what is important.
If the sensor is faulty or has a poor connection, the ECU always thinks (through too much resistance) that the engine is still cold and sends too rich of a mixture to the engine. The engine will get all jerky and it will feel like it is running out of gas.
It is tests OK when warm, move on. |
Posted: Mon Aug 06, 2018 1:46 pm Post subject: Re: Hesitation, bucking and stalling |
I just went for a few laps around the farm in the bus, about 10 minutes not getting past 2nd gear, it's also 33 celsius outside. When I got back I was measuring 104 on the sensor. |
Posted: Mon Aug 06, 2018 2:40 pm Post subject: Re: Hesitation, bucking and stalling |
I myself haven't done a fuel pressure test.....but I had my bus with one of the better VW mechanics here on the coast, and he went through the whole fuel system and checked fuel pressure. He replaced the filter, pump and 2 of the injectors. |
Posted: Mon Aug 06, 2018 3:19 pm Post subject: Re: Hesitation, bucking and stalling |
Can you take it back to him? |
SGKent Samba Member
Posted: Mon Aug 06, 2018 3:21 pm Post subject: Re: Hesitation, bucking and stalling |
sounds like a filter unless it started right after you were working on it. If it just gradually got worse it might just be the filter. So many of these buses sat for years and never had the tanks professionally cleaned before bringing them back to life.
check the dwell just on the possibility that it is a broken rubbing block on the points. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Aug 20, 2018 3:03 pm Post subject: Re: Hesitation, bucking and stalling |
[/img]
Well, it seems as though I will be replacing my fuel tank. I actually did end up swapping in a new temp sensor and it ran great right away and was able to put about 100k on it. And then the next morning it would not fire up. I ended up ordering in a few spare filters as well. The flow from the outlet on the tank to the fuel filter was a slow dribble, so I suspect a pile of crud is sitting at the bottom of the tank.
And ideas or tips?
Re-furb the old tank or just swap in a new one? The plan would be to do the fuel lines at the same time |
Posted: Mon Aug 20, 2018 4:17 pm Post subject: Re: Hesitation, bucking and stalling |
New tanks are available I see.....
http://www.busdepot.com/211201075l
Easiest to do with the engine out. That way you can also easily change out all of the fuel lines, clean up the engine compartment, and even paint up the tinwork. Change out the injector seals and intake runner hoses while you are at it. |
