obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2945 Location: East Northport, NY
Posted: Sun Feb 23, 2020 2:25 pm Post subject: Re: Mike's 1964 1200 Deluxe |
I got my engine installed today and wired up. My 6V battery is dead as a door nail - I'll have to buy a new one.
We used a 12V battery to start it and once the engine started (and sounded good!) it cut off. Absent the bulb in the Gauge which I am replacing anyway - I'm curious if a 6V car should run on the generator like a 12V car can run on the alternator even when there is no battery. A friend suggested that the 6V cars may need to have a battery in line to stay running. _________________ Mike
1964 Beetle
2001 Eurovan Camper |
Dibaltic Samba Member
Joined: May 06, 2007 Posts: 564 Location: Chambersburg, Pennsylvania
Posted: Sun Feb 23, 2020 5:03 pm Post subject: Re: Mike's 1964 1200 Deluxe |
obnoxiousblue wrote: |
Among the parts I ordered were new locking front door handles too. They come with an SC KEY, has anyone transferred their lock cylinders from an original set of handles to a new set? |
Did transferring the cylinder work? |
Posted: Sun Feb 23, 2020 8:39 pm Post subject: Re: Mike's 1964 1200 Deluxe |
Nope. To be honest though, of all the WW products I’ve bought, I’ve found these didn’t impress me as much. Many of their parts are real serious quality and look, fit, and feel great. These, the cast is different and the just don’t feel as “confident” and solid. _________________ Mike
1964 Beetle
mukluk Samba Member
Posted: Sun Feb 23, 2020 9:41 pm Post subject: Re: Mike's 1964 1200 Deluxe |
I'm curious if a 6V car should run on the generator like a 12V car can run on the alternator even when there is no battery. A friend suggested that the 6V cars may need to have a battery in line to stay running. |
A generator equipped car can and should run without a battery, but it's not a good idea to do so for any real length of time. One should absolutely never run an alternator equipped car without a battery however. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Feb 24, 2020 5:15 am Post subject: Re: Mike's 1964 1200 Deluxe |
Ok. So I need to figure out what I'm missing.
The generator light up front is red or green? I have no red - I do have green.
Iirc, the charging circuit runs through the light, right? _________________ Mike
1964 Beetle
Posted: Mon Feb 24, 2020 6:08 am Post subject: Re: Mike's 1964 1200 Deluxe |
Nope. To be honest though, of all the WW products I’ve bought, I’ve found these didn’t impress me as much. Many of their parts are real serious quality and look, fit, and feel great. These, the cast is different and the just don’t feel as “confident” and solid. |
Thank you for the details. Saved me from buying them. |
ebenasky Samba Member
Joined: March 16, 2011 Posts: 211 Location: Helena, MT
Posted: Mon Feb 24, 2020 10:19 am Post subject: Re: Mike's 1964 1200 Deluxe |
Iirc, the charging circuit runs through the light, right? |
Gen light is Red. Oil pressure is green. _________________ "I don't fix 'em to look at 'em, I fix them to drive."
- '60 Beetle "Ruby"
- '70 Beetle "Peace" |
mukluk Samba Member
Posted: Mon Feb 24, 2020 12:41 pm Post subject: Re: Mike's 1964 1200 Deluxe |
The charging circuit doesn't normally run through the red light per se, the light illuminates only when doing a bulb check or there's a problem with the charging circuit. With the red bulb not illuminating with the green during a bulb check, make sure you don't have a bad bulb or socket, the terminal bar in the speedometer where the bulb socket contacts isn't broken or corroded, you have good continuity through the blue wire running from the bulb socket back to terminal 61 on the VR, and that you have good continuity to ground at terminal 61 of the VR with the engine not running.
The generator should work regardless of whether the warning bulb does or not. If the generator has been sitting for a while or rebuilt, you may need to polarise it. http://www.speedyjim.net/htm/gen.htm
I'd still recommend you hold off running the car until you have a battery installed. While the risk of damaging a generator setup is less than an alternator, it can still happen. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sun Mar 08, 2020 6:32 pm Post subject: Re: Mike's 1964 1200 Deluxe |
So, I put in a new battery and replaced the bulbs in the gauge. The car starts, runs, and stays running. All seems good here.
I went to install my new headlights today. The housings come with glass, but no bulbs. I’ve customarily known these as sealed beams - like my 77 bus had, excel these sit inside the housing. I ordered new bulbs from WW, but they’re literally just bulbs. No glass “sealed beam” to nest inside the housing.
Did I order the wrong bulbs? Am I supposed to order another piece here?
Can I get these at my FLAPS? _________________ Mike
1964 Beetle
mukluk Samba Member
Posted: Sun Mar 08, 2020 8:37 pm Post subject: Re: Mike's 1964 1200 Deluxe |
If you have the US spec headlamp assemblies with a non-fluted lens, they use standard H6006 7" round sealed beam bulbs available through most any FLAPS (you may have to order them). From the sound of things you ordered Euro spec H1/H3 bulbs. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sun Mar 08, 2020 9:29 pm Post subject: Re: Mike's 1964 1200 Deluxe |
Thanks.
It’s a h6006 even if I’m running 6 volt? _________________ Mike
1964 Beetle
mukluk Samba Member
Posted: Sun Mar 08, 2020 9:35 pm Post subject: Re: Mike's 1964 1200 Deluxe |
H6006 is 6v, H6024 is 12v. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed Mar 18, 2020 9:55 am Post subject: Re: Mike's 1964 1200 Deluxe |
The previous owner of my car had cut the headlight plugs at some point.
Now that the car is painted up and all fixed, I ran the wires through new rubber conduits. I don't want to use butt connectors and tape to reinstall the three-prong-plug adapters.
I notice that the wires enter the back of the plastic plug at 90 degrees, where can I get these spade connectors?
Test fitting just so I can "see the light at the end of the tunnel" - it's looking more and more like a car!
1964 Beetle
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
mukluk Samba Member
Posted: Wed Mar 18, 2020 12:13 pm Post subject: Re: Mike's 1964 1200 Deluxe |
Or you can swap over to the original style headlight plug which doesn't require wire terminal ends. Each wire connection is spring loaded, so you depress the tab, insert the stripped wire end, then release the tab; it works just like the speaker connections on a home stereo head unit.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111941165C _________________ 1960 Ragtop w/Semaphores "Inga" |
bushz Samba Member
Posted: Wed Mar 18, 2020 4:06 pm Post subject: Re: Mike's 1964 1200 Deluxe |
Beautiful car, Great job |
Posted: Thu Mar 19, 2020 3:05 pm Post subject: Re: Mike's 1964 1200 Deluxe |
mukluk wrote: |
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111941165C |
This, this is why I come here. You sir have made my day. Thank you.
bushz wrote: |
Thanks! It’s almost done. I can’t wait.
Also, I’m using clear front turn signals on my car. Would the car have come with amber bulbs or clear bulbs? I realize that local law does say I should use amber. I just haven’t found 6V amber bulbs. _________________ Mike
1964 Beetle
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Mar 19, 2020 7:38 pm Post subject: Re: Mike's 1964 1200 Deluxe |
Clear bulbs the lenses should be yellow/orange. Looks like your front turn signal housings are the earlier design.
above for 1964-69 _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Thu Mar 19, 2020 7:45 pm Post subject: Re: Mike's 1964 1200 Deluxe |
Correct. When I got my car it had the 64 style (the car is a 64)
I liked the smaller peanut style ones, and since they fit the same holes without making any changes to the fenders I figur3d it was a simple, innocent mod that was super easy to change back. So,I’m decided to run the peanuts with clear lenses.
Got my front bumper on. Took some finesse. Was tough to get the holes and all to align and the kinks set in a comfortable position.
1964 Beetle
mukluk Samba Member
Posted: Thu Mar 19, 2020 9:46 pm Post subject: Re: Mike's 1964 1200 Deluxe |
If you were running 12v they do make an amber version of an 1156 bulb, but unfortunately there's no amber 1129 bulb for sale that I can find. The only 6v amber bulbs I'm seeing are a number 63 (~4.5 watt single filament, too dim for signals) or an amber version of an 1154 dual filament bulb. The 1154's bright filament is bright enough for signals, but you'd have to come up with some way to adapt it to your car. Another possible option would be to pick up some transparent amber glass paint and paint some 1129 bulbs. _________________ 1960 Ragtop w/Semaphores "Inga" |
