findon Samba Member
Joined: August 05, 2018 Posts: 16 Location: Leicestershire
Posted: Sun Aug 05, 2018 5:57 pm Post subject: Crazy Electrics |
New here, but have decided it's time I joined a forum if we are serious about VW ownership Had our van for a year with very few problems (except a wheel nearly coming off and a dodgy alternator and carb...)
On a drive back home last night in the dark a load of weird electric issues started... I assume they could all be related, or maybe not.
1. Before darkness descended - battery indicator light came on at the start of the journey (battery was charging, so ignored - has happened before, generally goes off with high revs). Seemingly nothing else wrong.
2. On turning at a roundabout the horn suddenly started going on and off and the headlights were switching themselves to full-beam seemingly at random (it was dark by now, so we had the headlights on), weirdness continued after coming off the roundabout whilst keeping the steering column steady.
3. Noticed on pulling over that one of the rear lights was working OK but not when braking...
Spent the next few miles with loads of people flashing at us, as if our headlights were too bright...
Trundled home and keen to look at some of this tomorrow, I am guessing the relays and the wiring in the steering column should be my first port of call?
Thanks for any help in advance! |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1883 Location: N.W. Georgia
Posted: Sun Aug 05, 2018 6:08 pm Post subject: Re: Crazy Electrics |
If I experienced this sort of thing in my rig my first suspect would be the turn signal switch. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
busdaddy Samba Member
Posted: Sun Aug 05, 2018 6:22 pm Post subject: Re: Crazy Electrics |
My guesses are:
1= severely worn brushes
2= signal switch as Jeff suggests
3= bad grounds on the offending light fixture. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Aug 05, 2018 7:53 pm Post subject: Re: Crazy Electrics |
busdaddy wrote: |
My guesses are:
3= bad grounds on the offending light fixture. |
4. Regulator allowing the system to over charge
5. Defective ignition switch _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sun Aug 05, 2018 8:15 pm Post subject: Re: Crazy Electrics |
^^^ X3 ^^^
While one would logically assume that all simultaneous failures have a single cause (logically the most probable), it isn't necessarily the case. isn't it great when a half dozen things seemingly all go wonky at once. It happens. The solution is to fix them, one at a time. Diagnose, repair, go on to the next.
Persistence furthers. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
findon Samba Member
Posted: Sun Aug 05, 2018 11:50 pm Post subject: Re: Crazy Electrics |
Thanks for all the thoughts people! In short this sounds like a potentially complex mess in comparison to my previous minor fixes... not really sure where to start! |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Mon Aug 06, 2018 5:17 am Post subject: Re: Crazy Electrics |
findon wrote: |
First thing is to download a copy of your vehicle's wiring diagram:
https://www.thesamba.com/vw/archives/info/wiringt2.php
Then spend a couple hours trying to understand it. After a while, it starts to make sense, so don't give up in frustration.
Finally, pick the easiest problem to solve...like the brake light. You'll probably have that working in 10-15 minutes. But for the horn problem, search the Bay Window titles for "horn". It's the most difficult, but very doable with some research.
Good luck! Let us know how you get on. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
findon Samba Member
Posted: Wed Aug 15, 2018 4:49 am Post subject: Re: Crazy Electrics |
OK so the battery light...
Without engine on... solid reading of 12.69V... NO Battery light obviously
Ignition turned, engine off... voltage slowly dropping.. BRIGHT battery light
Ignition turned, engine on, continues to slowly drop (has always taken an initial press of the accelerator pedal to get the alternator to kick in)... BRIGHT battery light
After accelerator pressed briefly to kick alternator in, voltage starts to rise, battery light goes dim, but doesn't go off.
Then when driving the battery light appears to be directly connected to the accelerator pedal, basically going bright when pressing it down and going back to dim when releasing.
Battery tester (which also includes alternator tester) seems to think all is good and the voltage rise once the alternator has kicked in would seem to concur. Does this just sound like a wiring issue?
I guess it could all be related to the other listed problems (haven't been able to replicate the horn, headlight flicking one)... |
Zed999 Samba Member
Posted: Wed Aug 15, 2018 8:46 am Post subject: Re: Crazy Electrics |
With it charging you should measure ablut 14v.
If it's, say, 17v your regulator is broken. |
Posted: Wed Aug 15, 2018 9:13 am Post subject: Re: Crazy Electrics |
Repost this with voltage readings on both the alternator/regulator B+ and D+ terminals. Numbers will greatly aid in the creation of an accurate diagnosis of any alternator issues.
Also post model year and engine type (1 or 4).
findon wrote: |
SGKent Samba Member
Posted: Wed Aug 15, 2018 9:42 am Post subject: Re: Crazy Electrics |
First - and I mean absolutely no disrespect but the descriptions of the problems could be quick observations and not a detailed description. Here is what I mean - were the high beams actually coming on - where the relay clicked and the high beams illuminated, were the high beams coming on with the relay never clicking, or was the decision they were on simply because other oncoming cars were flashing the bus due to overly bright lights?
Let's first look at just this one symptom. How much weight was in the back of the bus? Could the rear have been low making the headlight appear high? Did the blue high beam indicator light come on? If a ground lifted could the high beams back feed where they came on without the relay engaging them? Or if a diode was blown, and AC got into the system, or the voltage regulator was acting up could low beam flaring lights be mistaken as high beams? Did anyone verify that the high beams were actually on?
As to the back - is this really a case that all happened at once, or was this an, "I better check everything else," - resulting in finding other things that were already wrong? Or did high voltage - caused by a shorted diode, or bad VR cause the bulbs to burn out?
I really think that before the OP can troubleshoot this he will need to take some very accurate checks to see what is actually happening. To start, having the alternator indicator come on implies that the system is not charging. Finding 12.69 V means nothing if the battery is still at a full charge - the correct measurement at RPM should be around 13.5 - 14.0 V, assuming that the meter is calibrated properly which many meters are way off.
I would measure the battery voltage at the posts with the ignition off. Then start the bus and see what the voltage does. Probably it wouldn't hurt to clean the battery cables first just to be sure the connections were good between the battery cable and the post. With everything off I would use a 12V inductive ammeter to see if there was any drain. That can happen if the VR is one with points and they stick. It can also happen with a bad diode in an alternator. A sharp rap on the VR box with a screwdriver handle might unstick welded points temporarily.
IMHO, once the OP looks over things more closely he should report his findings back. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
findon Samba Member
Posted: Wed Aug 15, 2018 9:47 am Post subject: Re: Crazy Electrics |
Sorry for ignorance, new to all of this!
It's a Type 1 1600 re-con engine (AD prefix), Van is a 1973
Looking at it, starting the engine doesn't cause a big jump in the value of the voltage, it just slowly ticks up... that's likely bad I assume.
Will happily grab a value from the alternator if i can work out where to do it!
Thanks for all the help so far. |
findon Samba Member
Posted: Wed Aug 15, 2018 9:51 am Post subject: Re: Crazy Electrics |
SGKent wrote: |
First - and I mean absolutely no disrespect but the descriptions of the problems could be quick observations and not a detailed description. |
Totally get it, I am completely new to this forum and maintaining this vehicle, so trying to work out what on earth I am doing. Apologies if I am not being clear enough. |
Posted: Wed Aug 15, 2018 11:12 am Post subject: Re: Crazy Electrics |
No problem. You most likely have the Bosch AL82N type alternator which has a large lug terminal (B+) for the output power and a small 1/4 inch blade terminal (D+) for the dash indicator lamp. You can take the voltage readings directly on those two terminals. Do be careful to keep your meter test leads away from the moving fan belt! If your alternator configuration is different than as described here, let us know.
Do not 'assume' that the alternator is defective, as there are external factors which can cause the same symptoms. _________________ '71 panel, now with FI
findon Samba Member
Posted: Wed Aug 15, 2018 11:22 am Post subject: Re: Crazy Electrics |
Quick engine pic
SGKent Samba Member
Posted: Wed Aug 15, 2018 11:33 am Post subject: Re: Crazy Electrics |
Quote: |
Sorry for ignorance, new to all of this! |
no need - some of us have been around electrical, automotive electrical, and electronics for a long time. It is really easy to miss a simple turn, and go down an endless rabbit hole. Starting in the back as Telford suggests is a really good place to begin this quest. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
findon Samba Member
Posted: Wed Aug 15, 2018 11:44 am Post subject: Re: Crazy Electrics |
In answer to your questions (as much as I can remember, we were a little panicked at the time as it was all pretty new to use and we had a sleeping 3 and 5yr old in the back)
1. The relay was clicking and the blue dash light was definitely coming on and the high beams were definitely switching (from memory they were only ever switching from LOW to HIGH on their own, i.e. whenever we switched back down to LOW, they would flip back up - not always instantly though, the horn was also intermittent).
2. The symptom of other cars flashing at us only started when we moved off again (the automatic switching / horn beeping problem never repeated itself during this part of the journey), so I can only assume that this was in fact just people mistaking low beam for high due to weight and us being paranoid!
3. As you say, the rear light issue may have been there for ages, it was only noticed as a result of the panic after we pulled over. |
findon Samba Member
Posted: Wed Aug 15, 2018 3:48 pm Post subject: Re: Crazy Electrics |
Will have a look at it all again tomorrow, wondering if i've just got a loose/slipping belt now I have sat and thought about the symptoms. EDIT: Seemingly not the answer, deflection on the belt seems fine, around 14mm.
findon Samba Member
Posted: Thu Aug 16, 2018 5:27 am Post subject: Re: Crazy Electrics |
BATTERY LIGHT ISSUE
So the big lug is giving out 13.4v (relative to ground) with the engine idling, but goes up to around 14.7v when accelerating.
The blade one is 15.6v at idle and goes up to over 19v when accelerating
REAR LIGHT ISSUE
You will be pleased to know I diagnosed this one: One of the little bendy metal clips that goes into the bulb holder - no idea what this is called - had snapped, so the lead was just hanging free (is there a chance that this could have been somehow touching the bodywork or something else and causing the odd headlight/horn issue?)
The bulb holder is similar to this - https://www.justkampers.com/311-953-071-reversing-...-bays.html - except that it has two contacts to the same bulb (one for brake contact and one for rear light contact), i'm sure i will find a replacement somewhere... |
Posted: Thu Aug 16, 2018 11:37 am Post subject: Re: Crazy Electrics |
findon wrote: |
BATTERY LIGHT ISSUE
The blade one is 15.6v at idle and goes up to over 19v when accelerating |
OK, unless some other power source is backfeeding the D+ terminal (highly unlikely), then the regulator module inside the alternator has gone wonky. Both alternator terminals should have the same voltage. The small D+ terminal voltage is what feeds the regulator. As it is excessively high (19 volts), it indicates that the regulator isn't controlling the alternator properly. The 14.7 volts on the big B+ lug is being limited by the battery. As the alternator is currently running 'wide open', the battery is being overcharged.
You will have to drop the engine and uninstall the alternator. The regulator is located under the front (fan end) bearing cap. It can be replaced. You should also check the alternator diodes while you have it apart. If a regulator module isn't available, or the diodes prove defective, you will have to replace the entire alternator. _________________ '71 panel, now with FI
