Flat4Tom Samba Member
Joined: March 17, 2005 Posts: 443 Location: Kingsport TN
Posted: Mon Aug 06, 2018 9:52 am Post subject: Saco hydraulic clutch Install in Ghia Issue |
Anybody ever run into this... I'm trying to install a SACO hydraulic clutch kit into my '68 Ghia race car.
The center tunnel has a depression in the area where the pedals mount to allow for the original accelerator cable that is causing a problem. When trying to bolt up the SACO mounting bracket, that depression is in the way causing the bracket to angle into the tunnel, no longer flush with the tunnel side. It will not bolt up like that.
The MC bracket appears to be too wide. If it were about 1" narrower it might bolt up. Since it's aluminum I think I can cut it down and make it work, but I wanted to check first to see if anyone has had an issue like this? It was an expensive kit and I find it hard to believe that SACO's design is this far off.
Thanks in advance.
Tom _________________ '69 Fastback - automatic - 'Flamer'
MEANIRISHMOFO wrote: |
The whole Patina thing has gone way too far. A beat up piece of shit does not have patina. It's a beat up piece of shit. That car is a good base for a restoration, Not a coat of wax. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3467 Location: Charleston, SC
Posted: Mon Aug 06, 2018 11:05 am Post subject: Re: Saco hydraulic clutch Install in Ghia Issue |
Have you considered placing a few washers behind the mounting plate to space it away from the side of the tunnel?
It's been so long since I installed and last ran my Saco hydraulic clutch, though your issue seems vaguely familiar. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Mon Dec 17, 2018 4:14 pm Post subject: Re: Saco hydraulic clutch Install in Ghia Issue |
An update to my original post...
This kit is a major pain in the ass. I ended up cutting a section of the top of the mounting bracket to clear the tunnel depression.
It takes 2 people to install this kit. I tried for hours by myself and could not do it. You need 3 hands. 1 to hold the pedal cluster up to the tunnel. 1 to hold up the mounting bracket inside the tunnel, and 1 to start a bolt. Like trying to herd cats. Pedals flopping around all the time etc... Lots of colorful metaphors flying about all laying on your chest up at the tunnel.
Anyway, got it installed and the master cyl in the tunnel was dripping fluid, so out it had to come. Buy and install a replacement. Reinstall in the tunnel, not fun. No longer dripping.
After a quart of brake fluid, I have a pedal, but it will only go fully down once, the second time you press the pedal, it only goes down 1/2 way. Bleeding the slave will allow the pedal to fully depress. Bad slave cylinder. I have a new rebuilt spare I was saving so in it goes. It seems to be working now. I have a pedal finally.
The only thing I used from this kit was the mounting bracket and the hose. Replace both cylinders that came with the kit. If I had to do over, and I may still do it, I'd just put a set of new CNC pedals in it and be done, but I'd have no leg room.
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Tue Dec 18, 2018 5:59 am Post subject: Re: Saco hydraulic clutch Install in Ghia Issue |
Was the original SACO kit new or used? I ask because you said you replaced the master cylinder AND the slave cylinder with new parts. If the kit had been new, I would have been on the phone with SACO about that. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7527 Location: Santa Cruz
Posted: Tue Dec 18, 2018 7:39 am Post subject: Re: Saco hydraulic clutch Install in Ghia Issue |
Those are also known to have a burr thrown up into the bore where they drill the transfer ports.
You might have to touch the bore with a hone to keep the burr from hurting the O-ring. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Tue Dec 18, 2018 9:02 am Post subject: Re: Saco hydraulic clutch Install in Ghia Issue |
Lo Cash John wrote: |
Was the original SACO kit new or used? I ask because you said you replaced the master cylinder AND the slave cylinder with new parts. If the kit had been new, I would have been on the phone with SACO about that. |
Yep - brand new right off the card. Normally I would have been on the phone and I still might to get replacement parts, but when you're in the heat of trying to get something to work - I didn't pick up the phone. Didn't want to wait a week or two for replacements. _________________ '69 Fastback - automatic - 'Flamer'
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3228 Location: Rapid City, SD
Posted: Tue Dec 18, 2018 10:06 am Post subject: Re: Saco hydraulic clutch Install in Ghia Issue |
I went through the same exact nightmare a few years back with this kit. I spent a few evenings rebuilding the bracket so it would fit, only to find out the master itself had a sliced o-ring. My kit was also brand new, but came with a basket case project car.
I ended up using only the braided line to the slave. I made a new laser cut bracket to mount a willwood master in its place. Much easier, quality parts, correct pushrod angles, and it still uses the original clutch hook setup.
The Saco kit is complete garbage. Poorly designed, and poorly machined.
Brian |
