bonzai272 Samba Member
Joined: January 20, 2006 Posts: 237 Location: NorCal (East Bay)
Posted: Mon Aug 06, 2018 1:11 pm Post subject: Possible alternator issue, stereo keeps shutting on/off? |
Hey all,
My 1970 Bus had been parked for about 3 weeks. It then fired right up first try and I drove it around the block. During this short drive, the fan belt broke. Not sure how old the belt was as it was on there from previous owner. Anyway, installed a new belt and took it for a longer test drive; drove great.
Next morning, fired right up and drove to a show. When I went to leave the show, battery was dead. Got it jumped and went straight home. However, on the way home, my stereo kept shutting itself off and on...weird.
Checked voltage at battery when I got home and was only like 9 volts. I charged it up to 12.5 and now it fires up just fine but my stereo is still shutting off and on.
I then checked voltage at the battery and also directly at the alternator while revving the engine, voltage would not go above 12.2.
1. Isnt it supposed to be more like 13.5V while revving?
2. Does this indicate a bad alternator?
3. Maybe the stereo is acting up because the battery voltage is too low and not being charged by the alternator?
I thought maybe the new fan belt was too loose and slipping so I tightened it up. It now has a little more than 1/4" of play but still no change in alternator output.
In case it matters, my red gen light works properly at the dash. Comes on with key on but shuts off once engine starts.
Anything else I can test or do or is this all pointing towards a bad alternator?
Thanks for any input! _________________ 1955 Beetle
timvw7476 Samba Member
Posted: Mon Aug 06, 2018 1:45 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
either a bad diode or worn brushes.(poor contact at commutator)
+VW never calibrated these buses for modern constant-draw memory presets,
so my stereo can draw down the battery in winter time if left sitting long enough. One of the hassles of driving a 20th century machine in the 21st. |
Posted: Mon Aug 06, 2018 1:51 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
Thanks for the reply. So definitely think something within the alternator itself since I'm checking voltage right at the alternator with engine revving and it's not going higher than 12.2V?
I assume the diode is within the alternator as well as the brushes?
Im trying to identify which alternator I currently have but am not seeing any decals or labels. It appears internally regulated because while I do have a regulator in the bus, there are no wires going to it. _________________ 1955 Beetle |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 777 Location: Milwaukee
Posted: Mon Aug 06, 2018 4:11 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
My Pioneer reciever cuts out at about 10 volts on the house battery (FWIW). _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
buckswilde Samba Member
Joined: June 26, 2010 Posts: 131 Location: Lexington, KY
Posted: Tue Aug 07, 2018 10:37 am Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
I'm having the same issue, only I know my alternator is bad. Haven't gotten around to replacing it and have been doing short trips on battery only. When you hit the brakes the voltage to the stereo drops enough for the stereo to cut out. That's my issue anyway. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Tue Aug 07, 2018 10:46 am Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
Was the shutoff in conjunction with ANY other electrical acts, like activating a turn signal or wiper switch? Dirty connections can cause voltage drops in those situations and mess with the head unit.
Frayed wires can also cause voltage drops under vibration or bumps, like those Bay Area roads are known for…
www.airschooled.com |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Tue Aug 07, 2018 10:47 am Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
It can just be a loose wire from alternator to battery positive, the warning light may not come on. . Had to call out roadside assistance for what turned out to be a loose clamping nut.
A loose warning light bulb may cause problems with some alternator designs.
Or worn brushes or faulty regulator. _________________ Ancient vehicles and vessels
Danwvw Samba Member
Posted: Tue Aug 07, 2018 12:44 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
Interesting I wonder if a bad battery with an internal short blew the Alternator when it broke the belt, Could be a bad Battery. Maybe the belt just knocked a wire loose or shorted it or something. Now you're saying it's an Alternator right? Not a Generator? With alternators, they have two much smaller brushes one of which wears down then they don't charge right, With a generator, the larger generator brushes wear down too then due to corrosion etc they hang up in their holders and what your experiencing happens. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Fri Aug 10, 2018 4:29 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
Thanks for all the replies.
I assumed it was the alternator because I wasnt getting an increase in voltage at the alternator while revving the engine.
I think I just wasted $150 because I just put in a brand new genuine Bosch alternator and still no change. Im still registering about 12 volts both at the alternator and at the battery, even while revving the engine, and stereo is still cutting on/off every 10 seconds or so. By the way, stereo is very basic. Just two 6x9 speakers. No amps or anything and it had been working just fine before this.
Wire connections at alternator and battery are all solid.
To answer one question posed, no the shutoff was not in conjunction with any other electrical acts (lights, horn, etc).
Any other ideas or tests I can perform? Could a bad battery cause this? I can take it to AutoZone for testing I suppose.
Thanks again. _________________ 1955 Beetle |
Posted: Fri Aug 10, 2018 5:22 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
there is the classic 'long stud' issue with rebuilt alternators,
the stud to + battery is usually so long it grounds to the backing plate
& you get rewarded with low/fluctuating volts fed into the system.
Running a nut down on the stud, hack sawing it shorter & running the nut
off to create decent lead-in threads fixes it. There should be a protective
boot over it as well at the alternator output post. |
Danwvw Samba Member
Posted: Fri Aug 10, 2018 5:41 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
12,6 volts = not charging
14 volts = charging
Alternators don't need to rev they will put out full 14 volts at 900 RPM. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Fri Aug 10, 2018 7:10 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
As the bus is a '70, I assume you have a Bosch AL82N with internal regulator. Disconnect the wire going to the alternator D+ terminal (the small 1/4" blade terminal), and connect a test light between the D+ terminal and the battery positive post. Run it. If the battery voltage goes back to normal (also measure at the alternator B+ terminal [the big lug]), then the problem is in the dash indicator or its associated wiring. If it doesn't fix it, then you got a brand new dead alternator. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Sat Aug 11, 2018 10:25 am Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
telford dorr - thanks for the help! Yes, I have an AL82N.
I performed your test and voltage went back to normal, 14.3, so I guess something is wrong with the dash indicator or wiring. Can you point me in the right direction to further troubleshoot that?
The red G light on the dash does come on with key on and goes out when engine starts. _________________ 1955 Beetle |
Danwvw Samba Member
Posted: Sat Aug 11, 2018 10:59 am Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
Below is the back of the instrument cluster and the Alt/Gen lamp is shown there on the Right side of the picture. The common plate is actually connected to the 12Volts out of the ignition switch and the lamps connect to there wires.
The screws on the dash around the instruments will allow you to pull it out to look at it. You may need to un'screw the Speedometer cable from the back of the speedometer to get enough slack. It may just need some light oil on the lamp or switch connections or fuse connections. Schematic shows it's getting power off of the 5th fuse over from the left. The blue wire from K2 ie your Alt/Gen lamp is the 61 wire and connects to the D+ on an alternator the generator voltage regulator should be removed. Some alternators (Not the AL82) and all generators use an external voltage reg that may need to be removed it's located in the engine compartment on the Right side at the back. Perhaps the 61 wire does not make it through to D+ where there is an old voltage regulator. Another thing is it may just need a new lamp in the socket, Led's are nice elsewhere as instrument lamps however this one must be an incandescent.
Posted: Sat Aug 11, 2018 12:08 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
Ive got the instrument cluster out now.
Key on, the red alternator bulb lights up. I have 12V at the common plate but not at the bulb. When I start the engine, the bulb goes out like it should and I then have 12V at the bulb where the blue 61 wire connects.
However, I dont have voltage at the other end of the blue 61 wire, which is what connects to the D+ terminal on the alternator, right? _________________ 1955 Beetle |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sat Aug 11, 2018 4:11 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
iirc, key on, engine OFF you should have 12v at the alt wire, as it is passing thru the plate on the cluster to the bulb, and from the bulb to the wire going to the alt.
when the alt "wakes up" it puts 12v to that wire and that's why it shuts off when it's charging. it comes on when the circuit is dead, and uses the generator as the ground
so, one can ASSume that if you ground the blue wire on the alt, with the key ON the {G} light should illuminate if the circuit is good. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Danwvw Samba Member
Posted: Sat Aug 11, 2018 6:41 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
skills@eurocarsplus wrote: |
so, one can ASSume that if you ground the blue wire on the alt, with the key ON the {G} light should illuminate if the circuit is good. |
2X! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sat Aug 11, 2018 7:54 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
can't believe nobody has stated the obvious: maybe the stereo didn't like the music you were playing. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Sat Aug 11, 2018 8:00 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
hazetguy wrote: |
can't believe nobody has stated the obvious: maybe the stereo didn't like the music you were playing. |
true...perhaps he's listening to scuzz twittly
Jake Raby wrote: |
Brian wrote: |
Xevin Samba Member
Posted: Sat Aug 11, 2018 11:02 pm Post subject: Re: Possible alternator issue, stereo keeps shutting on/off? |
hazetguy wrote: |
true...perhaps he's listening to scuzz twittly |
Going to have to disagree skills. Scuzz Twittly should improve horsepower and not short out a stereo. This however might be a cause of concern.
Edit; wrong video. Karen can actually sing. I mean this music should be cause of concern.
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
SGKent wrote: |
