TC/TeamEvil Samba Member
Posted: Wed Aug 08, 2018 1:49 pm Post subject: Additional rebuild help needed for 28 PCI carb |
Would anyone have a link to a good clear exploded diagram of the carb for a 1955 Beetle? We just finished up a head job and reinstall of a Buddy's engine, got it started, and am having a few issues with the engine that weren't there before. When you push the gas pedal all the way to the floor, fuel squirts upwards out of the carb rather than downwards into the carb. Is there some sort of cap on top of the emulsion tube that could have come loose and been swallowed by the engine? Could the tube itself have come loose and been swallowed as well? I know nothing about these early carbs, but figure that the fuel squirting upwards might not be "normal."
Need some help, hopefully a good diagram will explain things. Any suggestions or explanations or whatever would also be much appreciated. Thanks, TC—
billb Samba Member
Joined: October 23, 2005 Posts: 369 Location: Austin, Texas
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Aug 08, 2018 2:25 pm Post subject: Re: Exploded diagram of carb for 1955 Beetle needed. |
If the bug is not running, the fuel tends to go up as it does not have a dump tube but the fuel should not spray up with it running. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Sun Aug 12, 2018 5:17 pm Post subject: Re: Exploded diagram of carb for 1955 Beetle needed. |
Turns out that there was more wrong with the carb than just gas shooting out of the top. Once we got the fuel pump operating (it took sucking fuel up and out of pump/lines as though the pump needed to be primed in a way after sitting unused for so long) we couldn't get the fuel out of the bowl and into the carb. Pumped up and into the bowl just fine but somethin's is clogged or jammed up inside the carb and the car won't run.
Took the carb off and broke it down for a rebuild, the needle valve seemed to work OK, the pin moved up and down, but blowing through it took a LOT of pressure. The bowl filled, the valve shut off the fuel flow just fine but that was it. Not sure what to do next other than the rebuild which I really don't have any faith in, especially if the carb is clogged up enough to stop the fuel from leaving the bowl.
Blew air through all of the openings, used a fine wire on the jets and all, but still, I've never had any luck with rebuilding Solex carbs. They usually work or don't and that's despite it being so very simple.
Any tips on the rebuild would be a help, otherwise very to find an already rebuilt or operating 28 pci and try that. Getting kind of frustrating around these parts . . . |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Mon Aug 13, 2018 8:56 am Post subject: Re: Additional rebuild help needed for 28 pic carb. |
Here is a rebuilder with a solid reputation.
http://www.vintagewerks.com/ |
Danwvw Samba Member
Posted: Thu Apr 04, 2019 12:43 pm Post subject: Re: Exploded diagram of carb for 1955 Beetle needed. |
This appears to be the wrong Carburetor, I am trying find a problem with my 1960 with the 28 PIC but have yet to find a Diagram of it on the Samba that explains it's operation. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Snort Samba Member
Posted: Thu Apr 04, 2019 1:55 pm Post subject: Re: Additional rebuild help needed for 28 pic carb. |
If you are asking about the 28 PCI, here is a cutaway diagram that shows how it works.
my59 Samba Member
Joined: August 13, 2003 Posts: 3794 Location: connecting the dots
Posted: Thu Apr 04, 2019 4:41 pm Post subject: Re: Additional rebuild help needed for 28 PCI carb |
The emulsion tube is a press fit, be very careful removing it, as twisting can cause it to crack. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Danwvw Samba Member
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Fri Apr 05, 2019 8:41 am Post subject: Re: Additional rebuild help needed for 28 pic carb. |
Yep! Ed does beautiful and thorough rebuilds of those components!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
qwerty Samba Member
Posted: Fri Apr 05, 2019 9:59 am Post subject: Re: Additional rebuild help needed for 28 PCI carb |
Might find some additional info in the Solex manual here in a PDF:
http://www.oacdp.org/solex.html |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Apr 06, 2019 6:06 pm Post subject: Re: Additional rebuild help needed for 28 PCI carb |
... when I got my '55 it would be difficult to start as if no gas in the carb - rebuilt it and now the carb drains (roughly) every 10 days - so, I start it once a week and always starts right up. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
