Kanester Samba Member
Joined: April 06, 2016 Posts: 76 Location: East Dakota
Posted: Wed Aug 08, 2018 3:26 pm Post subject: 70 FB Automatic won't start in P but will in N |
Is there a park switch or a neutral safety switch somewhere?
I can get it to turn over in N but nothing in P. Not even a click.
My gear selector has P N 3 2 1. No D. Not sure that that matters but sharing.
Thank in advance! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33820 Location: Conejo Valley, CA
Posted: Wed Aug 08, 2018 3:33 pm Post subject: Re: 70 FB Automatic won't start in P but will in N |
That's how it was designed. Starting in Park didn't come until about 1972 on the Type 3. See the end of the second paragraph in the Owners Manual:
Also, the first year or two of the automatic used the 3-2-1 lettering and not D-2-1. VW changed it to be less confusing to American drivers.
1970:
1971:
Posted: Wed Aug 08, 2018 3:37 pm Post subject: Re: 70 FB Automatic won't start in P but will in N |
Thanks!
So the procedure would be stop and put the car in Park then shut off.
When you want to leave shift into neutral to start? LOL Strange design.
I am learning a bunch with this FI Automatic though. 😁
I also should have learned to look at the owners manual pages first. I did do a search before posting. Just didn't check the manual pages. |
KTPhil Samba Member
Posted: Wed Aug 08, 2018 4:01 pm Post subject: Re: 70 FB Automatic won't start in P but will in N |
To reduce stress on the transmission's internal parking pawl mechanism, when parking, I always pulled up the emergency brake handle fully, then shifted to Park, all with my foot on the brake pedal.
Same deal on starting... foot on brake, shift to N, then crank.
Drove a couple of valets nuts at fancy restaurants... even though I told them about it, they thought they knew better. I'd have to go get it myself, and I didn't tip them when they didn't listen! |
KTPhil Samba Member
Posted: Wed Aug 08, 2018 4:04 pm Post subject: Re: 70 FB Automatic won't start in P but will in N |
Make sure you have no vacuum leaks on any hose in the engine bay or under the car. Also keep the timing set dead-on. Make sure your kickdown switch is there and adjusted right. These things make it drive/shift better, and you can control shifting much better with the throttle... makes it fun to drive! |
Posted: Wed Aug 08, 2018 5:44 pm Post subject: Re: 70 FB Automatic won't start in P but will in N |
Thanks for the tips.
My kick down switch is... well... Lets just say some of it is there.
I'll replace it though.
edit: and yes always the parking brake. Forgot to add that part. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22328 Location: Kimball, Mi
Posted: Thu Aug 09, 2018 1:21 pm Post subject: Re: 70 FB Automatic won't start in P but will in N |
Kanester wrote: |
Thanks!
The main idea behind starting it in "N" was to make sure you kept the parking brake adjusted (like you would on a MT car). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5359 Location: Lefty, CA
