Phat73 Samba Member
Joined: July 05, 2018 Posts: 95 Location: Victoria BC
Posted: Thu Aug 09, 2018 6:16 pm Post subject: heater channel rebuild |
I have a question regarding heater channel repair vs replacement. In an exploded view of the VW body I see that there "seems" to be inner and outer heater channel pieces that be purchased or one can order a complete channel.
So, the front 3rd of my driver side channel has had the green weenie. Is feasible or reasonable to expect the I could order an inner and outer channel pcs and just cut and stitch the part I need or, is it easier ( more labor effective) in the long run to just replace the entire channel/
The body is coming of the pan and new Dansk floor pans will be installed.
Any suggestions or referral to threads greatly appreciated. _________________ I succeed because I fail. |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Thu Aug 09, 2018 8:54 pm Post subject: Re: heater channel rebuild |
There's the bottom plate ,the top part and then the tubing inside for the entire heater channel assembly. Patch pieces include parts of the top piece or the whole bottom plate to my knowledge. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Glenn73 Samba Member
Joined: May 30, 2011 Posts: 1190 Location: West Jordan UT
