earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri Aug 10, 2018 1:45 am Post subject: Bus reduction boxes on IRS arms? |
Has any body ever done it it? I would love to have a set for my car.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
dustymojave Samba Member
Posted: Fri Aug 10, 2018 2:26 am Post subject: Re: Bus reduction boxes on IRS arms? |
There was a time when VW Buses in South Africa had reduction boxes on IRS. Somebody on here has a pair of the boxes. It was discussed within the last couple of months or so. _________________ Richard
SoCalBajas Member
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Fri Aug 10, 2018 4:28 am Post subject: Re: Bus reduction boxes on IRS arms? |
I can't see a significant advantage over 5.38 gears
I can't see operating CV joints a foot apart from each other. maybe if you ran 3X3 trailing arms, not on stock trailing arms
all you gave to do is seal up the bearing in the gear box, machine splines on axles, attach flanges to the axles, make your own remarkably short drive axles, find CVs that work at 60 degree angles - nothing to it. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Fri Aug 10, 2018 4:40 am Post subject: Re: Bus reduction boxes on IRS arms? |
Mal evolent wrote: |
all you gave to do is seal up the bearing in the gear box, machine splines on axles, attach flanges to the axles, make your own remarkably short drive axles, find CVs that work at 60 degree angles - nothing to it. |
The advantage would be the increased ground clearance without putting extra stress/angels into the CV joints like 3x3 arms would. The main issue besides trying to adapt the swing boxes to accept IRS stub axles would be flipping the R&P in the trans so you don't end up with 4 reverse speeds. |
Brian Samba Moderator
Posted: Fri Aug 10, 2018 3:40 pm Post subject: Re: Bus reduction boxes on IRS arms? |
dustymojave wrote: |
There was a time when VW Buses in South Africa had reduction boxes on IRS. Somebody on here has a pair of the boxes. It was discussed within the last couple of months or so. |
Yea I remember oogling after that for a bit. They were reduction boxes with U-Joints. Pretty cool looking at least. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Sat Aug 11, 2018 10:15 am Post subject: Re: Bus reduction boxes on IRS arms? |
I was thinking about trying to design my own redux boxes that used circle track "quick change" gears but they have to run on a 3 1/2" center line and that would not be much of a height gain. If I still ran the water jet machine from my last job I would try to do it, how about a 3 gear system, that would give about 6" of lift and you would not have to flip the ring gear in the transaxle. _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Sat Aug 11, 2018 7:37 pm Post subject: Re: Bus reduction boxes on IRS arms? |
Have you guys seen the chain rails?...vw powered that are driven by a chain....think of a off road bike style suspension setup. ..easy to change the gearing by just changing out the sprocket...mostly used in hill climbing events. _________________ Never be a follower...Do your own thing, make it your own! |
jsturtlebuggy Samba Member
Posted: Sun Aug 12, 2018 10:03 pm Post subject: Re: Bus reduction boxes on IRS arms? |
Yes it has been done. Somewhere I have pictures of a friend's Tow'd that has a setup someone else had made. They are laid down.
Gil George (FUNCO) use to make a set of side cover for a Bug Trans that had gears like a reduction boxes for being to change final drive ratios. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Mon Aug 13, 2018 3:21 pm Post subject: Re: Bus reduction boxes on IRS arms? |
If you built a reduction box using two sprocket and a chain you would not have to flip the ring gear. I am going to think about this for awhile.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Thu Aug 16, 2018 9:06 pm Post subject: Re: Bus reduction boxes on IRS arms? |
Earthquake
Quote: |
I was thinking about trying to design my own redux boxes that used circle track "quick change" gears but they have to run on a 3 1/2" center line and that would not be much of a height gain. |
The VW Bus reduction box gears have a center line space of about 3" Less than what Quick Change gears would provide.
Mal
Quote: |
I can't see operating CV joints a foot apart from each other. maybe if you ran 3X3 trailing arms, not on stock trailing arms |
This could be done with a 002 or 091 also. But then you would want the gears to be 1:1 or inverted to reduce the final drive ratio.
Plus...The CV axle length would not be so terribly short Mal. Even with stock width trailing arms. The outboard CV location would be about the same place as it is with regular VW hubs, stub axles and arms. _________________ Richard
SoCalBajas Member
