dcaver01 Samba Member
Joined: February 23, 2009 Posts: 103 Location: Los Angeles
Posted: Fri Aug 10, 2018 6:02 pm Post subject: On the Road: Aux Battery Not Charging |
Sorry if there's already a topic that addresses this issue.
86' Vanagon Westy. Gowesty Aux battery setup.
The secondary battery is not charging as of two days ago (was working well for the past few weeks).
Reading the isolator solenoid, while running, I get 14v out of one side (front) and 10v (same as secondary battery) out of the other side (back). Checked wiring, grounds and inline fuse, all appear to be good. No "click" on the solenoid when key removed from ignition.
Recommendations on what to check/try next? My instinct is to try a new relay or solenoid. Does anyone have part numbers for those or suggestions where I could pick these up between Seattle and Vancouver BC? Read on another thread the relay is a dual 86 and likely not to be found at local autoparts stores, that true?
Thanks in advance for any help. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2321 Location: Bay area CA
Posted: Fri Aug 10, 2018 6:12 pm Post subject: Re: On the Road: Aux Battery Not Charging |
You can happily replace the Gowesty huge solenoid with an 80/90A relay (not so common, often a motorcycle starter relay) or if you're confident about the currents involved an ordinary 30/40A relay will do. Both available at any FLAPS. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Fri Aug 10, 2018 6:16 pm Post subject: Re: On the Road: Aux Battery Not Charging |
fxr wrote: |
You can happily replace the Gowesty huge solenoid with an 80/90A relay (not so common, often a motorcycle starter relay) or if you're confident about the currents involved an ordinary 30/40A relay will do. Both available at any FLAPS. |
Thanks FXR -
Do you happen to have any parts #s for these? |
fxr Samba Member
Posted: Fri Aug 10, 2018 6:18 pm Post subject: Re: On the Road: Aux Battery Not Charging |
No - they are Very Common Parts. Get into a real live shop and eyeball. _________________ Jim Crowther
Vespa GTS 300 |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6244 Location: Portland OR
Posted: Fri Aug 10, 2018 7:44 pm Post subject: Re: On the Road: Aux Battery Not Charging |
You can also bypass the relay altogether and you won’t damage anything. Wire the batteries together and disconnect if you want while parked for extended periods. All the relay does is keep you from draining the main battery by only connecting them while you’re driving. You can manually manage that process as well if in a pinch. _________________ 89 Westy 2.1 Auto |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17121 Location: Retired South Florida
Posted: Sat Aug 11, 2018 10:53 am Post subject: Re: On the Road: Aux Battery Not Charging |
You want to search "Continuous Duty Relay". They are similar looking to the old Ford remote starter relay, but are designed for continuous loads. The starter relay is not.
My Yandina died after a couple years on a road trip. I bypassed it for the rest of the trip and when I returned, decided to put in a large battery switch from the marine industry. I also upgraded the cables so the engine can start off of either battery.
When the van sits, both batteries are disconnected from the van by the switch. It's not as automatic as some prefer, but it works. _________________ ☮️ |
Posted: Sat Aug 11, 2018 12:32 pm Post subject: Re: On the Road: Aux Battery Not Charging |
Thanks for the replies.
Replaced the relay and solenoid today and still no luck.
To manually charge the aux battery, do I take the red line coming out of the relay that goes into the side (front) of the solenoid and hook that to the battery positive? |
Posted: Sat Aug 11, 2018 1:00 pm Post subject: Re: On the Road: Aux Battery Not Charging |
I can't tell you how to direct connect them without seeing your wiring, but you would want the positive battery terminals linked together. Most likely one of the wires on the GW relay is from the positive terminal of the starter battery. It should have power all the time. Hope that is of some help. _________________ ☮️ |
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Sat Aug 11, 2018 11:17 pm Post subject: Re: On the Road: Aux Battery Not Charging |
Personally, I like this unit from Blue Sea Systems. Requires 3 wires: One to each battery and a ground. Senses when voltage is high enough to charge the other battery then ties them together.
https://www.bluesea.com/products/7610/SI-ACR_Automatic_Charging_Relay_-_12_24V_DC_120A
Available from your favorite marine supply house or through Amazon. |
Posted: Sun Aug 12, 2018 6:37 pm Post subject: Re: On the Road: Aux Battery Not Charging |
Thanks MarkWard-
Figured out the right wires and am able to charge the van manually.
Dampercamper-
That's pretty awesome. I'd just eliminate the solenoid and blue activation wire with this setup? |
Posted: Mon Aug 13, 2018 2:17 pm Post subject: Re: On the Road: Aux Battery Not Charging |
re: Blue Seas 7610:
Yes, the minimum hookup for this to be functional, you already have: the two heavier wires to/from each battery, and a good solid ground connection. I'm not big on the "pure magic, fixes everything" devices but this is a simple module to install, it senses raised voltage (indicating a charge state) and ties the two batteries together while that higher voltage exists. Doesn't need ignition switch wire (but see below) or anything else. And, it works.
(In the link I included is a Tech page link, it includes a diagram and notes. Options you can add are an external LED that shows when batteries are combined, and a "Starter Isolation" connection from your solenoid wire for your engine starter to untie the batteries when you crank your engine - this prevents the Aux batt from "browning out" during engine cranking, probably not an issue in the average Westy but when used in marine applications, for instance, it could dump or damage some of the electronics in the bridge due to lower voltage. Starter Isolation also prevents trying to draw excessive current through the wires between Iso relay and battery, if smaller than, say, #4 gauge you could conceivably have an unsafe current going through those wires during ccranking.)
Fisheries Marine Supply up near Gasworks Park (in Seattle) should have these in stock, close to $100 with tax. West Marine can also supply. If you're not in a hurry you might save some change by ordering online. |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2237 Location: Olympia, Washington
Posted: Mon Aug 13, 2018 10:53 pm Post subject: Re: On the Road: Aux Battery Not Charging |
I had this same problem last year and discovered the wire going from the starting battery to the gowesty isolator was 14 gauge :-O
What I did have was a really nice heating element under the van, but there was insufficient current being transferred to charge the second battery. I upped to 8 gauge wire and everything is hunky dory now (do people really say that anymore?). _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
Posted: Thu Jun 20, 2019 4:39 pm Post subject: Re: On the Road: Aux Battery Not Charging |
Dampcamper wrote: |
re: Blue Seas 7610:
Hey DampCamper - Coming back to this after a bit. I never installed that ignition switch wire - the setup has worked fine without, keeping my secondary battery fully charged.
However, I am currently experiencing some strange electrical issues. I just had to replace both my distributor and coil for the second time in three months. Mechanics don't seem to know what is going on. They blame the ECU, could be, but not sure.
Is there any chance that not having the ignition wire for the secondary battery could distrupt/damage the ECU, the coil or the distributor? |
Posted: Thu Jun 20, 2019 4:48 pm Post subject: Re: On the Road: Aux Battery Not Charging |
Short answer is no. It is also unlikely the ECU is causing the failure. It is also odd for both the coil and the hall sender in the distributor to both fail at the same time. That said, I don't see where you said what year van and engine. _________________ ☮️ |
Posted: Thu Jun 20, 2019 5:10 pm Post subject: Re: On the Road: Aux Battery Not Charging |
MarkWard wrote: |
Short answer is no. It is also unlikely the ECU is causing the failure. It is also odd for both the coil and the hall sender in the distributor to both fail at the same time. That said, I don't see where you said what year van and engine. |
Hi MarkWard -
Thanks for the reply - it's a 1986 2.1L Manual Westy. Good to hear that it likely is NOT the lack of an ignition wire from the secondary battery causing this. |
