gregb Samba Member
Posted: Wed Feb 27, 2019 8:38 am Post subject: What is this Nefarious Notch? |
I have a engine case with this particular notch under the oil cooler. What is it for? I have also seen some cases with it filled in.
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Wed Feb 27, 2019 8:44 am Post subject: Re: What is this Nefarious Notch? |
Reduces weight and material needed in casting the case.
Dan |
gregb Samba Member
Posted: Wed Feb 27, 2019 8:50 am Post subject: Re: What is this Nefarious Notch? |
Dan Ruddock wrote: |
Dan |
Thanks Dan. I've used probably 1/2 dozen other cases in my day and never saw this 'Notch'. The one I have now is from a Super Beetle so its probably just a newer version. Case stamp starts with an "AK". |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Wed Feb 27, 2019 10:51 am Post subject: Re: What is this Nefarious Notch? |
I just cleaned a mud wasp nest out of one last week. And I'm not joking. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
gregb Samba Member
Posted: Wed Feb 27, 2019 12:10 pm Post subject: Re: What is this Nefarious Notch? |
NJ John wrote: |
I just cleaned a mud wasp nest out of one last week. And I'm not joking. |
Hillarious and I believe you. I've found all sorts of weird things when taking down a long block. I think one guy on here found a small toy fireman's hat in his fuel pump! |
nsracing Samba Member
Posted: Thu Feb 28, 2019 10:58 pm Post subject: Re: What is this Nefarious Notch? |
That hole is for inserting the silencer so the engine will be quiet. |
mark tucker Samba Member
Posted: Fri Mar 01, 2019 11:25 am Post subject: Re: What is this Nefarious Notch? |
probably just for the end of the gally so some moron dosent drill all the way through.....and make a real bypass for the cooler |
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Fri Mar 01, 2019 6:09 pm Post subject: Re: What is this Nefarious Notch? |
Dan |
its not for that , if it was added for the casting it would be to relieve shrinkage or heat propagation in that area (used in a dense area deep inside of castings) that cant cool fast enough and causes long crystal formation cycles, resulting in hot tearing. but it looks like its got a mechanical purpos, i guess the casting could be hot enough there that that area needed it but its a lot of trouble to cover for a mistake.hmm... _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
modok Samba Member
Posted: Fri Mar 01, 2019 6:40 pm Post subject: Re: What is this Nefarious Notch? |
bingo |
Posted: Sat Mar 02, 2019 11:34 am Post subject: Re: What is this Nefarious Notch? |
probably a machine location fixture mount hole. |
modok Samba Member
Posted: Sat Mar 02, 2019 1:32 pm Post subject: Re: What is this Nefarious Notch? |
They had a problem with porosity in that area.
Some cases from the late 60's, the oil passage from the cooler down between the cylinders is sleeved with an aluminum tube, but you don't see that in late 70's cases. Adding that relief might have been part of fighting that problem. |
