mikes1p Samba Member
Joined: August 08, 2018 Posts: 1 Location: Bellingham, WA
Posted: Sat Aug 11, 2018 8:51 am Post subject: 2001 Weekender MV blown transmission, what is it worth now? |
Long time lurker, first post... looking for feedback on what our Weekender might sell for? Or ideas of what to do with it
Driving down I-5 for a weekend escape and BOOM! Felt like I hit something and put the brakes on, except I didn't put the brakes on! Pull over and it won't move in any gear, won't roll in N either, smells like burning clutch/brakes, hmmm I can only assume the transmission is toast after 167,000 miles.
@shop rates I am looking at:
$6000-$11000 for the transmission (talked to three shops)
$1500-$2000 in engine work needed (cooling system and oil leaks)
$500 rear brakes
Maybe will need other things while its apart (timing chain?) too. Also it has a good couple of dents in the drivers side rear two unibody panels so its not in the best condition.
So sad day, its been a great van, lot's of memories, lot's of adventures but with 167,000 miles I am not inclined to put $12K plus into repairs. I know that an ambitious DIY'r can do a lot of this work for a lot less but I'm not the type to fix it myself anymore. Not sure I want to hassle with parting it out, just easier to sell it. I have no idea what it might be worth, what do you think?
Thanks
Mike S _________________ 2001 Eurovan MV Weekender |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Sat Aug 11, 2018 9:45 am Post subject: Re: 2001 Weekender MV blown transmission, what is it worth now? |
mikes1p wrote: |
Blown transmission, unknown cooling system repairs, timing chain, brakes, and body repairs...maybe start with the low average of MV Weekenders for sale in the classified section and subtract $8K? _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Sat Aug 11, 2018 11:16 pm Post subject: Re: 2001 Weekender MV blown transmission, what is it worth now? |
Well under 5k as described. Ping the guys here in Denver who refurb and rent out as they are a good bet.
The hard part for most sellers to stomach is the
“If you just put 12k in You will have a 25k van”
which doesn’t hunt on a non runner since you don’t know what else you need. _________________ .ssS! |
Joined: August 31, 2013 Posts: 12846 Location: North Carolina
Posted: Sun Aug 12, 2018 6:41 pm Post subject: Re: 2001 Weekender MV blown transmission, what is it worth now? |
Realistically, you’d be lucky to get $1,500 unless it’s a poptop then maybe $2,500. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
