TheDon Samba Member
Joined: July 14, 2005 Posts: 498 Location: Windermere
Posted: Sat Aug 11, 2018 2:37 pm Post subject: Intake manifold question |
I have two intake manifolds for my singleport 1500CC engine (H engine code so it’s cleaely not OG to my ‘64)
This manifold was on the engine. Big hose with a bolt on the end on the nipple to the right. This manifold has holes in the heat risers from rust
A member from the forum gave me this manifold to use. I need to clean out the heat risers. No holes from rust.
My main question is, what are the pipe nipples for? Big and small
I’m wondering if I do not need the smaller nipple if I can cut it off and weld it shut. _________________
lawn ninja wrote: |
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sat Aug 11, 2018 2:58 pm Post subject: Re: Intake manifold question |
They were used for a vacuum source for brake booster (bus), emissions (idle solenoid) and/or autostick clutch diaphragm. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
mukluk Samba Member
Posted: Sat Aug 11, 2018 2:59 pm Post subject: Re: Intake manifold question |
Big pipe = vacuum takeoff for an Autostick or the brake booster on a Bus.
Small pipe = vacuum takeoff for altitude compensator or throttle positioner. _________________ 1960 Ragtop w/Semaphores "Inga" |
TheDon Samba Member
Posted: Sun Aug 12, 2018 8:03 pm Post subject: Re: Intake manifold question |
Excellent. Thank you
I’m going to use the intake with the small pipe nipple and if I don’t need it I’ll block off the nipple with a piece of rubber hose _________________
lawn ninja wrote: |
