67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Sat Aug 11, 2018 8:09 pm Post subject: Headliner install,9hrs in,bow problems,hole-e-crap!! |
‘67 sunroof bug
SewFine one piece headliner
WWest bows 3 @ 48” each
WWest spring clips (4)
Ok, things are going really well so far!! I haven’t eaten lunch or dinner but I’m pretty happy with my progress.
I’ve hit a snag though. I ran the bows through the sleeves in the headliner and they seem to be WAAAAY too big!? I’ve searched and searched but am unable to find anyone having issues with the bows and clips!?
I am at the first bow behind the sunroof. I get on clip in and insert the end of the bow. I go to insert the other end and there is a crazy amount of flex in the bow. Who has up close pictures of how the clips are installed and the bows WITHOUT the headliner blocking the view?
Again, I have searched but I’ve had no luck.
I know there are 3 bows in a sunroof car and I see there aren’t even any clips on the last bow over the rear window.
I was pretty excited but now a bit discouraged because I had to stop☹️ |
sb001 Samba Member
Posted: Sat Aug 11, 2018 8:23 pm Post subject: Re: Headliner install,9hrs in,bow problems,hole-e-crap!! |
So you're saying the bows are too long? Can't you just trim the ends to fit? WW says on their site some cutting may be required, but any headliner bows you buy are going to be 48 inches long. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Sat Aug 11, 2018 8:42 pm Post subject: Re: Headliner install,9hrs in,bow problems,hole-e-crap!! |
Yeah, I was “assuming” that the 48” was the correct length. I found a post, of a post, of a sentence of a post....!?
The first two just behind the sunroof were 38” long and held on by spring clips...the third one was 44” and had no bends.
The first 2 had bends 2” from the ends at about a 30 degree angle.
So I guess that might be my answer. Man I read for hours and couldn’t find a damn thing! |
Karmannut Samba Member
Joined: August 05, 2007 Posts: 139 Location: North Canton Ohio
Posted: Sun Aug 12, 2018 8:27 am Post subject: Re: Headliner install,9hrs in,bow problems,hole-e-crap!! |
I just did my non sunroof headliner with kit from West Coast metric the new bows were WAY to long used my original ones the new bows were also about half as thick as the original _________________ Rupert- 64 Sea Blue Beetle with 66 Dove Lodgette tent
Bunny- 84 grey Rabbit Convertible
Pepper-18 Habanero Orange Beetle SE Premium
Air and Water do mix! |
Posted: Sun Aug 12, 2018 11:34 am Post subject: Re: Headliner install,9hrs in,bow problems,hole-e-crap!! |
Do you remember how long they were? I cut mine to 38” but I think it was a bit too short. When I pulled the headliner backwards they had a little play in them. I’m getting close to finishing it up. Overall I am pretty happy with the results-I’ve NEVER done one so I’m happy.
The door posts were tricky. I put jute behind the pinch clips but I can still see the indentation of the clips a little through the material.
The tuck I did at the top of the door posts is “ok”. I cut too wide and you can see a little overlap in the top corner.
Oh yeah.....
PINCH WELTS ARE YOUR BEST FRIEND!!!!!
They helped tremendously. |
Posted: Wed Aug 15, 2018 4:03 am Post subject: Re: Headliner install,9hrs in,bow problems,hole-e-crap!! |
Sorry i never actually measured them non sun roof car they were all same length the new ones with the kit were obviously to long and much thinner I still had my old ones just used them. Overall very happy with how everything turned out also was really worried after watching some of the utube videos some of those looked pretty bad _________________ Rupert- 64 Sea Blue Beetle with 66 Dove Lodgette tent
