flightofphx Samba Member
Posted: Mon Aug 13, 2018 8:41 am Post subject: Do I need to use a thermostat? |
I live in warm Phoenix, AZ. It gets chilly in the deep winter, but freezes are rare and usually last two or three hours in the early morning hours. I garage my 67 Fastback.
I recently bought the car and I don't think the thermostat is installed (to be honest, I haven't checked). Is it necessary to use a thermostat? I think the car will warm up fine with our ambient temps here - but wanted an opinion from the enthusiasts here. |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2105 Location: Imperial Beach CA
Posted: Mon Aug 13, 2018 8:56 am Post subject: Re: Do I need to use a thermostat? |
You'll be fine without it. I'm in San Diego and havent had one hooked up for years with no obvious issues. You will want to either remove or cut the flaps or put a screw n them to keep them in the open position for full air flow 24/7. _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Mon Aug 13, 2018 9:00 am Post subject: Re: Do I need to use a thermostat? |
I'm in Phoenix and I think you'll be ok except in winter if you are driving it to work in the early morning.
If you do that it might stall a little at stop signs and hesitate a little until it gets warmed up.
If it has flaps, make sure they are set in the open position all the time. _________________ How to Post Photos
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Mon Aug 13, 2018 12:57 pm Post subject: Re: Do I need to use a thermostat? |
It will survive without it.
It will live longer with it, especially if you have short trips. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22697 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Aug 13, 2018 2:37 pm Post subject: Re: Do I need to use a thermostat? |
Yes. That's why the engineers put one there. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
GjMan Samba Member
Joined: June 05, 2004 Posts: 822 Location: Grand Junction, CO
Posted: Mon Aug 13, 2018 4:56 pm Post subject: Re: Do I need to use a thermostat? |
Bill Fisher (Hot to Hotrod Volkwagen Engines) makes a pretty good case for retaining the thermostat even if you live in a warm area. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76761 Location: Sneaking up behind you
Posted: Mon Aug 13, 2018 4:59 pm Post subject: Re: Do I need to use a thermostat? |
Are you going to remove the thermostat in your daily driver also?
Didn't think so. Its there for a reason _________________ Glenn
Member #1009
#BlueSquare |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4848 Location: sanger ca
Posted: Mon Aug 13, 2018 5:07 pm Post subject: Re: Do I need to use a thermostat? |
VW of mexico removed them all together with the efi models. I have been doing this since 1984 and have never used a t-stat. I have however, seen the flaps stuck in the closed position and burn down engines. You cannot compare the aircooled t-stat arangement to any water cooled car, only a fool would. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Mon Aug 13, 2018 5:59 pm Post subject: Re: Do I need to use a thermostat? |
mcmscott wrote: |
VW of mexico removed them all together with the efi models. I have been doing this since 1984 and have never used a t-stat. I have however, seen the flaps stuck in the closed position and burn down engines. You cannot compare the aircooled t-stat arangement to any water cooled car, only a fool would. |
VW of Mexico likely removed them because it's the new style Mexican thermostats that fail in the closed position. I've been doing this since 1975 and have ALWAYS used a thermostat... and I couldn't care less what VWoM does or does not do... I've seen their parts.
The aircooled thermostat performs the same function as a watercooled thermostat- to get the engine temp up to spec quickly for most efficient running and fuel burning, adding life to the engine by preventing the build up of harmful byproducts.
Only a fool would leave it off. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Tue Aug 14, 2018 6:46 am Post subject: Re: Do I need to use a thermostat? |
Do yourself and engine a big favor. Inspect and see if you even have one and the associated components. Even in Phoenix Tucson Yuma I would have the engineered thermostat VW had installed. Your engine will be glad you have it. Quicker warm ups. Now in the event you happen to come to the high country like where I live it is required to have a thermostat. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Glenn Mr. 010
Posted: Tue Aug 14, 2018 7:09 am Post subject: Re: Do I need to use a thermostat? |
Tram wrote: |
mcmscott wrote: |
Only a fool would leave it off. |
What he said. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Aug 14, 2018 7:11 am Post subject: Re: Do I need to use a thermostat? |
gt1953 wrote: |
Do yourself and engine a big favor. Inspect and see if you even have one and the associated components. Even in Phoenix Tucson Yuma I would have the engineered thermostat VW had installed. Your engine will be glad you have it. Quicker warm ups. Now in the event you happen to come to the high country like where I live it is required to have a thermostat. |
Thanks for the replies and advice. Not to open a Pandora's box here - but what should the warm up time be with a working thermostat? At what temp does it open? |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Tue Aug 14, 2018 7:45 am Post subject: Re: Do I need to use a thermostat? |
Opening temp for the Type 1/Type 3 thermostat is about 65 degrees C (~150 degrees F).
It sits in the warm air dump stream under the right side cylinders. The sled tins (between heat exchangers and crankcase) need to be installed for it to work properly. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Tue Aug 14, 2018 8:36 am Post subject: Re: Do I need to use a thermostat? |
sjbartnik wrote: |
It sits in the warm air dump stream under the right side cylinders. The sled tins (between heat exchangers and crankcase) need to be installed for it to work properly. |
Fuel injection cars have their own slight variant for both Types 1 and 3. Pun intended. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
KTPhil Samba Member
Posted: Tue Aug 14, 2018 8:40 am Post subject: Re: Do I need to use a thermostat? |
My '71 fastback is garaged in a SoCal valley. When I rebuilt the motor I put the thermostat back in. Even with the warm garage, I noticed quicker warm-ups and earlier steady idle. I figure the smoother running meant it was reaching equilibrium faster, and the result would be less carbon buildup over time.
Also, the heater warmed up within about 2 minutes, instead of 5! |
Posted: Tue Aug 14, 2018 9:30 am Post subject: Re: Do I need to use a thermostat? |
Tram wrote: |
Fuel injection cars have their own slight variant for both Types 1 and 3. Pun intended. |
Yes, I only mentioned the carb spec temp because he has a '67. _________________ 1965 Volkswagen 1500 Variant S
Posted: Tue Aug 14, 2018 10:49 am Post subject: Re: Do I need to use a thermostat? |
sjbartnik wrote: |
Tram wrote: |
Yes, I only mentioned the carb spec temp because he has a '67. |
Just pointing it out. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
KTPhil Samba Member
Posted: Tue Aug 14, 2018 11:11 am Post subject: Re: Do I need to use a thermostat? |
My post a few years back on the same subject (there are many such threads):
Quote: |
Yes, most SoCal shops removed them. But it was short-sighted, though also realistic from a business standpoint.
These cars needed periodic maintenance to operate correctly. Linkages can wear, things get bent during other repairs, and of course there is an adjustment. Most owners never did these things, or wanted to pay a shop to do them. VWs were bought to have cheap transportation.
Now if you were a shop at the time, you may have done a mental calculation: If 95% of customers will neglect this maintenance, and perchance the engine develops a problem, do you think they will fess up to their own sins, or will they blame the work YOU did and badmouth your shop? On the other hand, if you take it out, it may shorten the engine life (though not provably so). But you won't get blamed. It also simplifies engine teardown and assembly, saving you labor expenses. The customer won't know better, right?
So if you want to stay in business, you probably took the easy route and removed it. No immediate harm in the warm SoCal climate. Sure, the heat riser will get plugged sooner, and warmups will take a little longer (but a choke adjustment removes most of that symptom). And you save a little labor, pocketing the money. Who cares if 50,000 miles down the road it runs hot because of manifold icing, poor mixture, and carbon buildup?
But now, 30-40 years later, when YOU are the mechanic, does that logic make sense to you? You are not a businessman with ignorant customers, you are the owner/mechanic who seeks reliability and long life, and who does the proper maintenance. |
One suggestion for the Type 3 is to file a notch into one end of the operating rod (the one that is within the cast housing, running side to side). This way you have an instant externally-visible indicator of the flap position. Unlike in a Bug, this lets you monitor its operation for sticking or a broken accordion unit.
Posted: Tue Aug 14, 2018 1:41 pm Post subject: Re: Do I need to use a thermostat? |
KTPhil wrote: |
I am very new to T3. I didn't realize there was no visual of open or closed from the outside. Thanks for the tip. I am going to get under it this weekend and take a look to see if it has a thermostat still. |
Glenn Mr. 010
Posted: Tue Aug 14, 2018 4:50 pm Post subject: Re: Do I need to use a thermostat? |
A painted line will work also. _________________ Glenn
Member #1009
#BlueSquare |
