NoDents Samba Member
Posted: Mon Aug 13, 2018 8:16 pm Post subject: Removable Rear Apron |
OK people,
Some of you have customized you engine compartment so that you can remove the rear apron to make engine removal/install easier. I'm afraid I will need to do the same. Seeing how I'm craming a Type4 motor in attached to a Porsche 915 5 speed transmission, the 2 bottom engine studs are longer that stock VW and think this will be an issue pulling the engine backwards to get it out.
I assume both rear apron peices need to come out; the section inside the engine compartment that the hood latch attaches to, and the outside rear section that has the indents for the pea-shooter tail pipes.
How did you bolt in? Extra metal to reinforce things?
So, you got pictures of how you did it?
_________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
c21darrel Samba Member
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Tue Aug 14, 2018 1:34 pm Post subject: Re: Removable Rear Apron |
djkeev wrote: |
...I stumbled upon a Ghia thread months ago detailing a 70 Ghia Convertible tub rust repair in Body and Paint...
I convinced him to return it to Ghia whereupon it has become alive once again and is now frequently added to by the OP.
OP had wondered what happened to it.
Dave |
Thread name and link or it didn't happen
Emil _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
d5626 Samba Member
Joined: December 09, 2008 Posts: 154 Location: Pomona
Posted: Wed Aug 15, 2018 2:53 pm Post subject: Re: Removable Rear Apron |
I have some photos uploaded of how I did mine. Look under my photos or search gallery under ghia coupe "removable apron" |
Posted: Wed Aug 15, 2018 3:23 pm Post subject: Re: Removable Rear Apron |
D5626, Thx. Found them.
Will be a great help. _________________ No Dents
