Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Mon Aug 13, 2018 10:25 pm Post subject: Rabbit: drop and flush diesel tank |
Car hasn’t run for 26 years, cleaning out the fuel tank. Any page telling how to remove the tank? What can I expect that needs replacing? Any advice on what to rebuild, parts I need on hand, a repair kit or procedure? _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Tue Aug 14, 2018 3:40 am Post subject: Re: Rabbit: drop and flush diesel tank |
If I remember correctly, you have to unbolt the rear axle beam pivots from the body so you can remove the exhaust & then it’s just the two straps that hold it in. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
bvolks Samba Member
Joined: April 26, 2004 Posts: 845 Location: New Brunswick, Canada
Posted: Tue Aug 14, 2018 6:23 am Post subject: Re: Rabbit: drop and flush diesel tank |
It's easier if you also unhook the rear rubber brake hoses but I have done it without taking them off. _________________ 1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1971 Doublecab project
1995 Golf CL
1974 Beetle
1978 Westfalia |
sgnimj96 Samba Member
Joined: May 14, 2015 Posts: 49 Location: Melbourne, FL
Posted: Tue Aug 14, 2018 11:08 pm Post subject: Re: Rabbit: drop and flush diesel tank |
if it's got bad rust in the tank it will tend to keep clogging the fuel system. You can buy a new tank for a mk1 rabbit pretty cheap if you need to.
https://www.autozone.com/fuel-delivery/fuel-tank/s...hText=vw4c
The pickup tanks are a different story, can't find those anywhere. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Wed Aug 15, 2018 7:46 am Post subject: Re: Rabbit: drop and flush diesel tank |
If I was going to touch the rear brake hoses, I would replace them. Once I had new hoses in hand and they appear to work, I would cut the old hoses and replace them while the axle is out.
The axle is really not hard to remove. The only issues is the hardware. If it can turn, you're ok. If not, do not break the studs off. You'll regret it. |
