Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 760 Location: Brussels - Belgium
Posted: Tue Aug 14, 2018 8:11 am Post subject: beetle gearbox in a barndoor => clutch issues |
Hello all,
anyone had an issue with fully engaging the clutch after installation of a beetle gearbox in a BD? seems like the throw is just not enough?
difference I see is the 90mm clutch-arm on the gearbox while a BD has a shorter one. guess I need to change this out to a 75mm one?
Any other updates anyone else has done to improve this?
Thanks,
Peter _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
Terry Gaudet Samba Member
Joined: March 11, 2004 Posts: 399 Location: New Brunswick, Canada
Posted: Sun Aug 19, 2018 3:40 am Post subject: Re: beetle gearbox in a barndoor => clutch issues |
Hi Peter,
Did you install and setup the Bowden tube correctly? _________________ Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab |
Posted: Mon Aug 20, 2018 12:11 am Post subject: Re: beetle gearbox in a barndoor => clutch issues |
Hello Terry,
yes, that one is renewed and has the little sag in the middle as i always do, so should be correctly set?
This evening I can spend some more time... lets see if I can check what else could be up.
Thanks!
Scotty Samba Member
Joined: July 02, 2003 Posts: 1525 Location: Northampton - Uk
Posted: Mon Aug 20, 2018 5:12 am Post subject: Re: beetle gearbox in a barndoor => clutch issues |
I didn't have any issues with 3 different beetle gearboxes in my bus, I didn't change the arm on any of them _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
Hellberg Samba Member
