oibovveroi Samba Member
Posted: Tue Aug 14, 2018 12:24 pm Post subject: Riviera lug bolt question |
I have a 71 super with riviera rims, could I swap out the lug nut setup for lug bolts? Do the longer ones fit or unsafe?
What length would I need if possible? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Aug 19, 2018 3:40 pm Post subject: Re: Riviera lug bolt question |
It is your engineering project & you have wheels to measure/test fit etc Measure and order some Mercedes style trial sizes of wheel hardware from etc.
http://www.ezaccessory.com/Ball_Seat_Type_s/39.htm _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
gt1953 Samba Member
Posted: Wed Aug 22, 2018 2:15 pm Post subject: Re: Riviera lug bolt question |
On my 72 with the wheels, I am using the lug bolts.
_________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Tue Aug 28, 2018 10:01 pm Post subject: Re: Riviera lug bolt question |
You want to replicate the thread engagement of the Original VW Hardware.
Take a standard steel wheel out of your trunk, put a standard VW lug bolt through it.
Now measure how much of the bolt protrudes from the back side of the wheel.
Now stick the same bolt through your mag wheel, if it does not protrude the same amount than you need to order a bolt that does protrude the same as the stock set up.
Lug nuts and studs work the same way kinda. The stud needs to be long enough to pass through the hub, drum, wheel, and lug nut, with about 2-3 stud threads exposed.
You also have to learn the difference between ball seat, and conical seat
Now you Know _________________ Good Luck
Al |
