Beacon Samba Member
Posted: Tue Aug 14, 2018 8:41 pm Post subject: Oil Pump vs Pulley Tin |
I’ve installed an Empi #9207 oil pump with a screw-on filter. Unfortunately, the pump’s case is so thick that I can’t mount the tin that fits around the crank pulley. The case pushes the tin out so far that it rubs against the pulley. I’ve had to grind down the pump’s case (see arrow in photo) to get the tin to fit. It works, but I’ve never known this to be needed on other cars. Any ideas what I’m doing wrong?
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Wed Aug 15, 2018 7:41 am Post subject: Re: Oil Pump vs Pulley Tin |
Beacon wrote: |
I’ve installed an Empi #9207 oil pump with a screw-on filter. Unfortunately, the pump’s case is so thick that I can’t mount the tin that fits around the crank pulley. The case pushes the tin out so far that it rubs against the pulley. I’ve had to grind down the pump’s case (see arrow in photo) to get the tin to fit. It works, but I’ve never known this to be needed on other cars. Any ideas what I’m doing wrong? |
I had to do similar trimming with a Claude's Buggies pump/filter in the early 1980s and with CB Performance pump/filter 1.5 years ago (same company). So almost 40 years and the issue remains...sad....
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Wed Aug 15, 2018 9:53 am Post subject: Re: Oil Pump vs Pulley Tin |
Or put a notch in the tin, that little cut will not hinder keeping road air out and with the tin piece it will give something for the rear tin to mate with. |
mark tucker Samba Member
Posted: Wed Aug 15, 2018 2:49 pm Post subject: Re: Oil Pump vs Pulley Tin |
rework the tin.... bend,cut whatever you are good at.I didnt have to trim my pump when I ran one of those...long long ago...also those usualy have 35mm gears and small oil passages, you must run a thinner oil...like 5-20 or 10-20 or 5-30 max. other wize the drive tang and camshaft usualy get trashed from it taking somuch power to pump the oil through the tiny passages. I did however have to trim the case or back of the pumparm thingy as it was held away from teh case by some portion of the case where the pump has a relief cut any way...just not enough on all cases. |
Cusser Samba Member
Posted: Wed Aug 15, 2018 3:44 pm Post subject: Re: Oil Pump vs Pulley Tin |
mark tucker wrote: |
I didnt have to trim my pump when I ran one of those...long long ago. |
Maybe you forgot to add that tin, or just didn't notice it - after all: you are Mark Tucker.
those usualy have 35mm gears and small oil passages, you must run a thinner oil...like 5-20 or 10-20 or 5-30 max. other wize the drive tang and camshaft usualy get trashed from it taking somuch power to pump the oil [/quote]
My two have 26mm gears. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
Posted: Fri Aug 17, 2018 4:21 pm Post subject: Re: Oil Pump vs Pulley Tin |
One thing that this type of oil filter / pump WILL DO, is to raise the temp of the engine oil especially when just driving around town. It's not as bad at freeway driving where there is turbulent air flow in the engine compartment, but it really shows itself in slow speed town driving. You have to remember, that this style of pump was designed as a kind of poor man's full flow filter / pump for off road vehicles, with open engine compartments. When it is in a sealed area, problems can arise. I have tested this (on more then one car), and seen an approximate change in oil temps in the 30 degree range.. The problem is that the filter is very close to the exhaust. To fix it you use the same basic product, but it can be used to different ways. The product is something similar to this:
https://www.summitracing.com/parts/dei-010129?seid...3HEALw_wcB
Method 1, and the easiest is to just buy the smallest quantity that you can, and just wrap the filter can itself. Method #2 is to wrap the exhaust in the area of the filter / pump.
There is nothing wrong per say with this style of pump, in fact the first one I used was from Clause's Buggies, (way before they were CB). In fact all styles of full flow systems can suffer from this problem. Any time you get an oil holding device near the exhaust system, IT WILL pick up the radiant heat from the exhaust, and raise your oil temp. All of my type 1s have heat wrap on the exhaust when ever an oil line is close to the exhaust, and in every case, the in town oil temp has decreased.. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
