westina Samba Member
Joined: October 01, 2017 Posts: 368 Location: Beacon/NY
Posted: Tue Aug 14, 2018 9:40 pm Post subject: Where to buy paint for vanagon? |
Hi. I am getting close to spray my van. Color is L90D pastel white for 84 camper. I went to NAPA today and they said the color code is old and nothing comes up. He said bring a piece from the body and he can match the color. Is that a common method? I have scuff sanded the entire body, would that interfere with matching the color. Sliding door is untouched since it was in my basement, But as you know original paint is single stage. They did respray just the outside, below the windows of the van and clear coated. So most likely 2 stage job.
Should i look into another supplier and get a color mix based on the code?
I also quoted towards $400 for a gallon of base and another hundred for clear. Since its my first complete paint job, i am not familiar with the average cost of a car paint. Are they ballpark prices?
I like the deep, wet look so aiming for base coat/clear coat but also did some welding work, panel repl. some thin layer of bondo etc so the body is not flawless. Is base coat/clear coat would be less forgiving?
I am avare there is a body/paint section but wanted to get vanagon specific info so hope moderators wouldn't mind. Thanks. |
Posted: Tue Aug 14, 2018 9:42 pm Post subject: Re: Where to buy paint for vanagon? |
Ohh BTW napa brand was Martin seymour paint. Sales rep said goes on very thick/nice coverage etc. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Tue Aug 14, 2018 9:47 pm Post subject: Re: Where to buy paint for vanagon? |
I've heard that it's important for the seller of the paint to know what kind of sprayer you are going to use. Body shops who spray gallons a day have equipment and knowledge to handle a wide spectrum of things. But I'm assuming you are doing this perhaps for the first time and probably not full on pro equipment. So let them know that and consider calling an auto body shop supply store to see what they recommend for a home guy like you with home-type equipment.
So the NAPA guy may have a great paint or price, but it may be very difficult for you to get satisfactory results through an amateur piece of gear. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 383 Location: Seattle
Posted: Tue Aug 14, 2018 10:01 pm Post subject: Re: Where to buy paint for vanagon? |
I sprayed ppg single stage with my Vanagon, PPG can tell you who their local distributor is in your area.
Great points from IdahoDoug re: making sure they know what equipment you've got, what environment you have (e.g. what temperature it will be when you shoot) to ensure good results. _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
IdahoDoug wrote: |
So the NAPA guy may have a great paint or price, but it may be very difficult for you to get satisfactory results through an amateur piece of gear. |
I feel like i am a bit clueless and i may screw up big time. I am trying to think step by step so not to go into panic mode but i see your point.
I bought this titan https://www.thesamba.com/vw/forum/viewtopic.php?t=698622&highlight=titan
unit off of craigslist. It came with one nozzle. Also got the harbour freight https://www.harborfreight.com/air-tools/paint/20-o...8843.html.
i have no compressor. My plan was, once i gather the material, i mix small amount of paint and try spraying/swapping what i have if not working. If all fails, rent or buy(really dont want it because i ll have 0 use after paint) compressor. |
Posted: Tue Aug 14, 2018 10:04 pm Post subject: Re: Where to buy paint for vanagon? |
SyncroButter wrote: |
Great points from IdahoDoug re: making sure they know what equipment you've got, what environment you have (e.g. what temperature it will be when you shoot) to ensure good results. |
Thanks i have located local PPG shop near by. I call them tomorrow or pay visit. Do you suggest them over NAPA stuff? I ll get all required stuff from same place to ensure they would work together. |
jimf909 Samba Member
Posted: Tue Aug 14, 2018 10:09 pm Post subject: Re: Where to buy paint for vanagon? |
Here's hoping that it goes well and you post pics of the progress. I shot some laquer and some Imron years ago (the Imron still looks great) but I really know very little so can't be of much help. _________________ - Jim
Abscate wrote: |
Posted: Tue Aug 14, 2018 10:11 pm Post subject: Re: Where to buy paint for vanagon? |
Also i have no paint booth. Have garage(separated from the house) which emptied already. I am thinking about cleaning/vacuming/sweeping to make it less dust prone and go commando:) |
Posted: Tue Aug 14, 2018 10:18 pm Post subject: Re: Where to buy paint for vanagon? |
jimf909 wrote: |
Here's hoping that it goes well and you post pics of the progress. I shot some laquer and some Imron years ago (the Imron still looks great) but I really know very little so can't be of much help. |
[/img]
Thank you. So far it has been an adventure. Bought this neglected vanagon from texas and towed to NY. Lots of engine work/learning and plenty of help from the forum. This much work, i mean just the body work/paint probably would total about 15k-20k if it was done pro. i simply can't afford it. Therefore i m not looking for showroom quality but something presentable off course. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6532 Location: Westfalia, Earth
Posted: Wed Aug 15, 2018 12:21 am Post subject: Re: Where to buy paint for vanagon? |
Things have probably changed since my custom paint days, but in this case I suspect PPG still blows Martin Seymour deeply into the weeds.
Recommend wetting down everything you can in your garage and/or using lots of plastic sheets covering things having dust. I would not scrimp on a paint gun and it may be possible to rent a small compressor, varies with area.
Pick the perfect day, too, maybe 75 degrees or so but ask that, too. Body Shop suppliers will have a ton more knowledge than any normal NAPA. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Wed Aug 15, 2018 5:17 am Post subject: Re: Where to buy paint for vanagon? |
I'm currently repainting my F-250 and have learned a lot from watching you tube videos.
The Harbor freight HVLP 15 dollar gun works well enough if you aren't looking for Maserati level perfection. https://www.harborfreight.com/air-tools/paint/20-fl-oz-hvlp-gravity-feed-air-spray-gun-62300.html - there are you tube videos on how to set them up for auto paint. Basically, you must take it apart and clean it real good before you use it. You'll also need to regulate the air down to 20-40 psi and add a water filter at the input to the gun. So add a regulator and filter to the list.
I think using a two stage (base coat and then clear coat) is your best bet. It will give you more time and also show imperfections which can be easily fixed before laying on the clear coat. I'd also recommend going to a local auto paint supply store to get your paint. The guys/gals behind the counter can help answer any questions. For what it will cost to rent a compressor, you can possibly buy one from HF. A small one should work but don't go too small - it should have a small storage tank. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
Posted: Wed Aug 15, 2018 7:26 am Post subject: Re: Where to buy paint for vanagon? |
Gizmoman wrote: |
I think using a two stage (base coat and then clear coat) is your best bet. It will give you more time and also show imperfections which can be easily fixed before laying on the clear coat. I'd also recommend going to a local auto paint supply store to get your paint. The guys/gals behind the counter can help answer any questions. For what it will cost to rent a compressor, you can possibly buy one from HF. A small one should work but don't go too small - it should have a small storage tank. |
Thanks, just got off the phone with local PPG store and told that they don't mix auto paints. My turbine sprayer/gun set up is still a total mystery. I ll do some dry runs and see how thats going to work. I am also keeping an eye for the 26 gallon HF compressor. If my current system fails, i may purchase one.
Still no source for the paint. I need a gallon of base and another gallon of clear and the other chemicals to do the magic. |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Wed Aug 15, 2018 7:52 am Post subject: Re: Where to buy paint for vanagon? |
The first van I ever sprayed was 74 bay tin top camper. I used napa's Martin senour paint single stage enamel. I did the body work in a small shop and rolled it out side onto a gravel driveway to spray it. The shop was so dusty after all the work that I felt wetting the driveway down right before painting was going to give better results. Did it on a calm morning. No sooner did I get it sprayed there was a bug hatch . They buffed out ha ha. The paint worked fine, put on two coats. Wet sanded and buffed it out. Almost 20 years ago. Aside from little chips in the nose from sand and pebbles it still looked good when I sold it to a samba member in jersey who drives it today. Biscay blue body and Wimbledon white roof. |
Posted: Wed Aug 15, 2018 8:25 am Post subject: Re: Where to buy paint for vanagon? |
westina wrote: |
I believe a PPG store is for house paint? You want an auto body store.
Not sure if it's close but you might try ARF Auto Body
14 Commerce Street Ext, Poughkeepsie, NY 12603
(845) 471-7200
Most will mix to the color number on the door jamb or mix to your requirements.
Also, you want good atomization to get shine. I doubt an airless will provide that but I'm no expert.
Good luck. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Posted: Wed Aug 15, 2018 8:34 am Post subject: Re: Where to buy paint for vanagon? |
Ok so i was able to locate a autobody store that carry few different paint brand including PPG. My paint code doesn't help much, they are mostly suggesting to bring along a piece from the van to match the color.
Also got in touch with sherwin williams auto paint supplier. So now i have to pick between
-napa(martin seymour)
-ppg
-sherwin williams.
They seemed to be 1:1 reducer, Therefore 2 quarts will give me a gallon of sprayable paint. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Wed Aug 15, 2018 8:37 am Post subject: Re: Where to buy paint for vanagon? |
I've been confused on the HF gun/compressor needs, but air tools and their nomenclature are "greek" to me.
The gun says moves 6cfm at 40psi and need a compressor in the 1-3 hp range.
But, the compressors at HF, even at 2.5hp, don't move 6cfm at 40psi.
Is that why you'd get a regulator- to keep the PSI lower and reduce the CFM to match the compressor's capacity?
Or, am I making this too complicated and any decent compressor with enough hp can get the job done?
Thanks, OP, sorry about the semi-hijack. I want my van painted one way or another, am considering lots of options, using the piece of sheet I cut out for my Westfauxlia conversion as a test palette as I try to figure out if going to do myself or pay somebody.
Roll-and-tip interlux actually looks pretty damn good, FWIW.
Prepares to be mocked for above statement... _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Wed Aug 15, 2018 8:50 am Post subject: Re: Where to buy paint for vanagon? |
Gizmoman wrote: |
westina wrote: |
(845) 471-7200
Good luck. |
Thanks i a have talked to them just now, they also do PPG, he said my paint code is good (L90D)-pastel white. and he can mix it. For the simplicity and piece of mind, i am leaning towards that route. I have heard good stuff about PPG auto paint. He also have 2 different tier. Expensive and budget. I ll do some research and pick one.
I have no solid feeling about my equipment. This turbine setup...You can check the link above, someone with similar setup reported good result with his paint job. Tip sizes for both clear/ base...Pressure rating, moisture...dust...I don't know man i am getting stress out a bit. Its probably because no solid ground in terms of equipment. Its just a theory/ wishfull thinking that i would plug the machine and spray away |
Posted: Wed Aug 15, 2018 8:52 am Post subject: Re: Where to buy paint for vanagon? |
mikemtnbike wrote: |
Prepares to be mocked for above statement... |
I have seen some really nice looking paint jobs done that way that have held up very well. Don't know about mixing custom colors though. |
Posted: Wed Aug 15, 2018 9:17 am Post subject: Re: Where to buy paint for vanagon? |
If the gun you have will do the job - by all means go for it. I didn't know PPG was a brand of paint.
No need to get stressed about it - just lower your expectations somewhat below a factory job.
For me it's about no obvious dents, only thin body filler where required, and consistency of color and sheen. It's all about the prep - you sound like your heading in the right direction. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
