E1 Samba Member
Joined: January 21, 2013 Posts: 6535 Location: Westfalia, Earth
Posted: Thu Aug 16, 2018 3:54 pm Post subject: Re: Where to buy paint for vanagon? |
SyncroButter wrote: |
re: sanding, you will want to sand each coat of sandable primer, then shoot a primer sealer and do not paint that. |
Hate to butt in, confirming you meant "Do not sand that…?" _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Borg Samba Member
Joined: October 18, 2012 Posts: 120 Location: Western Washington
Posted: Thu Aug 16, 2018 4:16 pm Post subject: Re: Where to buy paint for vanagon? |
I just walked in the door after doing a final 1500 wet sand and first round of mechanical buffing on my van. Reasonably happy with the results though there are a few areas where I can see RO sander scratches that I missed while it was in primer, need to get better lighting if I ever do this again.
I used about a gallon of acrylic lacquer from TCP Global. This is the same stuff I used on my 'daily driver 68 Bronco 6 years ago and it has held up well. Can't say enough about giving yourself the time to do the prep work before color, I'll be bothered by the spots I missed even though few others are likely to notice them. _________________ Steve |
E1 Samba Member
Posted: Thu Aug 16, 2018 5:12 pm Post subject: Re: Where to buy paint for vanagon? |
Edit: Wait a minute, you're not Westina, I'm soooo confused…
PROOF >>> Cool Borg, how's your headache???
I must missed earlier posts, had no idea you were painting already… DOH!
This is why I failed ridding comprension.
Sounds good, a few sand scratches are no thang, Fun stuff. Hope you're happy! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
westina Samba Member
Joined: October 01, 2017 Posts: 368 Location: Beacon/NY
Posted: Fri Aug 17, 2018 10:37 am Post subject: Re: Where to buy paint for vanagon? |
Hi folks. I have set up the titan ts50 and the HF gun and painted a piece off of the body. It came out nice. Paint is ok too, covers nice etc. It seems to be all about the settings and matching that setting to your speed and technique. Once you dialed that sweet spot between the pressure, paint output and such, result comes out ok. i ll post a pic later, don't have the cam now. With all that stuff sorted out, i am back to the van prepping. I also spoke to PPG and i was told the same thing, no wet sanding/sanding needed. Just base coat, clear coat. Unless 24 hours window is missed, than u will need to sand. Still undecided, to wetsand the whole van is about few hours job, not the end of the world. |
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 383 Location: Seattle
Posted: Fri Aug 17, 2018 10:41 am Post subject: Re: Where to buy paint for vanagon? |
E1 wrote: |
Hate to butt in, confirming you meant "Do not sand that…?" |
Sorry you are correct, meant to say you do not sand the primer sealer... you basically shoot the primer sealer as if it is the first of the color coats i.e. be prepared to move directly to shooting color as soon as the primer sealer layer is down (within the tie-in time limits of course). Thanks for pointing this out, will edit my earlier post! _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
Posted: Fri Aug 17, 2018 10:47 am Post subject: Re: Where to buy paint for vanagon? |
Borg wrote: |
I used about a gallon of acrylic lacquer from TCP Global. |
+1 to both of these
My own experience and what I have heard from others is that you can never have enough light when painting. I think of my shop as pretty well lit, but man when you see the paint in the sun for the first time all sorts of things will pop out for you. Get the best lighting you can reasonably achieve while at the same time being conscious of the fact that you do not want to be knocking over/breaking any incandescent bulbs while all of that paint vapor is in the air.
I used a gallon of single stage (i.e. paint alone, not thinned) to shoot my westy. I laid down 5 coats total to have plenty of paint on there for wet sanding, cutting and buffing. _________________ Grant
E1 Samba Member
Posted: Fri Aug 17, 2018 11:33 am Post subject: Re: Where to buy paint for vanagon? |
westina wrote: |
Westina, if me I'd still wanna talk to a painter about to sand/not to sand.
Reps and Techs are going to quote marketing which is often based to the laziest/quickest/easiest/most-profitable denominators. This is standard marketing -- older/lifer business guy here -- and I'd see no reason that sanding between wouldn't be slicker and potentially much-more durable.
Regardless of brand that's a bit on the Paint 101 vein.
Glad you're pleased so far!!! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
E1 Samba Member
Posted: Fri Aug 17, 2018 11:36 am Post subject: Re: Where to buy paint for vanagon? |
Sorry you are correct, meant to say you do not sand the primer sealer... you basically shoot the primer sealer as if it is the first of the color coats i.e. be prepared to move directly to shooting color as soon as the primer sealer layer is down (within the tie-in time limits of course). Thanks for pointing this out, will edit my earlier post! |
Thanks SB, hated to call that out but thanks for realizing the importance of why I did. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Fri Aug 17, 2018 1:53 pm Post subject: Re: Where to buy paint for vanagon? |
E1 wrote: |
westina wrote: |
Glad you're pleased so far!!! |
Yes. I have a friend at work who used to be a body shop guy. I am returning to work monday. I ll ask his opinion. Thanks |
nemobuscaptain Samba Member
