censor Samba Member
Posted: Wed Aug 15, 2018 8:50 am Post subject: '67 single cab seat belts |
My wife and I would like to add seat belts to our '67 single cab. It has a single driver's seat and a double bench on the passenger's side. Any suggestions on how and where to mount seat belts? |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Wed Aug 15, 2018 9:18 am Post subject: Re: '67 single cab seat belts |
You're in Missouri! Me too.
Okay, your '67 should have factory installed mounting points whether or not it still has waist-belts installed. It should be a matter of finding the four body mount points (outward and below/behind your seats) and seeing if mount hooks/eyeleys are still there. Those can usually be bought in the Samba.com classified ads (that look similar to the ones in this ad: https://www.thesamba.com/vw/classifieds/detail.php?id=1705410 ). I'd just order the brand new vintage looking seat belt sets from Wolfsburg West.
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Aug 15, 2018 9:37 am Post subject: Re: '67 single cab seat belts |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Aug 15, 2018 10:00 am Post subject: Re: '67 single cab seat belts |
To clarify- Even though you've got the wide(r) passenger seat- the bus is still only set up for 2 lap belts in the front. _________________
EverettB wrote: |
FU#5 |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Wed Aug 15, 2018 1:38 pm Post subject: Re: '67 single cab seat belts |
And if you would like to install 3-point belts with the shoulder strap, there is a long thread here with a lot of discussion. Title is something like "3-point seat belts in a split". _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
censor Samba Member
Posted: Thu Aug 16, 2018 8:55 am Post subject: Re: '67 single cab seat belts |
Since mine is a single cab and not a bus, I don't seem to have those same mounting locations. In fact, near the doors, I don't see any at all. There does seem to be some threaded holes behind the seats that could be used. I believe originally they were intended for a spare tire. |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Thu Aug 16, 2018 9:02 am Post subject: Re: '67 single cab seat belts |
Post some pics of your SC...that will help a LOT.
I don’t remember any threaded holes IN the spare tire well, but it seems that my old 67 benchseat bus’s seatbelts mounted very near the tire well.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Thu Aug 16, 2018 7:04 pm Post subject: Re: '67 single cab seat belts |
Most '67s I've seen don't have the large conversion plug. They just have the regular size nut. |
censor Samba Member
Posted: Fri Aug 17, 2018 5:55 am Post subject: Re: '67 single cab seat belts |
Here are some photos of the interior of the cab:
I'm considered having a tabs welded in since I don't see much already in place. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Aug 17, 2018 8:12 am Post subject: Re: '67 single cab seat belts |
Shoot one showing the lowest area next to the rear of the door. _________________ In Stereo, Where Available! |
BarryL Samba Member
Posted: Fri Aug 17, 2018 8:37 am Post subject: Re: '67 single cab seat belts |
Eric&Barb wrote: |
Shoot one showing the lowest area next to the rear of the door. |
They did: first photo but it's cocked. There's nada there. Strange as the rest of the mounting points are there. |
The holes in the tire well are the belt mounts, should be 7/16" fine thread. It should also have the outer mounts. Do both pass and drivers look the same? What is the underside in the wheel well look like? |
Z Samba Member
Posted: Fri Aug 17, 2018 10:30 am Post subject: Re: '67 single cab seat belts |
How about a shot of the passenger side by the door? Def look at the wheel well side of that outer mount area. Would be really weird to have the inners and no outers. |
