felixbobcat Samba Member
Joined: December 13, 2017 Posts: 173 Location: Los Angeles
Posted: Wed Aug 15, 2018 9:36 am Post subject: Anyone convert their van from 1.9 to 2.1 engine? |
I decided to convert my '85 Westfalia from a 1.9 to 2.1. My first plan was to go with a Subaru but budget constraints have limited me to the 2.1 engine at this time. I bought the '85 automatic without an engine and have since purchased a good used 2.1 to instal. I know there are quite a few differences in the water piping and electrical connections. The 2.1 engine came with its ecu and wiring harness.
I tried a search but nothing conclusive came up on this conversion. I'm looking for insight into what I need to to change for the wiring in particular.
Any suggestions or experience is welcome.
Thanks
Bob |
Yellow Rabbit Samba Member
Posted: Wed Aug 15, 2018 10:21 am Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Edited... I didnt catch that you currently have no engine. This swap should be pretty easy.
Last edited by Yellow Rabbit on Wed Aug 15, 2018 10:38 am; edited 1 time in total |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Wed Aug 15, 2018 10:26 am Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
The wiring is easy. Show us some photos of the empty engine compartment and the 2.1 that you have.
The cooling system is probably going to be the most work.
Mark |
E1 Samba Member
Joined: January 21, 2013 Posts: 6563 Location: Westfalia, Earth
Posted: Wed Aug 15, 2018 11:00 am Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
My plan is to do this very thing come rebuild time.
But I'm easy on engines, match revs on downshifts, keep good and clean synthetic oil in it, all meaning it may be a good, long while before needing said rebuild.
I intend to find a builder from a performance background to enable a couple tweaks:
port and polished intake and any other ways to get more air in;
a tuned exhaust to get it back out, and possibly a trick injection, computer, and whatever else do get more power without sacrificing much if any longevity.
Goal is going from 82 bhp to maybe 105-110. Anyone who's done this, I'm all ears and thus overly-susceptible to listening.
Or in lieu of all that, keep it at 1.9L as I am fascinated with Marco's turbo kit but would keep that to a 50% power benefit tops to get miles out of it. I have no desire to get much above 125 to preserve the trans and all bits between.
No hijack intended but hopefully food for thought without much trans-fat. _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
Posted: Wed Aug 15, 2018 12:10 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
I stuffed a 2.1L engine in my 83 1/2 using the 2.1L cooling system and exhaust, but keeping the Digijet FI system. May upgrade that some day as well.
If you have a complete 2.1L you should have most of the cooling system so it doesn't take much else to get it done.
Going with the 2.1L exhaust is a big improvement in reliability in my book so worth whatever it takes to do. |
E1 Samba Member
Posted: Wed Aug 15, 2018 12:55 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Wildthings wrote: |
In cooler head temps and/or better breathing from more power?
Thanks, WT. _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
Zeitgeist 13 Samba Member
Posted: Wed Aug 15, 2018 1:35 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
I just replaced the 2.1 in an '84. It uses the complete 1.9 cooling system with the complete 2.1 engine management and exhaust systems. If I were to undertake this swap, I would do it exactly the same way. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
E1 Samba Member
Posted: Wed Aug 15, 2018 1:45 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Still using the smaller, steel cooling pipe, Casey?
Our cooling system has been the Bomb for quite some time now, never gets anywhere near hot. So while I don't think the larger diameter is necessary and sure don't want one in plastic! curious what you did. _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3800 Location: VA/TN
Posted: Wed Aug 15, 2018 1:59 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
I thought the 2.1 cooling system would be more desirable as the 1.9L thermostat housings are becoming more hard to find.
E1, what kind of long coolant hoses do you have under your 1.9L? _________________ Brandon
Instagram @joannthevan |
E1 Samba Member
Posted: Wed Aug 15, 2018 2:01 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Do you mean the solid pipe?
If so, the 1" steel. The 2.1s use a plastic 1.25" replacement which I won't touch.
There's 1.25" new steel pipes out there, but in my view the prices are ridiculous.
If that's what you mean
all my rubber hoses are stock. _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
Posted: Wed Aug 15, 2018 2:28 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Ill post pictures when I get back in town. Thanks for the responses |
Posted: Wed Aug 15, 2018 3:03 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
E1 wrote: |
Our cooling system has been the Bomb for quite some time now, never gets anywhere near hot. So while I don't think the larger diameter is necessary and sure don't want one in plastic! curious what you did. |
I didn't do the initial swap, but I cleaned up the mess they made originally. It uses the factory steel pipes and all the 1.9 cooling system in the engine compartment. I swapped over the 1.9 thermostat housing and rear block off plate. All the 1.9 cooling bits bolt right up to the 2.1 engine. If you just have the 2.1 longblock, then you could run the Digijet and 1.9 cooling system on the 2.1 and there's really no big change involved. I do prefer the 2.1 exhaust system, so I'd really want to try and source one of those. I found a complete system on Craigslist for $100 and have been very pleased with the result. _________________ Casey--
y u rune klassik? |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Wed Aug 15, 2018 3:10 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
I prefer the streamlined cooling system of the 2.1L. So many leak potentials on the 1.9. |
Posted: Wed Aug 15, 2018 3:13 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
It sounds like the OP doesn't any of the 1.9 stuff left in the compartment so he has to figure out where to go from here with what he actually does have to work with. Without photos we can't really know what he still needs. Many 85 came with plastic 1 1/2" diameter long pipes and if those are what he has then it is a bigger problem than if he has 1 1/4" diameter steel pipes. Steel pipes he can cut to the shorter lengths needed for a 2.1 cooling setup. Not so simple with plastic pipes as he would be cutting off the important metal sleeved ends.
Mark |
Posted: Wed Aug 15, 2018 3:19 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
[quote="crazyvwvanman"]It sounds like the OP doesn't any of the 1.9 stuff left in the compartment so he has to figure out where to go from here with what he actually does have to work with. Without photos we can't really know what he still needs. Many 85 came with plastic 1 1/2" diameter long pipes and if those are what he has then it is a bigger problem than if he has 1 1/4" diameter steel pipes. Steel pipes he can cut to the shorter lengths needed for a 2.1 cooling setup. Not so simple with plastic pipes as he would be cutting off the important metal sleeved ends.
Mark
Just the engine was pulled. All the harnesses, ECU and plumbing are still there including the 1.9 thermostat housing. Looks like the only thing missing is the 1.9 water pump. |
Posted: Wed Aug 15, 2018 3:20 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Ill be able to post pics tomorrow when I get back in town. |
E1 Samba Member
Posted: Wed Aug 15, 2018 6:07 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Zeitgeist 13 wrote: |
I didn't do the initial swap, but I cleaned up the mess they made originally. It uses the factory steel pipes and all the 1.9 cooling system in the engine compartment. I swapped over the 1.9 thermostat housing and rear block off plate. All the 1.9 cooling bits bolt right up to the 2.1 engine. If you just have the 2.1 longblock, then you could run the Digijet and 1.9 cooling system on the 2.1 and there's really no big change involved. I do prefer the 2.1 exhaust system, so I'd really want to try and source one of those. I found a complete system on Craigslist for $100 and have been very pleased with the result. |
Appreciate the info, Thanks! _________________ 84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
Colin Chapman |
Posted: Thu Aug 16, 2018 2:25 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Photos of the engine bay and 2.1 motor
Notice no thermostat in the housing. Maybe why the 1.9 blew?
Notice some fried wires that need to be dealt with |
lucianosanchez Samba Member
Joined: May 04, 2016 Posts: 212 Location: Ventura County
Posted: Thu Aug 16, 2018 2:32 pm Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
I have an 83.5 (originally came with 1.9) which has a 2.1 engine on it. It uses the 1.9 engine management and cooling and I think the 1.9 exhaust. I didnt do the work, I purchased the van this way.
By the way, I think I know which van you got. I saw it on my local CL and really wanted to get it. It looked like a good deal. _________________ 1983.5 Aussan Brown Westfalia | 2016 to 2020
1983.5 Beige Westfalia | 2019 to Current |
Posted: Fri Aug 17, 2018 11:39 am Post subject: Re: Anyone convert their van from 1.9 to 2.1 engine? |
Turning out to be less of a good deal with all the problems I'm discovering.
Any thoughts guys on how to proceed? I'm thinking of keeping the original cooling system and Digijet.
Any advice on how to do that is appreciated. |
