Zen Bus Samba Member
Joined: May 09, 2008 Posts: 146 Location: Phoenix, AZ
Posted: Wed Aug 15, 2018 6:05 pm Post subject: Starter wiring on stand |
Hi all,
I have jumped the terminals with the screwdriver, it spins, but it doesn’t turn the engine. I’m guessing one of these other spades has to get power in order for the teeth to engage the fly wheel? I have a push button switch and I’m ready to hook up. I’ve got the fuel pump and coil hooked up just fine, just need to get the starter correct.
I looked around quite a bit and see a lot of posts on where the wires are coming from to the starter but didn’t see my query. Thanks!
FYI I have a stock 2L engine and tranny. My friend gave me this bell housing which was from an earlier bus, so I had to get a different starter that would fit (thanks Blair & Sons!), (my starter was too long with this smaller housing and I also had to take off my clutch & clutch plate). Will the starter’s teeth line up to my fly wheel?
_________________ '79 w/ Sunroof & zBed @ 10:11pm 22 of June 2009 I drove my grandpa's old bus! Thanks to The Samba and all!! 2.0; single weber carb; 78 heads & exhaust, electronic fuel pump. |
SGKent Samba Member
Posted: Wed Aug 15, 2018 6:08 pm Post subject: Re: Starter wiring on stand |
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Zen Bus wrote: |
Will the starter’s teeth line up to my fly wheel? |
Don't know, what flywheel is on it?
You need to jump between the lug with the cable on it and one of the spades, if one doesn't work try the other. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Aug 15, 2018 6:48 pm Post subject: Re: Starter wiring on stand |
Thanks both! Will post results this weekend. _________________ '79 w/ Sunroof & zBed @ 10:11pm 22 of June 2009 I drove my grandpa's old bus! Thanks to The Samba and all!! 2.0; single weber carb; 78 heads & exhaust, electronic fuel pump. |
