Type Sage_Karmann Samba Member
Posted: Thu Aug 16, 2018 10:01 am Post subject: knowledge of the engine .... what is this part? |
Hello from France
By flipping through my 1968 KG user manual - corresponding to the vintage of my Karmann, I come across the following board:
Nothing more normal ...... except that I wonder about the name and the use of the red circled piece:
which is not mentionned on the manual and is not in my engine either!
it seems connected to the intake manifold
Can you tell me more?
Have a good day
François |
Angus II Samba Member
Joined: June 01, 2016 Posts: 707 Location: Mammoth Lakes Ca. 93546
Posted: Thu Aug 16, 2018 10:05 am Post subject: Re: knowledge of the engine .... what is this part? |
Hello, It is called a one piece throttle valve positioner. There is a two part one also.
It helps in not letting the throttle return to idle, For about three seconds. It makes for better shifting and improves tail pipe emissions?
I think if you use the search, it will give you a better function diffenition. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32597 Location: Reading Pennsylvania
Posted: Fri Aug 17, 2018 5:32 am Post subject: Re: knowledge of the engine .... what is this part? |
Angus II wrote: |
Thanks for your usefull answer
I'll sleep less ignorant tonight
But not ready to install a new one
Best regards
François |
Posted: Fri Aug 17, 2018 5:39 am Post subject: Re: knowledge of the engine .... what is this part? |
djkeev wrote: |
1968 was the first year the US had any sort of emission control program.
Almost everything in the early days was a bolt on item and while it may have reduced emissions, it was often at the expense of a good running engine.
Many people, myself included, removed most of this add on crap.
I'm guessing your Ghia came from the States?
Dave |
Thanks for your answer,
Yes, my Ghia came (back) from States
She went there on aug 1967 (it's one of the first 1968 millesim)
I think that the throttle positioner has been removed by one of her us owner
Thanks again
François |
cool karmann collected Samba Member
Joined: November 23, 2008 Posts: 631 Location: Oxford, U.K.
Posted: Sat Aug 18, 2018 12:25 pm Post subject: Re: knowledge of the engine .... what is this part? |
Ooohh that's nice ! |
