Saggs Samba Member
Joined: December 23, 2003 Posts: 662 Location: Lincolnton, NC
Posted: Thu Aug 16, 2018 12:21 pm Post subject: Can someone recommend a good distributer for my T4 powered oval? |
have a 56 with a 1911cc T4 motor. Dual weber 40's, 9-1 comp ratio, mid range torque cam, stock 1.7 heads opened up for the 96mm cyls, . I have an 050 on there now set at 32degs full advance and maybe 8-10degs advance at idle. The thing just smells like it's not firing correctly or at the proper time. I don't think it should be jetted rich at all but it acts that way. I'd like to find something with some vacuum help.
Thanks _________________ "One man can make a difference...Jesus did." |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Thu Aug 16, 2018 12:34 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
The easy route is a 123 Bluetooth.
The 2018 gen 4 is nice, and easy to work with. |
mango-smoothie Samba Member
Posted: Thu Aug 16, 2018 1:14 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
i am running a SDVA (with points) & dual 44 IDF's on my 2056 T4 in my bus. runs flawlessly and gets >20MPG
on my other car (2056 T4 too) i have megajolt. lots of work to setup, but zero maintenance and quite easy to customize.
i ran pertronix in 009 and SVDA and wasn't a fan at all. went back to points and it's been great. |
Brian Samba Moderator
Posted: Thu Aug 16, 2018 1:43 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
Alstrup wrote: |
The easy route is a 123 Bluetooth. |
Real talk, is that a viable option? haven't really heard great feedback on that one yet. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Thu Aug 16, 2018 2:00 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
I was of the very same opinion until they released the 2018 USB and Bluetooth version. Now it has gotten significantly harder to find things I donīt like about it. A cool extra feature is the antitheft mode. |
Posted: Thu Aug 16, 2018 2:05 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
hmmm, cause I still have my magnaspark in the box
Are the pretty comparable? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Thu Aug 16, 2018 2:15 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
mango-smoothie wrote: |
i am running a SDVA (with points) & dual 44 IDF's on my 2056 T4 in my bus. runs flawlessly and gets >20MPG |
Are you sure the vacum can gets activated? Iīm not. I think you should look at your set up again. 20ish mpg is low for such a car, unless its a high top camper.
I agree, the P copy distributors are hit and miss. But since you bought it you could have saved yourself some and simply moved the Ignitor unit into a refurbished German SVDA and have gotten an even better result.
Iīm not affraid of the Ignitor modules. I have installed hundreds over the years and seen ONE that behaved odd and got replaced.
Another thing. 1/3 of all the problems with errattic timing is NOT the distributors fault, its the guy that install the distributorīs fault. Because most people fail to check the tolerance between the distributor drive and the distributor itself. If the tolerance is too large, which it often is due to varius reasons, the timing flickers and are all over the place. Thenthey swop the distributor to asnother one, often with another clamp too, and suddenly it runs better. Like I wrote, 1/3 of the times it is because with the other distributor and clamp the tolerance is better, so the engine runs better. That simple.
T |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
SVDA is a generic term. If it's a Bosch, what's the part number? If it's aftermarket, who's? _________________ Glenn
Member #1009
#BlueSquare |
oprn Samba Member
Joined: November 13, 2016 Posts: 12735 Location: Western Canada
Posted: Thu Aug 16, 2018 5:15 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
Saggs wrote: |
Thanks |
I am running a Pertronics III on my 1911 timed at 8* initial, 31 total with an additional 9* of vacuum advance, mild cam, 8.4/1 and 40 Webers. Runs pretty sweet but struggling to break 30 mpg(best of 29.9 so far) in a Manx copy. Not sure if the type 4 engines are just not a good fuel mileage engines or if it's the aerodynamics of the Buggy that is the limiting factor. |
Saggs Samba Member
Posted: Thu Aug 16, 2018 5:34 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
OPRN- does this petronix III have vacuum advance that will respond to the small amount of vacuum on my 40mm webers? Is something to get thru aircooled.net? I wasn't sure if these carbs would give enough vacuum signal or do I need to put in larger ports? Thanks for the replies to all! _________________ "One man can make a difference...Jesus did." |
Glenn Mr. 010
Posted: Thu Aug 16, 2018 5:44 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
oprn wrote: |
Saggs wrote: |
Thanks |
Not sure if you saw this:
https://www.thesamba.com/vw/forum/viewtopic.php?t=705258&highlight=
VDUBBIN BC wrote: |
I just installed the Pertronix Ignitor III distributor kit, coil and wires in my type 1 2110cc - 1962 beetle. There seems to be this intermittent cut out thing going on. Like it keeps shorting out? The RPM's have this short little cough at most revs. Any ideas?
https://vimeo.com/285341500
[https://vimeo.com/285341500][/vimeo] |
Member #1009
#BlueSquare |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Aug 16, 2018 6:39 pm Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
oprn wrote: |
Saggs wrote: |
Thanks |
Have you tried out any different ignition systems to compare? I've set up a German 034 SVDA on a 2.0 upright conversion for an early bay window in the past. I forget which cam ( mild for sure) but stock heads and 40 dells were used. We tried for a while to crack 30MPG, but we eventually tried taylor spiro-pro wires, a .034" plug gap, and a non-resistor rotor, paired with a Vintage Tiger CDI system, which netted a best highway MPG of 32.5, after a couple jetting changes and playing with the wideband. Interesting thing is that going with the CDI let us go richer on all jets and made a huge difference in how the engine felt. Before the CDI it was hard to push past 28MPG. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Saggs Samba Member
Posted: Fri Aug 17, 2018 3:11 am Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
I have tried an 010 and an 019 but the advance curves are not well suited for the motor. I think I need something like the above person posted with a hotter (or longer)? duration spark. If you have any product names or links to this CDI I would appreciate it. Does this take the place of my Bosch blue coil? and does it use a magnetic trigger or points? Last question and important one is, will the vacuum off my webers operate a standard vac advance dizzy? _________________ "One man can make a difference...Jesus did." |
Glenn Mr. 010
oprn Samba Member
Posted: Fri Aug 17, 2018 5:08 am Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
Saggs wrote: |
OPRN- does this petronix III have vacuum advance that will respond to the small amount of vacuum on my 40mm webers? Is something to get thru aircooled.net? I wasn't sure if these carbs would give enough vacuum signal or do I need to put in larger ports? Thanks for the replies to all! |
I have original Italian Webers and one has a vacuum port for the distributor on just one cylinder. Lots of signal to operate this distributor. I don't know if your Webers are set up like that or not.
The amount of vacuum available may actually be more related to camshaft choice and engine condition. |
oprn Samba Member
Posted: Fri Aug 17, 2018 5:20 am Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
[quote="Glenn"]Not sure if you saw this:
VDUBBIN BC wrote: |
I just installed the Pertronix Ignitor III distributor kit, coil and wires in my type 1 2110cc - 1962 beetle. There seems to be this intermittent cut out thing going on. Like it keeps shorting out? The RPM's have this short little cough at most revs. Any ideas? |
Yes I saw that before I bought mine Glen. My original Bus distributor was in poor shape and not usable so I contacted you for advice and the result was not helpful for some reason. Not normal from what I have seen on this site but perhaps I said something that offended you. Not sure but sorry for whatever it was.
Anyway in the interest of getting my engine running and being in a remote area I took a chance on the Pertronics and so far all is good. |
oprn Samba Member
Posted: Fri Aug 17, 2018 5:24 am Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
Lingwendil wrote: |
oprn wrote: |
Saggs wrote: |
Thanks |
Have you tried out any different ignition systems to compare? I've set up a German 034 SVDA on a 2.0 upright conversion for an early bay window in the past. I forget which cam ( mild for sure) but stock heads and 40 dells were used. We tried for a while to crack 30MPG, but we eventually tried taylor spiro-pro wires, a .034" plug gap, and a non-resistor rotor, paired with a Vintage Tiger CDI system, which netted a best highway MPG of 32.5, after a couple jetting changes and playing with the wideband. Interesting thing is that going with the CDI let us go richer on all jets and made a huge difference in how the engine felt. Before the CDI it was hard to push past 28MPG. |
No this is the only system I have tried so far. Interesting! |
Glenn Mr. 010
oprn wrote: |
I don't remember the conversation but I most likely said that I do not work on Type 4 engine and have no recommendation for them.
Nothing personal, i don't know why you felt that.
Just being honest. The last thing I want is to sell you a distributor that doesn't work for you.... unlike most online vendors. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Aug 17, 2018 8:07 am Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
The Winterburn is a nice sturdy classic product. But seriusly overpriced for what it is.
A good std type coil with a fast reload will do the same, and to significantly more than 6000 rpm. (A blue Bosch will struggle, possibly not make it.) Add a cheap pcd upgrade and the spark strength and quality will improve. Go MSD, Crane or what ever CDI and the spark strength, quality and duration will improve again.
T |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Fri Aug 17, 2018 9:40 am Post subject: Re: Can someone recommend a good distributer for my T4 powered oval? |
Torben, I need some advice on ignition.
My motor is a type 4 also ,with a turbo.
I run standard coil ,points and condenser. The motor is getting spark blow out at high revs and 15 psi boost. I'm looking for an easy upgrade for this. I would like to fit a more powerful coil ONLY but dont think the condensors like big coils.
I had a petronix 3 and flame thrower 3 coil but the module wnet skitso on me, so had to fit points. I still have the coil. |
