clbarton91 Samba Member
Joined: August 12, 2018 Posts: 25 Location: Clarksville, IN
Posted: Thu Aug 16, 2018 7:12 pm Post subject: Coil is getting very hot |
Finished rewiring my 1973 beetle today, previously i was having lightning issues but everything motor wise was great. Upon rewireing today i noticed the coil was getting extremely hot and im a bit worried... don’t think it was like that before.... anything to worry with there or solutions to check out? |
jamin12369 Samba Member
Posted: Thu Aug 16, 2018 7:22 pm Post subject: Re: Coil is getting very hot |
If the key was on and motor not running the points could be closed and that would cause it.
If the motor was running make sure you have resistor wire in correctly. |
Posted: Thu Aug 16, 2018 7:34 pm Post subject: Re: Coil is getting very hot |
It actually seemed to be getting hot even with the key in the off position, i had the battery disconnected for a while troubleshooting some headlight issues and when i hooked it back up for a bit and walked away, several minutes later it was still very hot |
anilv Samba Member
Posted: Thu Aug 16, 2018 7:36 pm Post subject: Re: Coil is getting very hot |
One of the signs of a failing coil is when it gets hot. I once drove an old MB for about 150 miles by drenching a cloth and wrapping it around the coil. When the cloth dried out the engine would start cutting out and that's when I knew it was time to stop and re-wet the cloth.
Anilv |
sb001 Samba Member
Posted: Thu Aug 16, 2018 8:44 pm Post subject: Re: Coil is getting very hot |
The coils in these cars get hot. Period. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Thu Aug 16, 2018 9:22 pm Post subject: Re: Coil is getting very hot |
clbarton91 wrote: |
It actually seemed to be getting hot even with the key in the off position |
The coil shouldn't get hot with the ignition off since there shouldn't be any power going to it, you should investigate further to make sure all power to the coil is cut when the ignition is switched off. _________________ 1960 Ragtop w/Semaphores "Inga" |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Fri Aug 17, 2018 11:29 am Post subject: Re: Coil is getting very hot |
mukluk wrote: |
clbarton91 wrote: |
The coil shouldn't get hot with the ignition off since there shouldn't be any power going to it, you should investigate further to make sure all power to the coil is cut when the ignition is switched off. |
Agree with mukluk. Coil gets hot from current passing thru it. With the battery hooked up but ignition switch OFF how is any voltage reaching the ignition coil??
Place a test lamp on the #15 terminal and check for voltage there while the ignition switch if OFF. If you have voltage... you have a BIG problem. Your ignition switch is not doing its job.
The reason WHY the coil gets hot?
Understand that when the points in the distributor are CLOSED this completes a circuit from the ignition switch; thru the ignition coil; thru the points to ground. If the ignition is ON current will flow thru the primary windings of the coil without end. The primary coil will start to heat up.
If the engine happened to come to a stop and the points are OPEN, there is no path to ground and there is no current flowing thru the coil. It remains cool even if the ignition switch is ON. You have around a 50/50 chance whether your engine will come to rest with the points OPEN or CLOSED.
If you know you will be working on your car for more than 5min with the ignition ON... remove the points wire from the #1 terminal of the coil. This breaks the circuit and makes sure the coil cannot ground thru the points. Just remember to reconnect the wire when you are done.
The other option is to rotate the crank pulley until the points are OPEN. It is the same as disconnecting the wire and you don't have to worry about reconnecting the wire. _________________ AshMan40
