Upgraded ignition Spark Comparison + Plasma/PCD info
Page: 1, 2, 3, 4, 5, 6  Next
jpaull
jpaull is offline
PostPosted: Thu Aug 16, 2018 10:48 pm    Post subject: Upgraded ignition Spark Comparison + Plasma/PCD info Reply with quote
If you ever wondered what the actual difference looks like, here it is.
Video link:
https://www.youtube.com/watch?v=IaLQpwMqqX0
1. In the video, first you see Bosch blue, Taylor Spiro Pro wires, resister rotor, and resister plugs on points system.
2. Then you see same system, just changing to non-resister plugs.
3. Next, you see a non resister plug fired by MSD Blaster SS, Solid core wires, non resister rotor on mag pickup distributor.
4. Next, you see the bosch blue/resister setup trying to jump a gap. Picture below:
5. Finally, you see the MSD BlasterSS, Solid core wires, Non resister rotor/mag pickup system jumping a gap. Picture below:
mark tucker
mark tucker is offline
PostPosted: Fri Aug 17, 2018 1:05 am    Post subject: Re: Bosch Blue vs MSD Spark Comparison (video included) Reply with quote
omg this cant be true!!!! your doing some kind of foto shop thingy!!! no way the msd coil can beat the borsche blew coil!!! it cant happpen!!! it just cant !!! so...can we just paint the msd coil and add a borsh sticker Shocked Rolling Eyes so how much power did your dyno show bewteen the two?
Krochus
Krochus is offline
PostPosted: Fri Aug 17, 2018 4:50 am    Post subject: Re: Bosch Blue vs MSD Spark Comparison (video included) Reply with quote
Itís not that simple. You just canít change the primary resistance of a coil that much without making accommodations inside the module or points to support it.
I would like to see this compared to a more modern COP and wasted spark coil
jpaull
jpaull is offline
PostPosted: Fri Aug 17, 2018 5:38 am    Post subject: Re: Bosch Blue vs MSD Spark Comparison (video included) Reply with quote
I edited the title, cause its not really a coil vs coil test, im showing what the difference in a upgraded ignition can make.
The point is to show a difference that people can see. And your thinking about the Blaster2(canister). I used the BlasterSS(square coil)which is a totally different coil that is more powerful.
jpaull
jpaull is offline
PostPosted: Fri Aug 17, 2018 5:43 am    Post subject: Re: Bosch Blue vs MSD Spark Comparison (video included) Reply with quote
Of course. Im showing the difference that can be acheived from a upgraded ignition system. People talk all day about one or the other, but how many people show a example?
rugblaster
rugblaster is offline
PostPosted: Fri Aug 17, 2018 6:22 am    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Back when MSD first originated a performance speed shop here had an MSD advertising display which allowed users to transition in and out of an MSD 6A box in a visual way. The results were visually and audibly dramatic. And it sold me on the technology and it has always worked for me.
We ran a variety of engines, some on methanol and one on a 25% nitro-methanol mix, which is harder to light than race gas, and never had a problem.
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.23 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '10 MB E350, '65 Plymouth Valiant convertible and a '14 Ford F150 King Ranch
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
Dale M.
Dale M. is offline
PostPosted: Fri Aug 17, 2018 6:48 am    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
I don't think anyone will deny that updating ignition is a good thing, however getting components that play nicely together and reliably seems to be issue/challenge....
Dale
ďFear The Government That Wants To Take Your Guns" - Thomas Jefferson.
ps2375
ps2375 is offline
PostPosted: Fri Aug 17, 2018 8:14 am    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Never had any issues with my HEI setup, until the 3yr old coil failed a couple of weeks ago, I put the 40yr old coil back in and it has been fine since then. And just bought a 65,000V coil on ebay...
Brian_e
Brian_e is offline
PostPosted: Fri Aug 17, 2018 9:35 am    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Good work.
It would also be neat to see a packaged ready to go high power set-up like the CB Magnaspark.
Next up..... dyno testing of each!!
Brian
jpaull
jpaull is offline
PostPosted: Fri Aug 17, 2018 10:07 am    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Brian_e wrote:
Good work.
Brian
I have a complete magnaspark distributor kit also, yes that will be next😁😁😁
mark tucker
PostPosted: Fri Aug 17, 2018 10:28 am    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
I was messen with ya and all the gotta have the blue coil guys...and for the guys that have to have the good old orange spark!!! Rolling Eyes
Maddward
Maddward is offline
PostPosted: Fri Aug 17, 2018 10:57 am    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Great visual! Thanks jpaull
1959 Baja Bug 1915cc draw through turbo
https://www.thesamba.com/vw/forum/viewtopic.php?t=701787&highlight=
jpaull
jpaull is offline
PostPosted: Fri Aug 17, 2018 11:34 am    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Glad it helps!
norris
norris is offline
PostPosted: Fri Aug 17, 2018 3:27 pm    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Very cool....thanks Jeff.....now I must buy a Blaster....not!(yet anyway)
Krochus
Krochus is offline
PostPosted: Fri Aug 17, 2018 4:02 pm    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Dale
Exactly. This is after all the coil the OP CANNOT run on his car.
You can go get a coil for $8 at the salvage yard that will put out nearly as much spark. The tricky part is getting to use it without being stranded
jpaull
jpaull is offline
PostPosted: Fri Aug 17, 2018 4:21 pm    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Krochus wrote:
Dale
Not true. I can run that coil with my magnaspark distributor, my msd distributor with msd box, or my 009 with msd box.
jpaull
jpaull is offline
PostPosted: Fri Aug 17, 2018 4:49 pm    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
You might check with Fred, I bet the winterburn can fire the Blaster or other high power coil just fine.
norris
norris is offline
PostPosted: Fri Aug 17, 2018 5:59 pm    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
I'll do that....mostly out of curiosity. No question that the spark is a LOT HOTTER
Emeraldlion
Emeraldlion is offline
PostPosted: Fri Aug 17, 2018 7:51 pm    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Let us know what you find Norris. Haven't wired up my winter burn yet, but would love to run a high power coil with my 010, or blue screamer and winter burn unit on my 2276
norris
norris is offline
PostPosted: Fri Aug 17, 2018 8:17 pm    Post subject: Re: Upgraded ignition Spark Comparison (video included) Reply with quote
Just emailed Fred. I'm thinking he'll tell me a hotter coil than my Bosch would be redundant with his CDI.....we'll see soon
Page 1 of 6
