Reset 10/‘54 speedo
Peter_KG
Peter_KG is offline
PostPosted: Fri Aug 17, 2018 4:22 am    Post subject: Reset 10/‘54 speedo Reply with quote
Hi,
I can find some topics for resetting a speedo for a later model,
however; the early gel needle ones are slightly different. The pin, with the gears, you have to remove from the odometer numbered gears, is stuck behind the pin for the speedo needle... Is it ok to remove the bracket (2 screws), with the tension spring (2nd pic)?
Thx!!
VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54
