62kellison Samba Member
Posted: Fri Aug 17, 2018 7:24 am Post subject: what size to build?. |
how can I get 140hp Minimum, but still keep it driveable for a 160 mile trip on highway once a year?.i am not looking to get 100,000 miles out of it.its fine if I have to rebuild every few years...stroker?.I am just looking for a couple of combo options I can build to give me that hp range but not burn it up on a trip to cape cod 160-200 miles away.1915? -2110?..not sure what combo can do that for me.NO turbo..high test gas is fine.for my fiberglass buggy.any insight guys?.this is going to be my winter build to keep me busy,thanks... |
slalombuggy Samba Member
Posted: Fri Aug 17, 2018 8:55 am Post subject: Re: what size to build?. |
2110, CB Panchitos, Web 86a, 9:1, 44mm carbs. 1 5/8 exhaust.
brad |
Posted: Fri Aug 17, 2018 10:47 am Post subject: Re: what size to build?. |
slalombuggy,i had really been thinking about a 2110.i just looked up that cam and heads.that sounds like a pretty strong combo!...thank u Sean. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Fri Aug 17, 2018 11:18 am Post subject: Re: what size to build?. |
I agree. 82X90.5=2110, CNC Panchito heads, Engle FK-8 cam w/1,4 rockers, dual Weber 44 IDF's, 1 5/8" exhaust 9.2-9.5 CR. A classic combo that will get 140 HP and 80K+ miles _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Fri Aug 17, 2018 3:52 pm Post subject: Re: what size to build?. |
thanks guys.from what I been reading u guys know what u are doing with these engines.i appreciate the advice and insight.I will be going with the 2110 and the Panchito head combo. Sean.. |
Glasser Samba Member
Joined: September 18, 2007 Posts: 1640 Location: Calgary Alberta Canada
Posted: Sat Sep 08, 2018 8:01 am Post subject: Re: what size to build?. |
Glasser ,yes that's sweet!!.I watched a video recently of your bug.thats what I want.alot of HP but still be a daily driver to some extent in the summer. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sat Sep 08, 2018 12:29 pm Post subject: Re: what size to build?. |
140 hp is stock with a Corvair. This is a bit more. 100,000 miles is very do-able
oprn Samba Member
Joined: November 13, 2016 Posts: 12739 Location: Western Canada
Posted: Sat Sep 08, 2018 2:18 pm Post subject: Re: what size to build?. |
They were a 2700cc 6 cylinder engine. The base model with twin carbs was 110 hp, the performance one with 4 carbs was 140 hp and the factory turbo engine with a single carter side draft carb was 180 hp. They were very much over built at about 300 pounds and yes they lasted well!
I highly doubt a punched out VW engine at that hp, even a type 4 could match their longevity.
Nice looking engine by the way, I would love to hear it run! Are you running the Corvair transaxle or a reverse rotation cam? |
Posted: Sat Sep 08, 2018 3:03 pm Post subject: Re: what size to build?. |
that's nice.believe me I thought about an adapter plate and a chevy v8 small block.lol.but I want to stick with the vw engine.i have had plenty of chevy v8,s.i do like the corvair,s tho.those motors must be getting hard to find.. |
Posted: Sat Sep 08, 2018 3:08 pm Post subject: Re: what size to build?. |
that really does look nice.i like the fan setups on those and the type 4,s.. |
Posted: Sat Sep 08, 2018 6:30 pm Post subject: Re: what size to build?. |
Its not my engine, just a pic Off The Samba
There were 1.7 million Corvairs made. Engines won't be difficult to find in our lifetime.
The largest Corvair parts business in the Universe, Clark's Corvair is in Shelburne, Mass. They remanufacture parts like piston/cylinder sets, rods, cams, etc., to better than new spec
http://www.corvair.com/user-cgi/main
The 110 and 140 are identical except the heads and carbs. 110 actually has more bottom end torque, 140 more top end hp.
https://nh.craigslist.org/pts/d/corvair-110-engine-complete/6671555103.html
https://allentown.craigslist.org/pts/d/corvair-140-heads-corvair-150/6661780623.html
Kennedy makes the best Corvair to VW adapter now.
If you decide to rebuild the engine from the crank up, put in a reverse rotation cam. If you're going to just do a top end, you'll need to flip the ring gear to the opposite side of the diff.
If you think you might go with a Corvair engine, buy this book first
http://www.corvair.com/user-cgi/search.cgi?part=C2406A |
oprn Samba Member
Posted: Sat Sep 08, 2018 7:44 pm Post subject: Re: what size to build?. |
I had a '65 Monza turbo and like a fool, sold it! They are getting pretty hard to find around here! |
Posted: Sat Sep 08, 2018 7:55 pm Post subject: Re: what size to build?. |
The guys that own them are dying faster than people are buying them
oprn Samba Member
Posted: Sat Sep 08, 2018 8:13 pm Post subject: Re: what size to build?. |
I haven't actually seen a Corvair in this part of the country in 18 or 20 years. There was a body shell about a 1/2 hour from here at one time but it's gone now too. |
Posted: Sat Sep 08, 2018 8:30 pm Post subject: Re: what size to build?. |
BL3Manx I did not know that.i am 20 mins from Shelburne!!...Hmmm ill be looking into that..thanks for the info!! Sean... |
Posted: Sun Sep 09, 2018 5:34 am Post subject: Re: what size to build?. |
there is a lot of them and I would say cheap near me in western MASS.that 1962 spyder is 2grand!.corvair engines is now a thought for another engine build.got me going now.lol..but I am in the beginning of my 2110 build!!..I COULD JUST BUY ANOTHER BUGGY!!... |
