khamul02 Samba Member
Posted: Fri Aug 17, 2018 1:57 pm Post subject: Closing inlet on fresh air heat exchanger |
If I closed off the inlet on a fresh air heat exchanger wouldn't essentially act like a stale air system? |
mukluk Samba Member
Posted: Fri Aug 17, 2018 2:35 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
No.
The stale air system had a pair of doors that would block off the exits for the air that had passed over the cylinders and heads to cool the engine, while also opening two flaps that would redirect that heated air into the cabin. Blocking off the inlets for a fresh air heater box will simply just stop the air from flowing through them -- no airflow through the heater box means no heat going to the cabin. _________________ 1960 Ragtop w/Semaphores "Inga" |
busdaddy Samba Member
Posted: Fri Aug 17, 2018 3:12 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
mukluk wrote: |
-- no airflow through the heater box means no heat going to the cabin. |
And eventually cracked or burnt out heat exchangers, air flows through them constantly, even when the heat is off, no cooling in there gets ugly. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Aug 17, 2018 4:21 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
Thanks for the replies. Is it possible to put a stale air exhaust on a 70 bug with too much trouble? I was thinking one way or the other would work ok. I'm in the south and really only need heat for a week or two during the winter. I also thought about putting some fans (similar to my 911) in the duct-work somewhere.
mukluk Samba Member
Posted: Fri Aug 17, 2018 4:31 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
If you currently have serviceable fresh air heater boxes installed, stick with a fresh air exhaust or at least leave the fresh air hoses connected to the boxes in some fashion. It'll make things easier on the rare occasion you do need to use the heater, and as pointed out above by busdaddy, it'll keep you from frying your heater boxes. Installing a true "stale air" exhaust may prove problematic if you have anything other than a 36 or 40 horse engine installed as the associated tinware and muffler are narrower to fit the engines they were intended for -- installing a stock stale air setup on an engine with a 69mm or longer stroke crank will leave gaps near the case and the muffler won't fit. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Fri Aug 17, 2018 6:09 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
I guess I should provide some backstory. This is the engine and it has no fresh air vents nor heat exchangers. So I was going to get a new muffler and exchangers. I was thinking a stale air setup. I would like to keep the engine bay as is and ad AC so not having the hoses for fresh air would make that a bit easier and help keep the engine bay clean given the addition of a compressor. Any advice is appreciated to get a little bit of heat.
mukluk Samba Member
Posted: Fri Aug 17, 2018 6:41 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
Stale air heating isn't really much of an option honestly for the reasons I gave earlier, not to mention the need to make absolutely certain no combustion gasses will leak from the cylinder/head mating area (stale air engines had copper crush seals specifically for this purpose).
If you aren't willing to install the fan shroud needed for fresh air heating then installing the other components doesn't make much sense either. I'd say your best bet to keep things looking as they are is going to be to dress warmly in the winter or wrap up in an electric blanket plugged into a power inverter. _________________ 1960 Ragtop w/Semaphores "Inga" |
bluebus86 Banned
Posted: Fri Aug 17, 2018 8:09 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
busdaddy wrote: |
mukluk wrote: |
And eventually cracked or burnt out heat exchangers, air flows through them constantly, even when the heat is off, no cooling in there gets ugly. |
THIS ABOVE. Air should always be blown thru the exchangers with engine running. This does two things.
1. keeps the exchanger manifold and its aluminum cast fin heatsink from over heating, cracking.
2. Keeps cylinder head temperature cooler, reduces heat radiated to the head above the exchanger.
Under normal operation with no cabin heat required, air blown thru the exchanger via the engine fan is dumped out under the car when heat control is off. I When heat in cabin is required, the heat control valve directs the heat to cabin, shutting off the dump to under car port.
The blown heated air is never shut off by the heater control, it is simply directed to either or both cabin or dumped under car.
Bug On, Nice and comfy! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
RichNJohn Samba Member
Joined: April 07, 2017 Posts: 91 Location: Palm Springs, CA
Posted: Sun Aug 19, 2018 3:53 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
khamul02 wrote: |
I was thinking about adding bilge blower fans like the one in the picture by splicing them into the heater tubes that run from the front of the heater boxes to the body under the back cargo area. However, since bilge gasses are (hopefully) not hot I didn't know if the fans could take the heat. the heat coming out of the floor vents in my bug is so hot I can't leave my feet next to the vents.
Has anyone sourced fans that are able to handle the heat? |
bluebus86 Banned
Posted: Sun Aug 19, 2018 4:10 pm Post subject: Re: Closing inlet on fresh air heat exchanger |
RichNJohn wrote: |
khamul02 wrote: |
Keep in mind any extra air blown into the cabin from heaters is cooling air robbed from the motor _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Aug 20, 2018 8:10 am Post subject: Re: Closing inlet on fresh air heat exchanger |
Get a stock fan shroud. Connect up the fresh air tubes. The junk aftermarket shrouds like you have, do not have the proper directional fins inside to get the cooling air in proper amounts where it needs to be blown to. _________________ In Stereo, Where Available! |
