stevo96 Samba Member
Posted: Fri Aug 17, 2018 5:24 pm Post subject: Exhaust stud broke |
Hi,
Fitting the exhaust to the engine and noticed the head is broke we’re the bolt threads in. Is there a temporary fix I can do?
SGKent Samba Member
Posted: Fri Aug 17, 2018 6:01 pm Post subject: Re: Exhaust stud broke |
pull the head, tig it and drill a new hole then tap it to put the stud in. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Aug 17, 2018 7:00 pm Post subject: Re: Exhaust stud broke |
I don’t have a tig.. I have a mig though. How about some sort of metal weld? |
Manfred58sc Samba Member
Posted: Fri Aug 17, 2018 8:16 pm Post subject: Re: Exhaust stud broke |
JB Weld will last for awhile. Get the area super clean ( carburetor cleaner,water,then alcohol ), and let it dry and set up for at least 3 days. I would then drill and tap the hole for a smaller bolt ( not a stud and nut ) and install once and only once. Best of luck _________________ Fat chick owner/operator |
SGKent Samba Member
Posted: Fri Aug 17, 2018 8:19 pm Post subject: Re: Exhaust stud broke |
aluminum requires a neutral gas like argon around the weld. I've welded cracks up in T1 heads. They are aluminum. The problem is that area gets too hot for anything but a weld. That or find another head. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat Aug 18, 2018 9:27 am Post subject: Re: Exhaust stud broke |
I can’t see any other fix than doing a top end overhaul _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Aug 18, 2018 9:39 am Post subject: Re: Exhaust stud broke |
I wonder if there's room to sneak a thin nut down in behind that from above?, you'd have to lift the tin (which might require almost as much work as prepping for a head swap) unless you can pry it up enough in place. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
