70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Sat Aug 18, 2018 8:41 am Post subject: Check transmission oil level hot or cold? |
Bentley seems to be silent on this, what is the preferred method? I am guessing cold so the oil has drained down. I guess technically it is not hot or cold since the transmission doesn’t generate heat like the engine, but do I need to let it sit for a specified length of time after driving it before I check the level? _________________ 1970 Crew Cab |
Posted: Sat Aug 18, 2018 9:57 am Post subject: Re: Check transmission oil level hot or cold? |
For a manual tranny it doesn't matter, the oil will drain down sufficiently within seconds to get an accurate reading. |
70Crew Samba Member
Posted: Sat Aug 18, 2018 11:05 am Post subject: Re: Check transmission oil level hot or cold? |
Perfect, thanks! _________________ 1970 Crew Cab |
SGKent Samba Member
Posted: Sat Aug 18, 2018 11:18 am Post subject: Re: Check transmission oil level hot or cold? |
Generally you let st least let it sit long enough for any air bubbles to get out of the oil then put a pan under the trans and remove the side filler plug/ Let any excess drain out and put the plug back in. If no gear oil drains out use your pinky finger (so you don't get it caught) and just barely touch inside the fill hole. There should be gear oil on the tip of your finger. If not then add oil until it flows out, let it sit 5 minutes until it stops then put the plug back in. It really doesn't matter whether the trans is warm or cold. If it takes much oil to top it off better find out why. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Starbucket Samba Member
Posted: Sat Aug 18, 2018 11:39 am Post subject: Re: Check transmission oil level hot or cold? |
Get it warm and change it. New oil will make your trany and you happy as it will last longer. I change mine every 10,000 miles. |
Posted: Sat Aug 18, 2018 1:02 pm Post subject: Re: Check transmission oil level hot or cold? |
Starbucket wrote: |
That is what my dad would have called a recreational oil change.
Being as I have put 8000 miles on my Bay in a month and many other times 8000-12000 in three months, doing so would be absurd. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sat Aug 18, 2018 1:25 pm Post subject: Re: Check transmission oil level hot or cold? |
Wildthings wrote: |
Starbucket wrote: |
Hahaha I love that term.
I would probably do it every three years if I didn't hit the VW service interval of 30,000 miles so often. If a car isn't driven much, then I would do it just to get the moisture and build-up out.
www.airschooled.com |
timvw7476 Samba Member
Posted: Sat Aug 18, 2018 7:59 pm Post subject: Re: Check transmission oil level hot or cold? |
Starbucket wrote: |
If you ever total your VW (God forbid)
I want first offer on your transaxle. mmkay? |
Posted: Sun Aug 19, 2018 8:50 am Post subject: Re: Check transmission oil level hot or cold? |
timvw7476 wrote: |
Starbucket wrote: |
Sorry, Granddaughter already said dibbs on the whole bus. |
Posted: Sun Aug 19, 2018 11:02 am Post subject: Re: Check transmission oil level hot or cold? |
Starbucket wrote: |
timvw7476 wrote: |
Starbucket wrote: |
Only thing worse than a VW Guy is a VW Family. : ( |
