chift Samba Member
Posted: Sat Aug 18, 2018 3:45 pm Post subject: Notches in Head where the Heat exchanges sit.. What to do? |
Hey folks,
I removed the gaskets and found some notches where the gasket sits between the head and the heat exchanger. Any suggestions/recommendations on options?
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sat Aug 18, 2018 4:21 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Anything you do short of new heads will not have a good ending _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sat Aug 18, 2018 4:26 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
How would that happen in the first place? Someone taking a chisel to the copper gasket? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
chift Samba Member
Posted: Sat Aug 18, 2018 4:28 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Not sure :/ but that does seem likely.
I was afraid of that aeromech... |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Aug 18, 2018 4:37 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Well yeah it doesn't look good, but a good cleaning wouldn't hurt to get a better look at the issue. If the edges of the valleys are raised you may be able to tease the metal back into place with the tip of a blunt drift and a hammer. Possibly even fill the remaining divot with copper wire in a similar way to how they do gold inlay on firearms.
Another option would be to mill (maybe even Dremel) the entire surface down a little, but that's not really a driveway job without some sort of special jig to guide the tool and control the depth of the cut. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
chift Samba Member
Posted: Sat Aug 18, 2018 4:43 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Thanks busdaddy. I'll clean it up in the coming days and get better pictures. Assuming I can edges the valleys in and fill in the gaps, how do I know it'll be good? |
Posted: Sat Aug 18, 2018 4:44 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Those heads look to be past their life limit. To do a half ass patch is just delaying the inevitable _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sat Aug 18, 2018 4:49 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
chift wrote: |
Hey folks,
I removed the gaskets and found some notches where the gasket sits between the head and the heat exchanger. Any suggestions/recommendations on options? |
ok....if you removed the gaskets, you did the damage....it's pretty clear that the nice shiny diggers are fresh....clearly this wasn't done in the past.
what did you remove them with, an ax?
you may get lucky, but they seem pretty dam deep....try to gingerly wire wheel the surface with a dremel. that will give you a better idea of the damage....but the V shaped nature of the damage will for sure lead to burnt out gaskets as the hot gasses will have a nice easy path to eat them new gaskets alive _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
chift Samba Member
Posted: Sat Aug 18, 2018 5:10 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Thanks Skills/everyone.
I'll write brush clean them and see where we're at. |
Posted: Sat Aug 18, 2018 5:35 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Doesn't look to me like the gaskets were sealing well previously. Making sure the flanges are flat and aligned with each other would help the situation overall as would annealing the gaskets prior to installation. Since the V-marks are small, it is possible that some kind of exhaust repair goop might actually work, don't have personally experience with these products:
https://www.amazon.com/s/?ie=UTF8&keywords=exh...omen_e_p38 |
Posted: Sat Aug 18, 2018 6:43 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
aeromech wrote: |
Those heads look to be past their life limit. To do a half ass patch is just delaying the inevitable |
Agreed, but a patch could buy some time while new the head fund cookie jar fills up, and we all know once it's apart for heads there's always a few more things that need doing, start putting aside the $. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sun Aug 19, 2018 7:16 am Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
I could be wrong, but it almost looks like to me that there is still a gasket in each hole.
Perhaps a previous previous owner used some kind of sealant in there which caused them to stick, and the previous owner installed new copper rings right under the old ones, and they didn't seal to each other? _________________ Dave Cook
1973 Wild Westerner
My Thing |
HAM Inc Samba Member
Joined: May 09, 2011 Posts: 161 Location: Watkinsville,GA
Posted: Sun Aug 19, 2018 8:20 am Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
There are definitely gaskets in the last the two photos. I have no idea how to get them out without doing major damage without removing the heads. _________________ Len Hoffman
Hoffman Automotive Machine Inc.
www.hamheads.com |
Posted: Sun Aug 19, 2018 8:50 am Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
A pocket screwdriver with a sharpened tip bent at the right angle works well. Thin the blade way down to about half its original thickness and then take the edge off the blade with a fine file or stone so that it doesn't tend dig into the metal. |
Posted: Sun Aug 19, 2018 9:31 am Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Sometimes you can get the tip of one of these under the edge enough to get it loose, just have to find the right size:
Слава Україні! |
SGKent Samba Member
Posted: Sun Aug 19, 2018 10:17 am Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
why did you pull the exhaust off to begin witfh? It is material to the answer. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
chift Samba Member
Posted: Sun Aug 19, 2018 3:53 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
vwwestyman/HAM Inc... it doesn't feel like there's another gasket.
SGKent: the Bus is a 78 and had all rusted out heater boxes/manifold that were beyond repair, so I've been collecting parts to convert it to a 72-74 system following ratwells page: http://www.ratwell.com/technical/Exhaust.html
I think I'm going to go with BusDaddy's advice and hope they last while I save some $ for new heads. |
Posted: Sun Aug 19, 2018 7:01 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
chift wrote: |
It probably doesn't feel like a gasket, given the way it's crusted into the head, but the the copper color gives it away.
It's probably going to be tough to get that out without digging underneath it. Seen a blue-million just like it. _________________ Len Hoffman
www.hamheads.com |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3848 Location: San Jose, CA
Posted: Sun Aug 19, 2018 9:44 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
Your first pic:
That looks like a gasket. Unless the gasket seat was machined with two steps in it: look at the OUTBOARD edge of the groove from about the 4 o'clock position to the 10 o'clock position, that appears to be a step-down, revealing the actual seat below; Then, at the INBOARD edge, at about the 11 o'clock position, you can see what appears to be the inner edge of the gasket seat. Those reveals are evident because the gaskets are an imperfect fit in the seat, and there's always some shift due to inherent slop. I'm with Len...heck, they're probably all gaskets.
(Edited for clarity.)
Hoody Samba Member
Posted: Sun Aug 19, 2018 10:28 pm Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? |
I bet someone put red loctite under them. As Len suggested you should pull the heads. Drop the engine and do it correctly the first time. If you mangle the heads trying to pry them out you are going to have to pull it anyway. And the Bus will be sitting while you save up for a set of heads. |
