Notches in Head where the Heat exchanges sit.. What to do?
Page: Previous  1, 2
Wildthings
Wildthings is offline
PostPosted: Sun Aug 19, 2018 10:59 pm    Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? Reply with quote
Hoody wrote:
I bet someone put red loctite under them. As Len suggested you should pull the heads. Drop the engine and do it correctly the first time. If you mangle the heads trying to pry them out you are going to have to pull it anyway. And the Bus will be sitting while you save up for a set of heads.
People pull these all the time without mangling the heads. While you have to use care, it isn't all that hard to do.
chift
chift is offline
PostPosted: Mon Aug 20, 2018 6:27 am    Post subject: Re: Notches in Head where the Heat exchanges sit.. What to do? Reply with quote
Busstom wrote:
Your first pic:
chift wrote:
That looks like a gasket. Unless the gasket seat was machined with two steps in it: look at the OUTBOARD edge of the groove from about the 4 o'clock position to the 10 o'clock position, that appears to be a step-down, revealing the actual seat below; Then, at the INBOARD edge, at about the 11 o'clock position, you can see what appears to be the inner edge of the gasket seat. Those reveals are evident because the gaskets are an imperfect fit in the seat, and there's always some shift due to inherent slop. I'm with Len...heck, they're probably all gaskets.
(Edited for clarity.)
Hmmm... I'm going to clean it up tomorrow/Wednesday but I see what you're saying.
Page: Previous  1, 2
Page 2 of 2
