clbarton91 Samba Member
Joined: August 12, 2018 Posts: 25 Location: Clarksville, IN
Posted: Sun Aug 19, 2018 7:44 am Post subject: Instant electronic brake light switch |
Has anyone had any luck finding an instant brake light switch? My switches don’t seem to wanna work without a ton of pressure on the pedal. |
Fiddlestyx Samba Member
bluebus86 Banned
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Mon Aug 20, 2018 8:42 am Post subject: Re: Instant electronic brake light switch |
I had to put one of those kits on after I got my front disc conversion. Having the discs I wasn't applying as much pressure to the pedal, and the lights weren't coming on right away with the stock pressure switches. Got a kit as mentioned above and it works the second I press my pedal. I also installed LED brake lights to lighten the load on the micro switch.
Great upgrade.
Also, the micro switch can be wired in series with the original switches, so if one fails, you will still have brake lights. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Aug 20, 2018 3:45 pm Post subject: Re: Instant electronic brake light switch |
clbarton91 wrote: |
Have you tried a pair of good-quality switches, and then bleed the brake system? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Aug 20, 2018 3:52 pm Post subject: Re: Instant electronic brake light switch |
kangaboy wrote: |
Also, the micro switch can be wired in series with the original switches, so if one fails, you will still have brake lights. |
parallel, actually. |
GearHeadKeith Samba Member
Joined: January 14, 2003 Posts: 112 Location: Detroit, MI
Posted: Tue Jun 11, 2019 8:23 pm Post subject: Re: Instant electronic brake light switch |
Fiddlestyx, thanks for the kind words about my kit. I just launched my own website to make it easier to order this kit: www.aircooledevolution.com/products
Thanks! _________________ Keith Gilbert - DdK
1971 Super Beetle sedan, Shantung yellow with black interior. Cosmetically unrestored with over 366k miles.
1776cc: 9.2:1 compression, dual Weber 40DCN on Deano intakes, Primo Petrucci 40mm/36mm round-port heads, Crower VW284F cam, Kymco 1.5" exhaust
SSC trans with 3.78/2.25/1.48/1.04 & 4.12 Gleason R&P, Type IV output flanges, Berg Shifter
Topline front struts/springs/sway bar, Sway-a-Way rear bar, 4-wheel disc brakes
Owned since 1994: 3rd owner since new! |
