How should I proceed? |
Fabricate a working version of you mock-up |
0% |
[ 0 ] |
Fabricate a new mustache bar |
100% |
[ 2 ] |
Total Votes : 2 |
rmallory Samba Member
Joined: January 31, 2017 Posts: 16 Location: Nashville
Posted: Sun Aug 19, 2018 3:13 pm Post subject: How can I mount my elecitric motor? |
So I’m converting my 1969 vw bus from gas to electric.
I installed the motor onto the drive train and realized it’s too long to bolt onto the mustache bar. Right now it’s resting on top of the mustache bar, cushioned with some rubber hose.
Not sure how to proceed. Do you think I can fabricate a piece of steel to attach to the motor and the mustache bar? Rough mock-up:
Or do I need to fabricate a custom mustache bar? |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sun Aug 19, 2018 3:46 pm Post subject: Re: How can I mount my elecitric motor? |
I have yet to see a picture of an ev motor in a bus or beetle that is supported by some kind of bar.
That doesn't mean people don't use them, its just that I haven't seen it. All the pictures I've seen just show the motor hanging off of the transmission.
What setup are you planning (motor, controller, batteries, and placement of batteries)? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sun Aug 19, 2018 4:07 pm Post subject: Re: How can I mount my elecitric motor? |
ivwshane wrote: |
What setup are you planning (motor, controller, batteries, and placement of batteries)? |
The 69 is a weird model though. The drive train in this model is mounted at the mustache bar. So without that bar, the whole thing will rest on the ground. I think on every other year the transmission is mounted to the chassis. But the transmission on mine just hangs:
I’m using EV West’s VW bus kit with 4 early model Tesla batteries. They don’t address this issue with the kit b/c I think it’s unique to the 69. |
Posted: Sun Aug 19, 2018 4:25 pm Post subject: Re: How can I mount my elecitric motor? |
I did not know that.
If you don't mind me asking, how much did the batteries set you back?
I'm looking to convert my ghia to electric but I'm waiting for the battery and transmission tech to improve (however fitting a Tesla deivetrain would be nice). _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sun Aug 19, 2018 4:55 pm Post subject: Re: How can I mount my elecitric motor? |
ivwshane wrote: |
I'm looking to convert my ghia to electric but I'm waiting for the battery and transmission tech to improve (however fitting a Tesla deivetrain would be nice). |
About $2300 for all 4. Craigslist |
Posted: Sun Aug 19, 2018 4:59 pm Post subject: Re: How can I mount my elecitric motor? |
rmallory wrote: |
ivwshane wrote: |
Wow! That's pretty good!
I look forward to your build, please keep posting your progress;) _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sun Aug 19, 2018 5:36 pm Post subject: Re: How can I mount my elecitric motor? |
As a '68 - '71 have no rear trans support (hence the straps holding it up), you'll have to weld up a custom rear support bar. This bar will support not only the motor, but will take all of its torque. Make it stout, but incorporate the stock rubber mounts to avoid breaking stuff. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Sun Aug 19, 2018 5:47 pm Post subject: Re: How can I mount my elecitric motor? |
telford dorr wrote: |
As a '68 - '71 have no rear trans support (hence the straps holding it up), you'll have to weld up a custom rear support bar. This bar will support not only the motor, but will take all of its torque. Make it stout, but incorporate the stock rubber mounts to avoid breaking stuff. |
Is he basically replicating the mounting bar found on later bays? If so, isn't that a part that can be purchased used? Or did VW reinforce the area where it connects to on the underside of the carriage? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sun Aug 19, 2018 6:21 pm Post subject: Re: How can I mount my elecitric motor? |
Dang. That’s what I was afraid of. Looks like that is what others have done:
Not sure how to pull that off. |
Posted: Sun Aug 19, 2018 6:50 pm Post subject: Re: How can I mount my elecitric motor? |
rmallory wrote: |
That looks like a lot of weight in the back. I wonder how that would affect steering control.
I would think people would create a cage for the batteries and mount then underneath in between the rails to help keep the center of gravity low and to keep the weight distribution more even. It would also make heat dissipation easier to achieve.
You couldn't fabricate this?
69 ghia coup 1600dp
70 single cab |
dstimm Samba Member
Joined: June 29, 2018 Posts: 153 Location: Encinitas, CA
Posted: Sun Aug 19, 2018 7:24 pm Post subject: Re: How can I mount my elecitric motor? |
You should ask the EVWest guys, they are friends of mine and I am sure they would be willing to help. They have two split window buses but I am sure they have experience with Bay window buses too. Electric buses are so fun to drive. |
dstimm Samba Member
Posted: Sun Aug 19, 2018 7:28 pm Post subject: Re: How can I mount my elecitric motor? |
ivwshane wrote: |
I actually think that is less weight than the original engine and gas tank. However I do agree that having the batteries under the frame of the bus would be a good idea. Plus it makes the engine bay look so clean. |
Posted: Sun Aug 19, 2018 7:44 pm Post subject: Re: How can I mount my elecitric motor? |
dstimm wrote: |
ivwshane wrote: |
The cleanliness of the evwest installs are what really turned me on to ev conversions. To me they are as beautiful as an engine bay with Porsche 914 fan housing setup. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sun Aug 19, 2018 8:08 pm Post subject: Re: How can I mount my elecitric motor? |
ivwshane wrote: |
I’m mounting the batteries under the bench seat. I have far fewer batteries than the bus pictured and much less weight. Maybe I could but I’m not sure how that would help me. Does that mount the the transmission? I already have a stock motor mount. I need customized one to fit this motor. |
dstimm wrote: |
Good idea. Just shot them an email. |
Posted: Sun Aug 19, 2018 8:49 pm Post subject: Re: How can I mount my elecitric motor? |
rmallory wrote: |
ivwshane wrote: |
The exploded view shows the subframe that the transmission hangs off of in a later bay. I would certainly entertain going this route. |
