lowN2slo Samba Member
Joined: September 21, 2008 Posts: 30 Location: Canada
Posted: Sun Aug 19, 2018 6:32 pm Post subject: ‘67 Overriders |
Can get rear overriders through the fender, bolted to the bumper. But there aren’t any holes/bolts to secure them on bumper bracket. Nothing lines up, help? |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5133 Location: Central Florida
Posted: Sun Aug 19, 2018 6:42 pm Post subject: Re: ‘67 Overriders |
The over rider supports should bolt up with the forward most bumper bracket bolts. It helps to loosen pretty much all the bolts, get everything together and then start tightening up. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7687 Location: Gainesville and St. Petersburg, Florida
Posted: Sun Aug 19, 2018 8:48 pm Post subject: Re: ‘67 Overriders |
Example, here is how the rear overrider support brackets secure to the car. This is a US delivery car with standard equipment "ram protection" (aka towel bars / overriders.) US-spec cars were Deluxes that included the ram protection equipment. However, cars delivered to Canada could easily have been standards, not Deluxes, (as both were available for Canada delivery) and would not necessarily have come with overriders. Thus, no holes in the bumper blade and no round overrider support bracket hole in the rear fender for the towel bars. That's why I suggested photos of your issue.
_________________ -Kent
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1612 Location: Salisbury, MD
Posted: Mon Aug 20, 2018 11:13 am Post subject: Re: ‘67 Overriders |
Here’s a rough idea of how mine are-maybe it will help you out...
Posted: Mon Aug 20, 2018 11:53 am Post subject: Re: ‘67 Overriders |
Correct. The overrider supports are side-specific. Make sure you have the correct support for each side.
Bolted to the car, it looks like this:
Note the bolt flange on the rear overrider support brackets point inward. (This is contrary to the front overrider brackets, as they point outward.)
As previously shown, the body mounting bolt goes through the overrider support first, then the bumper bracket. This configuration is an easy mount-up, as long as you have the correct supports and OEM fender with the hole in the correct spot.
Posted: Tue Aug 21, 2018 6:33 am Post subject: Re: ‘67 Overriders |
Will take another look, thanks for all the responses! |
