asesso Samba Member
Joined: August 14, 2018 Posts: 13 Location: Ocean City NJ
Posted: Mon Aug 20, 2018 6:38 am Post subject: air vents |
I just purchased a 73 Thing with a gas heater. I noticed a short metal cable attached to the vent control lever on the dash near the glove box. it is not connected to anything but the lever. I think it goes to the air vents, but I think I may be missing these pieces. Can someone post pictures on these vents, how they mount on the thing and where this cable attaches
Art |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Mon Aug 20, 2018 11:00 am Post subject: Re: air vents |
asesso Samba Member
Posted: Mon Aug 20, 2018 11:11 am Post subject: Re: air vents |
Thanks for the picture, but I am still confused where the vent doors are located and where the cable connects to the doors
Do you have a picture from the vehicle?
Art |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
Posted: Mon Aug 20, 2018 12:05 pm Post subject: Re: air vents |
The cable comes from the lever and goes down to the Vent number 15 in the picture and goes up inside it to a little lever. This closes off the heat from the floor and directs it to the windshield. It is very simple if you have all the parts. You have to have part 15 for it to work.
GB |
Posted: Mon Aug 20, 2018 12:26 pm Post subject: Re: air vents |
This is all I've got; need somebody who owns a '73 to snap a photo. |
asesso Samba Member
Posted: Mon Aug 20, 2018 12:58 pm Post subject: Re: air vents |
Thanks, this helps a great deal! Would still like to see an actual picture if possible
Art |
Posted: Mon Aug 20, 2018 1:13 pm Post subject: Re: air vents |
I just looked at mine again and the picture shown would look just like that. There is nothing but the cable going from the lever to the outlet. Would have to remove the outlet to show the hookup inside.
GB |
asesso Samba Member
Posted: Mon Aug 20, 2018 1:34 pm Post subject: Re: air vents |
I just looked at mine and there is a flapper door which either directs heat to the floor or up to the windshield. The cable from the dash lever reaches that are but there is nothing on the flapper door to connect the cable. Where do I find that connection ? When I look up in that vent I can see and work the flapper but see no way to connect the cable. Sorry for all the questions but you have been very helpful. I also found a hornets nest in the vent!
Art |
Posted: Mon Aug 20, 2018 2:11 pm Post subject: Re: air vents |
OK this is simple, the cable goes through the side of the outlet were the flapper door is, look at the flapper and there is a little lever attached to the door with a hole in it. The cable has a Dog Leg bend in it at the end. If I remember when I installed mine you take the tube off and to get the bent wire attached. Reinstall it and then you put the little clamp on the cable on the out side of the tube and adjust it to full close and open. Tighten the clamp and check it to make sure it works. Hope this makes since.
GB |
asesso Samba Member
Posted: Mon Aug 20, 2018 2:32 pm Post subject: Re: air vents |
This is a picture of the vent opening in the footwell. A rubber flapper door covers this vent. Am I missing a part because I still don’t understand how to connect the vent lever cable. Be patient with me , I am a surgeon not a mechanic!
Art |
Posted: Mon Aug 20, 2018 2:47 pm Post subject: Re: air vents |
Yes you are missing part 15 in the parts break down and the same part in the picture that shows the cable. When you have that part it will all make since. Check with Mike at https://www.thesamba.com/vw/classifieds/detail.php?id=2153489 and he should have the part.
When I was working as a Tech for Mercedes, BMW, Porche, VW, Audi I use to tell the Doc's they had it easy, Went to school on the Human Body and the Brain was there, the Heart was there, The lungs there, etc. When a new car came out they would move Control units the junction boxes the sensors. Change the way the engine was controlled, had to learn a new system every year and remrber the way the old ones worked as well. Enjoyed it and still do.
GB |
asesso Samba Member
Posted: Mon Aug 20, 2018 2:52 pm Post subject: Re: air vents |
Is this the part I need?
Art |
4118thing Samba Member
Posted: Mon Aug 20, 2018 5:52 pm Post subject: Re: air vents |
The cable connects to a flap in 23. If you close the flap on 23, it diverts the Dow to 22. Part 15 is the fresh air intake manifold to bring air into the combustion chamber. No heated air passes thru 15. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Mon Aug 20, 2018 5:59 pm Post subject: Re: air vents |
Apologies Billy, but I think it is number 21 in the parts breakdown that connects to the cable.
asesso Samba Member
Posted: Mon Aug 20, 2018 6:38 pm Post subject: Re: air vents |
Thanks |
Posted: Mon Aug 20, 2018 9:11 pm Post subject: Re: air vents |
Correct on the 21 should have gotten the parts book out and not looked at the small picture on the computer.
GB |
74 Thing Samba Member
Posted: Tue Aug 21, 2018 6:53 am Post subject: Re: air vents |
Looking at the parts diagram is the air always blowing towards the defrost and the flap allows air to go to the lower passenger compartment when opened? |
BNMike Samba Member
Joined: November 12, 2009 Posts: 333 Location: Hot Springs, SD
Posted: Tue Aug 21, 2018 7:15 am Post subject: Re: air vents |
74 Thing wrote: |
Whenever the heater is on, air is blowing out. Where most of it goes depends on which way the little handle moves the flap inside the nozzle in the picture. You can put the handle anywhere between all footwell heat/less defrost and all defrost/no footwell heat. The problem with the footwell heat is that it cooks your right foot
BNM |
Dougster43 Samba Member
Posted: Tue Aug 21, 2018 8:10 am Post subject: Re: air vents |
I just went through a similar dilemma. There is supposed to be a tab on the flapper that the cable hooks into after it passes through the warm air elbow, but the tab had broken off. It didn’t look like it was very robust to begin with...
Note that the Thing Shop sells a warm air elbow for a 73 but not sure if that’s what you need since there isn’t a picture on their site for some reason. My cable was also in very bad shape.
I replaced the tab on the flapper by cutting a small piece of aluminum angle (I used a “T” profile but an angle would work, and riveting it onto the flapper in the place where the tab should be. I had to drill a small hole in the new tab for the end of the cable to hook into.
I couldn’t find a good stock cable, so I had a replacement cable made by a control cable specialist- I think it was about $20 although he couldn’t match the little bracket that holds the cable to the warm air elbow so I used a cable clip instead. Took a little trial and error but it works great now!
If you decide to try this solution I can try to take a picture although I’m not sure how much is visible without taking it apart. I also have some of the aluminum T left and would be glad to make you a new tab that you could rivet to the flapper. |
