Is it possible to replace valve seats? 65 1200
StiffGizzard
StiffGizzard is offline
PostPosted: Mon Aug 20, 2018 9:40 pm    Post subject: Is it possible to replace valve seats? 65 1200 Reply with quote
So I finally pulled the valves off and started lapping and noticed that exhaust valve seats 1&3 are fucked.
The valves sit flush with the top of the guide and never mind the leak down, I can see LIGHT through one side like the guide is ovalized Sad
Any idea why 1&3 would be in the exact same shape while all the others are solid?
parker007
parker007 is offline
PostPosted: Mon Aug 20, 2018 9:43 pm    Post subject: Re: Is it possible to replace valve seats? 65 1200 Reply with quote
can be fixed by good machine shop. but sometimes cheaper to find used good head. when seat lose machine shop has to make new seat, true pocket and install then grind, expensive.
StiffGizzard
PostPosted: Mon Aug 20, 2018 10:45 pm    Post subject: Re: Is it possible to replace valve seats? 65 1200 Reply with quote
Is it possible to just run an over sized valve that would sit on the top of the seat like the rest?
... or am I just fucked....
Any idea how much it would be for two replacement single port heads?
parker007
PostPosted: Mon Aug 20, 2018 11:07 pm    Post subject: Re: Is it possible to replace valve seats? 65 1200 Reply with quote
that head look like fixed before by hacker, no cant just change valve. problem is gases going between seat, plan new seat with full rebuild or new head.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Tue Aug 21, 2018 1:34 am    Post subject: Re: Is it possible to replace valve seats? 65 1200 Reply with quote
Valve seat replacement is a high specialty job - one that most general purpose machine shops are not going to be able to do.
It was with the change to square boss heads during the 1965 model year that VW changed to a higher quality valve seat, pretty much "unleaded quality" seats began then. Before that, valve seats could and would erode away with modern fuel. I know, I've seen it on my own engines before I changed to square boss heads. (Not that I haven't seen heads form after this time also have horrible valve seats)
Andy T.
rcroane Premium Member
rcroane is offline
PostPosted: Tue Aug 21, 2018 4:54 am    Post subject: Re: Is it possible to replace valve seats? 65 1200 Reply with quote
Andy...did the replacement "F" heads also have the higher quality valve seats, or was it just the square boss heads? Thanks.
'65 Sunroof Bug
The Android
PostPosted: Tue Aug 21, 2018 8:58 am    Post subject: Re: Is it possible to replace valve seats? 65 1200 Reply with quote
Oh, good point there. I think they did, but I never saw any kind of service bulletin saying so.
Andy T.
