‘67 Overriders
lowN2slo
lowN2slo is offline
PostPosted: Sun Aug 19, 2018 6:32 pm    Post subject: ‘67 Overriders Reply with quote
Can get rear overriders through the fender, bolted to the bumper. But there aren’t any holes/bolts to secure them on bumper bracket. Nothing lines up, help?
Sharp64 Premium Member
Sharp64 is offline
PostPosted: Sun Aug 19, 2018 6:42 pm    Post subject: Re: ‘67 Overriders Reply with quote
The over rider supports should bolt up with the forward most bumper bracket bolts. It helps to loosen pretty much all the bolts, get everything together and then start tightening up.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Sun Aug 19, 2018 8:38 pm    Post subject: Re: ‘67 Overriders Reply with quote
Photos would be a HUGE help here, as your wording doesn't make a lot of sense. Wink
Wanted:
Atlas Motors and Brundage Motors license plate frames.
OG member of the '67 Posse
A few of my toys, past and present
'66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert
"Clunk"
67 Florida Deluxe
Samba Purist
PostPosted: Sun Aug 19, 2018 8:48 pm    Post subject: Re: ‘67 Overriders Reply with quote
Example, here is how the rear overrider support brackets secure to the car. This is a US delivery car with standard equipment "ram protection" (aka towel bars / overriders.) US-spec cars were Deluxes that included the ram protection equipment. However, cars delivered to Canada could easily have been standards, not Deluxes, (as both were available for Canada delivery) and would not necessarily have come with overriders. Thus, no holes in the bumper blade and no round overrider support bracket hole in the rear fender for the towel bars. That's why I suggested photos of your issue.
Wanted:
"Clunk"
67 Sunroof
67 Sunroof is offline
PostPosted: Mon Aug 20, 2018 11:13 am    Post subject: Re: ‘67 Overriders Reply with quote
Here’s a rough idea of how mine are-maybe it will help you out...
67 Florida Deluxe
Samba Purist
PostPosted: Mon Aug 20, 2018 11:53 am    Post subject: Re: ‘67 Overriders Reply with quote
Correct. The overrider supports are side-specific. Make sure you have the correct support for each side.
Bolted to the car, it looks like this:
Note the bolt flange on the rear overrider support brackets point inward. (This is contrary to the front overrider brackets, as they point outward.)
As previously shown, the body mounting bolt goes through the overrider support first, then the bumper bracket. This configuration is an easy mount-up, as long as you have the correct supports and OEM fender with the hole in the correct spot.
Wanted:
"Clunk"
lowN2slo
lowN2slo is offline
PostPosted: Tue Aug 21, 2018 6:33 am    Post subject: Re: ‘67 Overriders Reply with quote
Will take another look, thanks for all the responses!
