rty1138 Samba Member
Joined: June 10, 2018 Posts: 101 Location: San Francisco
Posted: Mon Aug 20, 2018 11:40 pm Post subject: Reverse light switch mechanism in transmission not working? |
Everything works except whatever is inside the transmission that switches the switch. Any ideas? _________________ 1984 Vanagon GL |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Tue Aug 21, 2018 2:33 am Post subject: Re: Reverse light switch mechanism in transmission not working? |
If you removed the switch and tested it for continuity
nO, closed when activated.....
It’s time to take the trans apart. Not.
Wire in a switch to the dash and bypass the trans switch. _________________ .ssS! |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Tue Aug 21, 2018 6:17 am Post subject: Re: Reverse light switch mechanism in transmission not working? |
The switches are finicky, and they require a washer like spacer. If it was removed and you tested it and the switch itself is good, don't go assuming the trans is the problem until you are sure that you've got the right spacer/washer. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Aug 21, 2018 11:01 am Post subject: Re: Reverse light switch mechanism in transmission not working? |
bobbyblack wrote: |
The switches are finicky, and they require a washer like spacer. If it was removed and you tested it and the switch itself is good, don't go assuming the trans is the problem until you are sure that you've got the right spacer/washer. |
Thanks I was just reading that a spacer might be needed. Any ideas on size? _________________ 1984 Vanagon GL |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Tue Aug 21, 2018 11:16 am Post subject: Re: Reverse light switch mechanism in transmission not working? |
My old transmission had a very finicky reverse light. It wasn't the switch itself, but the selector shaft that actuates it was worn. It was a matter of very fine adjustment to get the light to come on in reverse rather than (strangely) 4th gear.
As the transmission hadn't had the 3/4 hub thingy replaced, had 215,000 miles on it and leaked like a sieve out of the seals I just replaced it with a rebuilt one with beefier 3rd and 4th gears to accommodate the Subaru EJ22 that was being fitted. _________________ Jim Crowther
Vespa GTS 300 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Aug 21, 2018 3:31 pm Post subject: Re: Reverse light switch mechanism in transmission not working? |
I lost track of the reverse light spacer when I installed my "new" (rebuilt) tranny last summer.
Actually, I think I never got it off the old unit & returned the core with the spacer stuck to the case...
Long story short, I found out shortly afterwards that my reverse lights were coming on...IN EVERY GEAR!
After some Samba searching to verify the specs, I found a suitable washer (close as possible to 0.90mm...
...I think mine was slightly over that), popped it in place & it's been perfect ever since...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Tue Aug 21, 2018 5:28 pm Post subject: Re: Reverse light switch mechanism in transmission not working? |
Boy, the automatics are super easy to deal with the reverse switch. It's a gigantic 1940's looking heavy copper switch more befitting a train. Easy to get to by the shifter, etc. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Fri Aug 24, 2018 12:34 pm Post subject: Re: Reverse light switch mechanism in transmission not working? |
UPDATE:
i definitely have the washer spacer installed. i tried tightening and loosening the switch. nothing. i had the crazy idea of removing the washer and IT WORKS!
so yeah, sometimes you need the washer, sometimes you don't i guess. _________________ 1984 Vanagon GL |
Posted: Fri Aug 24, 2018 2:29 pm Post subject: Re: Reverse light switch mechanism in transmission not working? |
Counter-intuition FTW!!!
What are the chances you had (2) spacers on there before you removed one...???
<shrug>
"The WonderVan"
fxr Samba Member
Posted: Fri Aug 24, 2018 5:02 pm Post subject: Re: Reverse light switch mechanism in transmission not working? |
Check it doesn't also come on in other gears than just reverse - BTDTGTTS. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Fri Aug 24, 2018 6:44 pm Post subject: Re: Reverse light switch mechanism in transmission not working? |
fxr wrote: |
Check it doesn't also come on in other gears than just reverse - BTDTGTTS. |
i'll check _________________ 1984 Vanagon GL |
Racin_jason Samba Member
Posted: Wed Sep 05, 2018 9:25 am Post subject: Re: Reverse light switch mechanism in transmission not working? |
any one have any secrets they'd be willing to share as to how to remove the switch while its still in the car? |
Posted: Wed Sep 05, 2018 10:27 am Post subject: Re: Reverse light switch mechanism in transmission not working? |
Racin_jason wrote: |
"car" ???
Vanagon I hope. Automatic? Manual? Year? _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Thu Sep 06, 2018 4:56 pm Post subject: Re: Reverse light switch mechanism in transmission not working? |
bobbyblack wrote: |
"car" ???
Vanagon I hope. Automatic? Manual? Year? |
sorry i ended up here via the search function. looking for beetle info.. I'll see myself out. |
Posted: Thu Sep 06, 2018 6:48 pm Post subject: Re: Reverse light switch mechanism in transmission not working? |
No harm, no foul...
"The WonderVan"
