El Samba Member
Joined: August 02, 2018 Posts: 22 Location: New England
Posted: Fri Aug 03, 2018 11:06 am Post subject: My 69 |
Finally figured out how to post pics I bought this a month ago, after a long search for what I thought was a good deal for a vintage bug in reasonable condition. It runs great (fingers crossed) and minimal surface rust under the fenders. I plan on new paint and thats all. It's now a show car but I love it! My question is, did I pay too much.... less than 3,000.00- with unknown miles- odometer was disconnected at some point during a 5 yr nap in a garage, and I have no idea, but it reads at 46,000, and I did have that fixed.
sb001 Samba Member
Posted: Fri Aug 03, 2018 11:20 am Post subject: Re: My 69 |
Yes you paid WAY, WAAAYYY too much.
That's a $400 car, but I'll take it off your hands for $500.
Joking aside, to find a bug in New England with very minimal rust, with a nicely running engine, and an interior in that condition, you got a steal. Loks like it was very well cared for. Looks like a miminal bit of work left to do to finish it off in the engine bay and up front in the trunk, but very nice as is.
Mine is a Royal red 1969 as well, and it has received lots of compliments.
Is it a matching engine #? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Fri Aug 03, 2018 11:29 am Post subject: Re: My 69 |
Nice bug! I have a -68 and I love it.
But please consider removing that fuel filter out of the engine compartment. A fuel filter on the pressure side of the pump and just above the distributor is like asking for a engine fire..... _________________ Type 1 1968, Lotosweiss. 2109 oxyboxer engine
Early Bay 1970, Montana Red. Under construction |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Fri Aug 03, 2018 11:46 am Post subject: Re: My 69 |
sb001 wrote: |
Joking aside, to find a bug in New England with very minimal rust, with a nicely running engine, and an interior in that condition, you got a steal. Looks like it was very well cared for. Looks like a mininal bit of work left to do to finish it off |
Agree. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
El Samba Member
Posted: Fri Aug 03, 2018 12:21 pm Post subject: Re: My 69 |
That makes me feel better! Thank you!
I do not know really where to find the engine number, but I will look around if you point me in the right direction? and where would the fuel filter be relocated to ? |
El Samba Member
Posted: Fri Aug 03, 2018 12:25 pm Post subject: Re: My 69 |
sb001 wrote: |
Is it a matching engine #? |
I'm going for the royal red as well! There is some yellow paint on parts of this bug, but I have no idea what was done to it previously. |
Cusser Samba Member
Posted: Fri Aug 03, 2018 12:34 pm Post subject: Re: My 69 |
El wrote: |
I do not know really where to find the engine number, but I will look around if you point me in the right direction? |
Engine number is stamped just below the generator stand. For a 1969 VW originally began with letter "H".
Zundfolge 1-4-3-2 is the firing order.
A fuel filter unsupported like yours can pull brass outlet tubes from the carb or fuel pump, or can break or leak, fire danger.
The outlet tube near the oil fill cap should connect to the air filter. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
El Samba Member
Posted: Fri Aug 03, 2018 1:08 pm Post subject: Re: My 69 |
The outlet tube near the oil fill cap should connect to the air filter.[/quote]
Ut oh.. so my number is AE which if I read on JBugs right, is a 71? Is this a bad thing?
Thank you for the info on the fuel filter. I will get it to a mechanic next week. Its hot enough around here without having a bug fire! |
sb001 Samba Member
Posted: Fri Aug 03, 2018 1:15 pm Post subject: Re: My 69 |
El wrote: |
No not a bad thing at all. It just means someone switched out the original 1500cc for a 1600cc. (Still single port though, very similar to what originally came on the car.)
What are the rest of the numbers on the block? _________________ I'm the humblest guy on this board.
1600 SP engine
El Samba Member
Posted: Fri Aug 03, 2018 1:28 pm Post subject: Re: My 69 |
What are the rest of the numbers on the block?[/quote]
AE 475958
next to that there is a black metal piece that has
vw 113.129.70---cant see the rest.
And one part says made in brazil. |
El Samba Member
Posted: Fri Aug 03, 2018 1:29 pm Post subject: Re: My 69 |
El wrote: |
What are the rest of the numbers on the block? |
AE 475958
And one part says made in brazil.[/quote]
Dubious heritage! |
Cusser Samba Member
Posted: Fri Aug 03, 2018 1:30 pm Post subject: Re: My 69 |
El wrote: |
Ut oh.. so my number is AE which if I read on JBugs right, is a 71? Is this a bad thing? |
Unless you're doing a 100% restoration, I think an AE 1971 engine is a GOOD thing, especially if it has the 1971 doghouse oil cooler/fan shroud. The engine pictured has single port heads, likely a 1600cc single port now, that's fine.
An AE engine is better metal alloy than the 1967-1969 "H" engines, and the AE engine is dual relief pistons where the "H" was single relief. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Danwvw Samba Member
Posted: Fri Aug 03, 2018 1:50 pm Post subject: Re: My 69 |
El wrote: |
I plan on new paint and thats all. |
What a nice find. Good solid bug. Yeah, be glad it's the 71 engine case it's pretty good somewhat better than the 68's mechanically speaking. An AE or later case would be best. You can always find a case for a 68 if you want it original. Looks like it's got the 68 engine tin etc on it.
Yeah, give your engine some attention. Get the Heater hoses hooked up as they move a lot of heat away from under the engine for you. Check your actual oil temperature, Hot and see how hot it is running. That 71 engine case was designed for a better cooling fan shroud etc.. The one called the Dog House. But since the car has single port heads it probably will do ok with the 68 non-dog-house fan shroud. The only weakness in the AE engines was the pulled cylinder head studs. Yours is probably inserted. You can look under the engine, may have to remove some engine tin to see though if it has the case inserts. You're looking to see where the cylinder head studs go into the case if it has inserts:
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Mos6502 Samba Member
Posted: Fri Aug 03, 2018 2:00 pm Post subject: Re: My 69 |
I think you got a good deal.
But as others have noted, hook up all the air hoses, and the breather hose on the engine.
One thing I see, and I'm curious about is in the pic of the back side of the dash. Right in the very middle of the pic, there's a hose coming out of the bottom of the fresh air intake - but it's routed to the side rather than to the drain in the center of the trunk. Find out where that hose goes - you do not want it dumping water into some part of the car where it can't drain away!
edit: did a quick google search to find a pic
That hose from the bottom center of the fresh air intake is supposed to go right down the middle of the trunk and to a drain hole, as seen in this photo. It lets water drain out of the ventilation system when it rains. Who knows where it's dumping water on your car the way it is currently set up. |
El Samba Member
Posted: Fri Aug 03, 2018 2:21 pm Post subject: Re: My 69 |
Amazing information! I was told the hoses in the engine were not needed since it won't be driven in the winter. That didn't make sense to me, because of the points you all made. I am ready to get all of this on a list for the mechanic to fix. The front compartment hose in the middle mentioned, the part stuck into the air vent, I will see where it leads to. Thanks for so much info! I will try to educate myself a little more before I ask too many annoying questions |
El Samba Member
Posted: Fri Aug 03, 2018 2:24 pm Post subject: Re: My 69 |
That hose from the bottom center of the fresh air intake is supposed to go right down the middle of the trunk and to a drain hole, as seen in this photo. It lets water drain out of the ventilation system when it rains. Who knows where it's dumping water on your car the way it is currently set up.[/quote]
OHHH ok! I found that plastic L shaped part in the glove box and didn't know what it was for. I stuck that hose in the air vent cuz it fit.. Thanks you!!!! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Aug 03, 2018 9:57 pm Post subject: Re: My 69 |
Get the fresh-air hoses from the engine fan to the two two-inch pipes sticking up out of the rear breast plate. There are also rubber gaskets that attach on those lower pipes.
The engine fan’s air is supposed to blow down those pipes to, not only supply heat in winter, but also to help cool parts of the engine—heat exchangers to heads.
Also, get a stock air filter. The small empty pipe that sticks up from your oil filler is a blow-by pipe. Oil and blow-by comes out of there. A rubber hose connects at the oil filler and is run to another small pipe to the air cleaner.
I think you got a great deal. Look below at my engine to see where the various hoses mentioned above are located.
Tim
_________________ Let's do the Time Warp again!
Richard O'Brien |
docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Fri Aug 03, 2018 10:12 pm Post subject: Re: My 69 |
1970 engine compartment should look pretty similar to yours.
https://youtu.be/KoEY8K26KAM _________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15” 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
El Samba Member
Posted: Sat Aug 04, 2018 5:20 pm Post subject: Re: My 69 |
Thanks so much for the advise, and pictures of what the engine should look like! I have some parts to order, and hoping I can install some of them myself. |
