sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Wed Aug 22, 2018 3:49 pm Post subject: Lifted Spindles or adjustable beam |
I went with raised spindles to keep the suspension geometry the same, the steering was heavy.
I believe that an adjustable beam to raise it keeps better stering geometry but worse suspension.
Which is better.??
i HAVE 205X15 TYRES SO HAVE REASOBABLE GROUND CLEARANCE.
SORRY ABOUT THE CAPS LOCK _________________ 63 singlecab
73 thingster
74 Thing |
Brian Samba Moderator
Posted: Thu Aug 23, 2018 5:51 pm Post subject: Re: Lifted SPiddles or adjustable beam |
Lift spindles are the better way to go, in my opinion. Heavy steering could be from the larger tires and changing the offset of center line from the wheels. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
mikething Samba Member
Joined: February 09, 2009 Posts: 95 Location: Dana Point
Posted: Sat Sep 01, 2018 8:11 pm Post subject: Re: Lifted SPiddles or adjustable beam |
where do you buy lift spindles? |
Hyatt181 Samba Member
Posted: Sun Sep 02, 2018 3:26 am Post subject: Re: Lifted Spindles or adjustable beam |
I was just comptenplating this subject.
I have a beam with adjusters in it.
But I have a better condition beam in my basement.
I also have a set of 2 1/2” higher spindles in my basement.
Was trying to decide if I add adjusters and use a stock spindle or skip the adjusters and use the raised spindles. |
66 Shorty Samba Member
Joined: May 10, 2007 Posts: 916 Location: Rhode Island
Posted: Fri Feb 19, 2021 10:26 am Post subject: Re: Lifted Spindles or adjustable beam |
Raised spindles for a thing or raised spindles for a bug? They're different, but, I'm sure you already know that...
If you use 2.5 raised bug spindles you'll be at stock thing height... and they won't just bolt up to the thing arms...
I just added adjusters to my thing beam. I'm contemplating on how I'm going to do bump stops and limit straps... I don't like the hook and rod cuz of all the clanking of metal on metal... anyone ever do it without hook and rod? I'd like to see some examples. |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Fri Feb 19, 2021 11:09 am Post subject: Re: Lifted Spindles or adjustable beam |
Ummm, you dug up a pretty old thread to respond to.
Have you ever used hook & rod limiters? I’ve pounded the shit out of mine & never heard them “clank”.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
